how many fans and where comes with a coolermaster elite 430 ?? confused on this
22 Nov 2010
Kettering
hey guys,
ive been reading and watching reviews on the coole rmaster elite 430 case and some reviews say it comes with only a rear fan and some say it comes with a front LED fan
which is true ??
if it dose only come with the one fan i will be ordering 3 120mm blue LED fans for it, but need to confirm how many comes with it first :)
cheers fellas
beasty
im going to put two 120mm fans in as well, one at the top and one at the rear, both will be used as exhausts
im also thinking if to get a 120mm fan for the side as a intake for my gtx 480 ??
what do you guys think ??
oh yeah, thanks stulid, i did not think of that
also whats the difference in the lite and advance case ?? is it enough to worry about
Differences:
- Interior black coating makes stylish inside looks
- Front 120mm fan with brilliant Blue LED provides the best airflow to HDDs
- Rear 120mm fan for high-efficiency ventilation
- Tool-Free mechanical design for quick assembly and maintenance
- Side ventilation holes for better cooling performance
- Large transparent side window included
- Supports long graphics cards including Radeon HD 5970
- Top Cooling: 120 mm fan x 2 (optional)
- Front Cooling: 120 mm blue LED fan or 140 mm fan x 1 (optional)
- Rear Cooling: 80/90/120 mm fan x 1(optional) (120mm fan included)
- Side Cooling: 120 mm fan x 1(optional)
- Bottom Cooling: 80/90/120 mm fan x1(optional)
- I/O Port: USB 2.0 x2, Mic x1, Audio x1, 1394a x 1,(optional)
- Dimension: 190 x 424 x 490 mm (W x H x D)
- Dimensions: 214 x 511 x 528mm
- Motherboard Compatiblity: ATX, Micro-ATX, Mini-ITX
- Room for 120 x 240mm Radiator inside the top and bottom
- Cable management and CPU retaining holes for easy maintainence
- Support Tri-GFXs
- 4 x 5.25" Drive Bays
- 7 x 3.5" Drive Bays
- I/O Panel: USB2.0, 1 x eSATA, 2 x Audio
- Front Cooling: 1x 120 mm (17 dBA)
- Rear Cooling: 1x 120 mm (17 dBA)
- Top Cooling: 2 x 140 / 120 mm (optional)
- Bottom Cooling: 2 x 120 mm (optional)
- HDD Cage cooling: 1x 120 mm (optional)
