- 1 Jun 2010
- Bedford
Many thanks again xsistor
Your insight has most definitely been helpful in gaining better understanding of how processors process Floating point operations aswell as integers.
Lastly with regards to speeding up the floating point division, you are right in saying there are some methods which exist. I think one of the method is division by reciprocal method which makes it easier to process such division calculations and thus speed up the process.
Many thanks again
you have to add forward-slash before youtube in the 2nd bracket and it will come e.g [/MEDIA] and the number in between is the one you copy and paste aftwer watch?=
Just click quote on my post and you will see how it is typed.
.Your insight has most definitely been helpful in gaining better understanding of how processors process Floating point operations aswell as integers.
Many thanks again
So that's what I did wrong I put the whole link between the tags.
