Just imagine the cooling power of that heatsink. 12 Heatpipes and 4 x 100mm fans. It would be seriously top end. I really don't think you should compare the Corsair coolers against a behemoth such as this.
Bigger = Better.
Looks like they've given it some elevation to not foul on memory and such sticky out motherboard components but it's probably going to be too high to fit most cases. The smaller heatsink seems to be quite a bit smaller though and seems a bit of a waste when you consider the top 6 heatpipes would only get their heat once the bottom heatpipes have taken the heat up to their array.
I think users will want to use some form of metal bracket to ensure this thing stays in place.
I don't think I would be buying one though as it would probably foul up on my 8 heatpipe graphics cooler. You see Bigger is always better.
