I did the Verzasca dam jump in August '09. It was absolutely mind blowing. Beautiful part of the world too. I stayed in Locarno which is a place I want to go back to if the opportunity arises.
Interlaken has loads of things to do. Canyoning, hang gliding, hiking, trotti biking, mountain biking, big lakes, skydiving etc. Quite expensive but fancy saving up and going back to do a lot of the stuff there.
I did the Macau Tower at 233 metres and would do it again in a heartbeat, I want to do this dam also however. Looks awesome
I had never done a bungy before, did a 50M crane one then the Macau a few weeks later. Seeing as you are so close just do it, but don't think about it when it comes to jumping...just lean forward and let mavity take over when the countdown stops You know you want to
I jump from 15000ft but would be a bit scared to bungie next to a dam. I always think the wind will blow me into the wall and scrape my face off on the way back up.
Not to put a downer on it but the jump I did in Phuket had a 100% safety record for the operator also. Someone went face first into the water on the exact same jump and ended up in hospital a few years prior to my jump.
Have an accident? Change the operator, retain 100% "record".
Check the place and the operator out I would say, 100% means sweet FA
