- 10 Jun 2010
- Scotland
Ok. I have 4GB of DDR2 667 ram installed into an Abit IL97-Pro. I am running a x64 bit OS, Windows 7.
On a fresh install, it only detected 3.12GB. I figured this was a limitation of the BIOS or a fault. I checked the manual, it does indeed support 4GB. I then flashed the BIOS to the latest version and it dropped to 2.87GB usable.
It does see the 4GB, so it tells me. Just refuses to use them.
I thought the only thing it could be is my video card stealing some of the system ram, i opened up dxdiag and found it to be nibbling on a whole 1200MB of system ram.
I then thought, I'll install the proper ati drivers, that should sort it. Unfortunately not. Just the same. There isn't an option in the BIOS unlike laptops to limit the amount of ram it uses either.
It's an HD 2400 pro. Surely it doesn't need to steal my system ram, I wont be playing games on it either, so nothing intensive at all.
Is there a way to limit the amount of shared memory on a dedicated card under windows 7 x64?
Cheers.
Cheers.
