I have 8gb of XMS3 - IS this okay for Sandybridge?
26 Dec 2005
Paisley
Im considering upgrading my i5 @ 4ghz bundle for a a 2500k or 2600k setup, would i still be able to use the same ram or would this need changing as well?
If I went for the i7, would i need to only use 6gb to get the best benefit for triple channel?
Triple channel is only on the X58 i7s, not the newer P67
+1
Your existing dual channel ram should be fine in a sandy bridge board. Just check what the operating voltage ranges are for your modules - as you should be running memory at ~1.55V with a SB system, compared to 1.65V for nahalem.
Like others have said, you don't need triple channel for P67, only for X58. So in that way, your RAM will be fine.
But I imagine that it is 1.65v RAM if you're using it with an i5-7x0, and I have heard that there are problems when using 1.65v RAM with P67 - I know some people have had problems getting the motherboard to recognize their 1.65v XMS3 properly.
Like others have said, you don't need dual channel for P67, only for X58. So in that way, your RAM will be fine.
Dont you mean triple channel :P
Is it really an issue having non 1.5v RAM?
I have bought 8GB of XMS3 (1.6v-1.65v rated) and am wondering if this will be an issue on my i5 2500k and MSI P67a-G45 now :S I got it because it's the only RAM I could see that would have height clearance due to the Zalman cpu cooler!
i've got 8GB XMS rated 1.6v - 1.65v and i've had no issues once I enabled XMPP in bios (to stop a double cold boot issues prone to all P67 boards).
I've got the same set in my p67 and it's fine.
Went into the bios, changed settings to 1.5v, 1600MHz, set timings at 9-9-9-24 and that was it.
No issues at all.
Excellent thanks :)
I assume no funny business before setting the profile? Other than the dual boot from cold issue which the P45 has had before too.
No, absolutely fine. 1st time boot into the bios and away.
Not sure about the cold boot issue as I changed the settings straight away and didn't notice it on the 1st boot.
It double boots, Intel chippy mobos have done this for some time where you cold boot, it turns off before POST then a few seconds later it boots up normally. I think people called it the infamous "Double Boot".
My Gigabyte UD3P did this :p
