Would a lot of people take into consideration one bad feedback, when the rest are positive, and ive argued my case against the feedback?
Sure it isn't actually faulty? If it's never been used it is possible.
That's what I thought. If true then this other guy is thinking the same about the OP that the OP is thinking of him.
Again, in a rare case possibly yes, but he told me he had removed an item the same as mine previous and installed mine, so where do i stand?
You get him to send it back, you check the serial numbers (oh wait...) and then if it's genuinely faulty you refund him. If not, you don't.
Why should i refund on an item never installed? nor used?
At which point ebay refund him anyway.
And why would that matter?
The seller gets the item back, it works, he can sell it again.
Neither party are out of pocket bar a small amount for postage.
I'm not convinced by that, but then mercifully I've never been in that position.
Nowhere, you should have taken the serial numbers off it or used a UV pen on some part of it and taken snaps as proof.
Basically sold an item that was brand new, never been used or installed, to do with plumbing and electrics
he received the items and used the words "thanks its exactly the same item as i had removed"? anyhow he then goes on to explain the item is faulty and wont work? the items had never been used in there life!
i then go onto help him (baring in mind these items needed to be installed by a professional) he claims hes a heating engineer? but said there unusable, so i send him all the relevant paperwork and instructions to guide him, everything i get back is these don't work, i want a refund!
i then said i wouldn't be issuing a refund as there was nothing wrong with the items, he then sends the items to case, and leaves negative feedback on my profile,
so what do i do from here? do i have any chance of this going in my favor?
Alex
Those eBay ******** push us sellers to ridiculous extremes because they refuse to protect us...
If he does post the item back to you, DENY all receipt. If it needs to be signed for, DO NOT SIGN FOR IT and do not accept delivery. Sadly, as a seller, the only way you can fight bandits like this is to seriously go balls to the wall and **** with them. Likely he will return it in standard post, requiring no signature or proof of delivery - if this happens, deny it ever returned back to you and there is no way you can refund the seller.
