Eyefinty Question
8 Jul 2007
Huddersfield
Right before i order this today just want to make sure this will all work
I have already a BenQ 2410HD monitor (dvi)
Going to buy 2 Benq 2420HD monitor (dvi and hdmi)
and a XFX 6950 2GB to be flashed to 6970
and OcUK Mini DisplayPort to DVI-D Active Single-Link Adapter
What I want to do is
Monitor 1 DVI - DVI
Monitor 2 HDMI - HDMI
Monitor 3 Mini DP adaptor - DVI
Will this all work, thanks in adavnce
That should all work fine, although you wont be looking at amazing fps on a single 6850 at that res (all depending on what you're playing of course)
yes sorry meant 6950 to be flashed to 6970(edited 1st post)
and they are all ordered and will be here today, the monitors are from somewhere else though as ocuk dont stock the ones ive ordered
Monitor 1 DVI - DVI
Should be able to run Monitor 2 off dvi as well as the card has 2 so:
Monitor 1 DVI - DVI
Monitor 2 DVI - DVI
right ive got everything and cant get it working
Its not to do with the monitor been dvi-i and the adaptor dvi-d is it
edit all monitors are dvi-d
stumped atm
right the hdmi monitor is on
the dvi monitor is on
but the connected via the active mini DP - dvi will not come at all
may sound silly but recheck the mini dp connections to make sure theres good contact i had the same and the monitor conection was loose
the one i recieved was his and worked with no problems, im not sure if you have missed something or mabe the adaptor is faulty its hard to say
the only thing i can think of now is to just use the displayport on its own with only one monitor and see if you get a signal, if not i would be concerned there was a fault with the adaptor, also look into the monitor settings to see if you have to change the input device manually
