I've just fitted this on the asus sabertooth P67.
Fits perfectly using the 1156 connections. Exactly the same as 1155
Misleading here.
You need to distort the rear bracket to line the holes up correctly.
Bit like:
o----o
o---o
It is pliable and will bend, but the screws become tight as the plate attempts to re-align itself.
This is on the P67 Sabertooth B3.
Misleading here.
Bit like:
The bracket doesn't need distorting at all, it fits perfectly. If yours was distorted something can't be right.
Well its on and will pass the test but its not right. It should be a perfect fit and its not. Tried always but its on and is firm and flush to processor so all good.
Thanks all.
