Yeah Ive checked the prices, its not tooooooo bad!
$160 you can have a custom package, 1 pistol, 1 sub machinegun and 1 assualt rifle
Ive put aside $250 just for the range![]()
I'm not going crazy, I want to do everything I want to do but I'm not planning to be excessive.
My main concern is the plane journey, 11 hours is a long time. Luckily I have some stuff on my iPad to keep me entertained but I'm sure it won't be much fun!
On the way there i was up for about 28hrs and on the return journey i was up for about 34hrs with work the following day!No it's not. We got a coach to the Canyon from Vegas which took a couple of hours. Unfortunately we had to endure the film 'Click' enroute.[TW]Fox;18824571 said:Driving to the Canyon isn't as easy as you think - its a LONG way from Vegas, it's about a 7-8 hour drive really.
Yeah well 4 of us are going, so $5 each for a taxi is nothing
Well yes Im assuming Im going to spend more money that I budget for, it is Vegas after all!
Check this site out: http://www.grandcanyonskywalk.com/
You've got to do the Skywalk. Really cool (and a little bit nerve racking!).
Stopping at Hoover Dam was also fantastic.
No it's not.
I tell you what, rather than just slam me, why not offer some friendly advice?
no need to be so abbrasive!Thats fine, 4 1/2 hours is what we are expecting, would have been nice to stop over and spend 2 days in total, but as we are only there for 6 nights we will have to do it in a single day
Here's hoping I dont get lost at night on the way back to Vegas![]()
It's still sinking in since the first post to suggest as such[TW]Fox;18825557 said:As others have said, you didnt actually go to the Grand Canyon at all. You went to somewhere similar, thats well marketed, and run by a bunch of scammers.
Will do my best!
Has anyone here ever driven from Vegas to the Grand Canyon south rim?
Having some problems finding directions :S
Also I wouldn't want a convertible to drive to the canyon, You'll want the roof up if you spending 8 hours in the desert sun otherwise you'll have to lather on the factor 50.
To be honest, if is your first time and you're only there for six days. I wouldn't bother driving to the Grand Canyon. It's not like it is going anywhere, just go next time.
