Hi Everyone,
wish my first thread on here could be a bit more jolly but alas a sorry tale to tell. Anyway..
Got my new Gigabyte GTX480 SE today , had been looking forward to it and it was delivered very quickly so that was great.
Removed my GTX295 and fitted the GTX480 SE with great care and anti static strapped with cotton gloves as well !! fitted fine and hit the power switch, the fans on the GTX480 burst into life but nothing else did .... oh well i said, i'll check the power connectors , hmmm all ok there. booted again.... the green lights came on on top the GTX480 " oh great" i said So shut down and put the side panel on , booted..... nothing. Checked cables, all ok. Booted... nothing.
Reseated the card , booted... nothing. Refitted the GTX295 and it booted straight to Windows.
Just dont get it ,seems like an intermittent fault or incompatibility.
So now i have my RMA and will return it tomorrow. If it comes back ok then im stuck as i dont know what else to check really.
My GTX295 works fine each time and does every day . GTX480 SE just wouldnt post.
Any ideas or is just bad luck this time ?
Thanks all.
SYS:
Antec 900 Case
Asus P5N-T Deluxe motherboard
8GB DDR2
GTX295
Extreme QX9650
Thermaltake Toughpower 700W
Thanks all.
SYS:
Antec 900 Case
8GB DDR2
GTX295
Extreme QX9650
