Just wondering what typical load temperatures were with automated fan control (i.e. out of the box).
I'm getting 82-84 C during 100% activity gaming, I have actually another 6950 on the way for crossfire however the cards will have to sit right next to each other, I usually when at uni have the fans set to 60% because the noise doesn't bother me and then the card usually is in between 60 and 70C.
Do you foresee any problems? I'm going to use a fan profile so that by the time the cards get to 80 the fan speed will be at 55% increasing to 60% at 85.
If i'm honest anything past 60% is far too loud, when gaming it's usually not an issue due to speakers/case fans/headphones but anything past 60% and I will probably be able to notice it a lot.
I read somewhere that up to 102C is considered 'safe' but it's obviously not ideal, what sort of temps should I be limiting the cards to?
Maybe to reduce temps I should flash back to 6950s? :/
