Is my thread illegal.
17 Jan 2006
Dundee
I have had a comment made by a fellow member that states my sig here is illegal.
I have used this sig for several years now without a problem. Is my leg being pulled or does it contravene some rule that I am unaware about? :confused:
What is the signature for? [edit your profile]
You may use a signature (commonly used in email messages) in your posts. You can specify in your profile a signature to use at the bottom of your posts. When you post, there is an option to use your signature.
A signature may contain one or more images but they must fit within a box with maximum dimensions of 400 x 75 pixels (width x height) and with a maximum (combined) file size of 20k. Images containing mostly very large words or animated .gifs will not be permitted. You may also add 1 consecutive lines of normal or smaller text directly above or underneath the image with no spaces inbetween image and text.
If no images are used then up to 4 consecutive lines of normal or smaller text is permitted. Do not pad out your text lines with blanks lines. A line of text is defined as having a maximum length of 400 pixels. If you want to turn the signature off in the future, you can come back and edit your post. If you have specified a signature in your profile, the box will be automatically ticked for you.
The forum Dons/Admins reserve the right to judge individual signatures, particularly those deemed to contain material of an adult or offensive nature. If the Dons/Admins think the signature is unsuitable for a family orientated forum, then it will be removed. If the user then replaces it without making changes, they will be suspended.
It may be the 3 blank images under it?
This thread is just unbelievable; you're going to jail!
(I think the problem is that you have a link to your business in your sig, albeit just a contact e-mail)
FAQ:OcUK would like you and your whole family to learn and share via our forums. For this reason swearing and the posting of "adult" or offensive material is forbidden.
There you go. Most people find Dundee United offensive. :p
My first question is why do you have four links to images that all appear to be the same in your signature?
Do you want me to fix it?
[edit]Fixed it for you, vastly simplifying the code in there.
If you need any of the code still for any reason let me know, I took a copy.
