White specs all over car
14 Aug 2004
Hi all. I got a car a few months back and noticed that it has white specs all over the boot and roof of the car. I tried using some polish which seemed to dim the marks but does anyone know how I can remove them?
ta.
edit: photo's now added:
Sorry for the angles but it was sunny and I couldn't see proper lol.
would this work? my dad said that the white specs look like the red paint had worn away on the car but I don't believe this.
get some photos.
We can't tell from purely text if this is something ON the paint, or if its where the paint has been removed revealing the undercoat.
So the whiteness is actually underneath the paint?
Primer is usually a whitish grey colour so it may be that.
How old is the car?
Could have been worse, your wife could have tipped paint on it :D
is it smooth to the touch, or when you rub your finger over it can you feel something on top of the paintwork ?
As already said it looks like the lacquer is failing.
The only way you are going to fix that is with a respray. In fact I have to wonder if it's not already had one, and someone's not done a very good job of it.
