Mine was cleared up very nicely with Zineyt lotion. It came in a weird bottle with a dabber on the end that was used to treat the offending areas. That probably took under 6 months, and my spots were quite bad at times.
Hey,
There's loaaaads to know, and I was on it for several months in my last year of uni.
A good start is http://reclaimyourskin.co.uk/ - I myself wrote a little blog on there for people like you to read and add to when you start on the drug.
It can have bad side effects but this will be explained to you (extreme dry skin, dry scalp etc.) it basically reduces dramatically your skins ability to produce oil and therefore stop the acne.
I did have a lot of submissions on that site, but it seems they've redesigned it and my content isn't there anymore.
My skin used to be pretty bad and therefore I lacked confidence! Wish I went on it before uni, it wasn't until my skin was clearing up a fair bit that I actually met someone (probably a mix of improved self confidence and nice skin!).
Before (I have very few photos of my skin before it got better!)
Now:
How old are you and how serious is it?
I tried all sorts of creams etc, various antibiotic tablets (oxytetracyclene), and none worked.
I met a dermatologist through the NHS and had my bloodtests, then went onto a course of tablets.
In a nutshell, these were the phases;
1-2 weeks - nothing much, skin starting to dry by the 2nd week
2 weeks onwards - incredible dryness of skin, lips cracking, random nosebleeds where the skin inside your nose just randomly cracked! (had about 5 in total).
You get a phase of really nasty spots, but this clears and it was suprising how fast my skin lost its redness and cleared up.
6 months seems like a long time, but it really flys by and is well worth doing imo.
She also had massive mood swings and put on a bit of weight. However, she had also just taken the anti-preggers jab so that might have also been to blame for those two conditions.
It was single handedly the best decision I have ever made.
Yes, the side effects were AWFUL. The outcome made it worth it a million times over.
I only took the drug for 6 months on a large dose.
Supplement with Vitamin D?
Would that seriously work? It's not like I am hidden in a basement all day. Even when I am indoors - my room has two windows and plenty of sunlight gets through.
May I ask what does you were on mate? As mentioned before, I got it presbribed roaccutane back in December and plan to start taking it (now that my life is sorted out) shortly. I was presbribed 90mg a day which seems high![]()
I'm 28 bro and I still have issues with my face from time to time. If I'm stressed/not sleeping/being lazy, eating badly etc. I use 'Quinoderm' (5% benzoyl peroxide) cream. £3-4 from the pharmacy, no presciption, and it works great for me. I use it if I need to and it's usually cleared up in 2-3 days. There's a stronger one too. Worth a go for £3 imo.
