adhesive for a zetec badge?
13 Jan 2004
Leicestershire
what would you use? it comes off with that gummy stuff you use to get off with boiling water. where can you get that from and whats it called?
i have the option of fitting 2 2nd hand ones (+gum) or 2 new ones but will be a LOT cheaper if i knew what that adhesive were?
Pop in a body shop and buy 2 inches of whatever double sided tape they use off them. Invariably they will tell you to keep your money and give you a bit.
