Future proofing, for someone who doesn't really play games (he grabs them, plays for a day or two then gets bored) then surely the RAM to 16GB is a pretty cheap upgrade and way to future proof the system instead of getting 2 GPU's.
You've gone for 8GB of PC12800 where as my build had 16GB of PC 15000.
Any reason why you've gone for a different motherboard (about £20~ cheaper)?
650w PSU against a 950w is another £50, slightly different CPU cooling and mine had the added TV card (£30).
i went for the lower ram as you can clock it yourself and like i said, 16gb is so pointless for his needs you dont even know, he may aswell use the extra £140 as toilet paper.
Changed the mobo out for no real reason, i like the look of the p67 sabertooth with its black jacket, the x58 was a good board, very stable, not heard much from the one you chose.
650w will be plenty enough for the build, anymore is a waste unless he plans on goin sli/xfire, the xfx model is a quality unit too.
how long ago didhe buy that system? because all buissnesses legallly have to give you atleast 7 days to get a full refund on what you brought, and i even managed to do this like 10 days after i got my 560 ti![]()
ok, how about:
Intel Core i7 970 3.20GHz (Gulftown) (Socket LGA1366) - Retail £449.99
Gigabyte GA-X58A-UD7 Intel X58 (Socket 1366) DDR3 Motherboard £299.99
OCZ Vertex 3 120GB 2.5" SATA-3 Solid State Hard Drive £239.99
Corsair Professional Series™ Gold AX850 High Performance 850W Power Supply £157.99
GeIL 12GB (3x4GB) DDR3 PC3-12800C9 1600MHz VALUE PLUS Triple Channel £119.99
Fractal Design Define XL Full Tower Case - Black Pearl £94.99
Compro VideoMate E900F Dual Tuner TV Card - Retail £84.76
Thermaltake Frio CPU Cooler £42.98
Fractal Design 140mm Silent Cooling Fan £12.24
Fractal Design 120mm Silent Cooling Fan £9.98
Total : £1,527.90
Peerzy, you can drop the i7 2600k and get an i5 2500k, it can be just as easily overlcocked to 4.5Ghz on Air.
