TODAY ONLY - SPECIAL OFFERS...
Brand new for Today Only we've got a fantastic gaming tower with over £10 off!
The new 650D from Corsair sets the new standard in midi-tower chassis design. Corsair Obsidian 650D Gaming Midi-Tower in Black, for just £129.98 -
Gigabyte P67A-UD4-B3 Intel P67 - Get ready for a mind blowing media experience when you upgrade to a GIGABYTE P67A-UD4 motherboard. Every component on GIGABYTE P67A-UD4 motherboards is designed and engineered to deliver exceptional performance and clarity for your computing needs. Powered by the Intel® P67 chipset with support for 2nd Generation Intel® Core™ processors.
Corsair Obsidian 650D Gaming Midi-Tower - Black @ £129.98 inc VAT
The Obsidian Series 650D mid-tower case is manufactured with strong, stamped steel parts for increased rigidity, and coated in a black textured paint. The front panel features a beautiful black brushed aluminum faceplate to bring a subtle elegance to your next build.
A large, black 200mm intake fan hides behind the front dust filter, quietly pushing vast amounts of air over your hard drives and video cards. The air is then exhausted by a second 200mm fan on top of the case, and a rear 120mm fan. The top fan can be replaced by dual 120mm or 140mm fans, and is pre-spaced for a dual radiator if you’re interested in watercooling. And all fans are controlled by a three-mode, four-channel fan controller should you want to make your own choice between noise and performance.
- Motherboard Support: ATX / mATX
- Expansion Slots: 8
- Drive Bays: 5.25" x 4 & 3.5"/2.5" x 6
- Cooling: 2 x 200mm Fans and 1 x 120mm Fans
- Front I/O Ports: USB2.0 x 4 / FireWire x 1 / Audio x 2 / 4-Channel Fan Controller
- Dual 200mm fans provide outstanding cooling for even the hottest components
- Easily accessible dust filters make maintenance simple and hassle-free
- Quick-release side panels make it easier than ever to upgrade your hardware
- Integrated fan controller lets you quickly adjust cooling performance and noise levels
- Four tool-free optical drive bays and up to six SSD-ready hard drive trays provide plenty of expansion
- CPU backplate cutout makes it easy to upgrade your CPU cooler
- Brilliant cable routing system provides a way to keep your system neat and tidy
- Adjustable drive cages can be removed and relocated to accommodate large video cards
- Room for long power supplies gives you peace of mind for future upgrades
- Dimensions: 546mm (L) x 229mm (W) x 521mm (H)
Only £129.98 inc VAT.
ORDER NOW
Gigabyte P67A-UD4-B3 Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) ** B3 REVISION ** @ £138.00 inc VAT
nonl2br
Get ready for a mind blowing media experience when you upgrade to a GIGABYTE P67A-UD4 motherboard. Every component on GIGABYTE P67A-UD4 motherboards is designed and engineered to deliver exceptional performance and clarity for your computing needs. Powered by the Intel® P67 chipset with support for 2nd Generation Intel® Core™ processors, GIGABYTE P67A-UD4 enjoy uniquely developed technologies such as Maximum Power Delivery technology, Dual CPU Power technology and Ultra Durable 3™ design just to name a few, that ensure a reliable and enjoyable computing experience. ike the pistons and cylinders of a car engine, the design of the motherboard Voltage Regulator Module (VRM), component quality and number of power phases greatly affects motherboard performance. GIGABYTE engineers were first to realize not only the importance of using the best quality components for this critical area, but also that with more power phases, there can be more power available to your CPU. GIGABYTE 6 series motherboards with their new redesigned VRM, promise to deliver first class system performance and power stability. With only the best quality components and unique design, incorporating Dual CPU Power and Power Phase Boost with Multi-gear Switching, your CPU can enjoy better power than what was available from previous motherboards.
- Intel P67 Chipset: Socket 1155 Support for K edition Unlocked CPUs<br>
- SLI and Crossfire support
- SATA 6GB/s and USB 3.0
- ATX Form Factor
- 3 Year Warranty
Only £138.00 inc VAT.
ORDER NOW
ORDER NOW
nonl2br
- ATX Form Factor
- 3 Year Warranty
ORDER NOW
