Microwave problems
18 Mar 2008
My google fu skills are lacking today. I've tried but to no avail. Microwave is making a crackling sound, and doesn't actually heat up my food.
So basically it's broken and making weird noises. I don't know why I'm making this thread, I'll inevtiably have to get a new one, but I'm posting just in case someone happens to know a fix.
Also I'm very hungry :p
Oh and obligatory: RIP guys :(
I'm just going on the little that I know about microwaves, but you should get rid ASAP. If its leaking it can be very dangerous, don't use it again, and buy a new one, they are fairly cheap so not really worth fixing.
I had something similar. Fixed it by putting a jar of mustard in at 800W (or as high as the microwave allows) for 20 minutes.
Should clear up any problems :)
Thanks guys :p
Yep, new microwave for me then.
^I would do the mustard thing, but I don't wanna risk it. I already used up most of my mustard by spreading it on my cpu. Apparently it helps you achieve an extra 300mhz overclock?
Move any magnets away from it.
I don't think there's any magnets near it.
Yea cos DIY on magnetrons isnt dangerous at all ;)
Get a new one.
Edit:
The noise its making isnt like a "whirrrrrrrrrrrrrrr >> (5 mins later) >> ding!" is it? I think that's normal.
Whatever you're trying to heat up will do just as well on the hob. Don't play with borked microwaves, they can be a little nasty if they wanted to be. I had one bite my finger.
I have worked in a Microwave factory at the quality assurance department for over 20 years and have seen many Microwaves in my time. If you send me your name, address, and pictures of the microwave I will be able to sort out some repair info for you.
I have worked in a microwave factory at the quality assurance department for over 20 years, if you send me your name, address, and pictures of the microwave I will be able to sort out some repair info for you.
I am actually Strife's boss and he shouldn't be giving out advice on a public forum. Just send me your bank details, pin numbers etc and I will sort this out at BetFair's end.
