**Official Sapphire Sapphire ATI Radeon HD 5850 Extreme 5850 Extreme Owners Thread**
Have mine up and running, very impressed with it, it fits very nicely in my Shuttle and takes less power than I thought since the PS fan doesn't spin up under load anymore.
Haven't done much testing but it is quite cool and quiet and a nice upgrade from my old 1950.
hi
you need to overclock that quad pohly . try to get it past 3gz if poss and you will notice a difference
cheers
What size screen? The 5850 is much, much faster than a 4850
its on a 1920*1080 24". i however now seem to think that it may be falty and unstable because if i run any graphics intensive programs the screen gose black or blue screens (only blue screended once)
guys, im building my first machine, do i need to use the disc or will windows 7 auto detect and download the latest drivers? thanks
5850 extreme btw :p
5850 extreme btw :p
Probably worth downloading the latest drivers from AMD site, but windows will automatically install the basic drivers for it to work.
5850 extreme btw :p
The disk that came with mine had old drivers on, use the current from AMD.
no, mine is going back doa :( . started fine tried cod 4 then turned off never to come back on :confused:tried two other cards fine :(
Ok no worries.. Do these squeel or have cap whine either 5830/5850...?
I've found that about after three hours of gaming my 5830 seemed to have some issues with sound, Nothing I can hear over my crappy headset/ speakers mind you. Other then that when it isn't idle it is whisper quite.
