Double Cat5 network cable?
23 Dec 2009
RG8 9
Hi chaps
I have the router for my house in my PC room, as the main phone line runs into it. I also have a network cable running into another room, where it is connected to another PC. This room has now got another PC as it is being used as an office.
I really don't want to be running another cable through the house so am wondering if you can buy a single cable, with two connectors at both ends? Wireless is not an option either.
I have tried looking but am getting nowhere, though it is first thing on a Monday morning and I am knackered.
Cheers. :)
The cable is quite long though. From my room to the other one is about 10 metres. I am a bit of a networking nub, so would your idea still work?
If so, any cheap recommendations?
That's not "quite long" in ethernet terms ;)
100 meters is (give or take) the maximum cable run without repeaters.
if your handy with a pair of rj45 crimps, remove the old terminal and recrimp the cable with two terminals as only 2 of the 4 pairs are needed for an ethernet cable
You can also get connectors both ends that will give you 2 RJ45 both ends of a single cable. Personally I'd just get a small switch.
That idea has problems written all over it. I would not trust myself at all. :)
Please excuse my stupidity, but I can plug the long (ish) cat5 cable from my router that goes into the other room into this box, then run another short cable to the second pc in there? So basically the box splits it? If so, I am sold!
Simple solution surely, just buy a 4-port, 5-port, or 8-port switch and two short network cables?
The best solution for this scenario. This means more machines can be added at a later date if needed for a very cheap solution.
This is fine. Sold.
TPlease excuse my stupidity, but I can plug the long (ish) cat5 cable from my router that goes into the other room into this box, then run another short cable to the second pc in there? So basically the box splits it? If so, I am sold!
You need two short cables (one for each PC from the switch), as the existing cable will just connect the switch to your router ;)
You can get Y splitters for less than a quid specifically for this purpose. You can carry 2 connections over one length of cable as they only need 2 pairs each.
I'm pretty sure you'd limit each connection to 10meg half duplex though which would be a bit poo.
Well, if you don't want to cut anything you can buy premade rj45 splitters on a popular auction site for 99p each delivered - you'd need two of them though, plus four short bits of cable (two go into the router, two go to your PC's in the office) This has the limitation of only supporting 100Mb/s connections on each connector, rather than a full gigabit. It does work though and if you only need 100Mb it's a cheap way of doing things, easily doable for under £5.
The most futureproof solution is to pick up a switch, which is installed as you think (long cable goes between the router and switch, then your office PC's connect to this) It's a little more expensive, but will allow for gigabit connections, and let you easily put more devices in your office in the future.
+1 for the switch
and for 15 quid man i might get one and get rid of me old one 10/100 switch lol cheers for the link to it 3dcandy
+1 for the switch
Hey no worries...it's been mentioned as a decent cheap switch on here before...seems a good enough spec, includes power save etc.
Thanks for all the replies chaps.
I would like to do this as cheaply as possible.
My internet connection into the property is pretty dire anyway (less than 2meg). I managed earlier this year to double the download speed by a simple firmware update and a BT Broadband Accelerator, all of which were advised and linked on here.
The good thing is that the office is unlikely to grow by more than 2 PC's. The connection speed from the office is not of paramount importance as the PC's are only really using the connections for email, and occasional windows updates, though these are rare as they are both on XP. All of this is done during the day when I am at work as well so when I get home, it is only my PC connected.
Will the splitters be ok for email only? I assume so?
Thanks again.
Ok I have been reading on the pre-made splitters and even though they are cheap, I think I will go for the box linked in this thread, and a short length of cable.
Any cheap half decent ones on OcUK? If someone can link me will purchase today. :)
