920 @ 4GHz 40/80c - ok?
26 Jan 2011
It has got quite a bit warmer now and my computer has seemed to have risen 5c, although I have up the speed of all fans in my HAF X.
I'm clocked @ 4GHz running around 40c idle and 80c under full load with Prime95.
A week or so ago it was 5c under these stated values.
Should I worry about this at all? Perhaps drop a couple of clicks down?
My vCore is at 1.24 using a Coolermaster air cooler, not sure which as borrowing of my cousin...
80c is fine when running stress apps, normal usage wont push it that high. Also seeing a rise of 5-6c on my cpu and gpu's in the last few days.
The temps are fine, mine idles at 35-40c (low rpm fans) loaded is 60-70c (dependent on what rpm on my fans i use).
Also the ambient temps have risen abit the past few days its getting warmer, easy fix, open the windows and stop using the heating in the house lol.
