Do it yourself ,its very easy to do .
Take off the warranty sticker using a hairdryer so you can re-apply it after you fix it . Then take along to your local game / gamestation and trade it in for a new one .
The YLOD fix isnt permanent full stop - i fixed mine as per ?Gilskys guide on youtube and tbh it lasted only a few minutes. Then did the hairdryer trick and it worked long enough for me to get all my save games etc off and take it to gamestation and a play test there to trade it in.
If you cant be bothered to take it apart then at least try the hairdryer trick. Worth a shot even to get a disk out the drive.
