Thanks for the reply, was considering that one to be honest but need to read more about it.
What fan do i get to match the top one currently installed? or do i just get 2xred led 200mm megaflows from Cooler Master and use them?
The HAF X is a superior case for air cooling compared to any Corsair case.
The HAF X offers the best in cooling performance.
) and will probably keep this for quite a while now.very true lee,but on another note,it's only people's word that it is good at air cooling but until you actually get one for yourself you dont realise just how good the haf-x is.
best case ive owned so far (ive said this about all my case's) and will probably keep this for quite a while now.
actually it's the first coolermaster case ive owned and very surprised at how good it's made.
i thought my antec p190 was well made and think it's on par with the haf-x.
One quick thing, i know you mentioned a fan controller above but that seems to have a lot of wiring? is there any easier to set up ones for about £30-50?
Thanks for comments again, i think i'll get 2 Megaflows fitted on the top.
Acemodder why does Ocuk not stock these fans?![]()
