Gigabyte GTX480 SE temperatures
4 Nov 2002
Harlow
Hi, was just looking to idea of what temperatures people are getting with this card, both with stock settings and when overclocked if possible...
GB 480 SE temps
I have an SE in a CM Cosmos S case and have set the fans with MSI Afterburner to idle at 32% fan and 44oC. playing Crysis2, BFBC2 etc goes up to 65-70% at 79 to 83oC depending on room temperature. 32% is almost silent.
Stock fan is set to idle at 48% which is to high and slightly audible IMO. Fan at 70% is not too bad but audible over system fans. Quieter and less annoying than a stock 5850.
These are at Stock speeds. Going up to 755 mhz did not seem to have much effect on temps but its only a mild OC.
Its a v.good card but you need adequate case ventilation. I would say Sli would be a different matter as far as noise and temps go.
My temps are somewhat higher then that, thinking that I may need get myself a new case. Only got a small 80mm input fan and a 120mm outtake fan on the current case, think the airflow may be somewhat limited...
480 soc @ stock , playing ffxiv now and temps were around about 77-78c , now around about 66c
10 degrees less by forcing v sync in the nvidia control panel , which is a result cos it looks better and runs cooler :)
480 SE stock in Antec 900
Crysis 2 for an hour or so
I'm getting average temps of 70c with the fan at the standard 48%
Can't understand why my temps are so much higher than yours I would imagine there are very few cases with better airflow than my Cosmos S. Maybe the TPM needs redoing. Anyone taken the cooler off one of these?
