What gear?
I can do 6500rpm in 3nd at 80mph.
I'd have thought the 1.6 Focus would be higher up the rev range than my car, so I'd say more like 3.5-5k for 60-80...it tops out at 115 and has 98bhp, so somewhere around there I'd guess.
3nd, eh?
In my 1.6 MK1 the rpm while in 5th is at exactly 3K when doing 70mph. I'm guessing if your doing 80mph then it will probably sit just under 3.7K rpm.
Liam
I find a lot of what people are saying quite hard to believe. Unless it's an overdrive, the people doing 3k at 70 will be hitting peak power at around 140mph, which for a 1.6 fails a sanity check.
I'm going to find the published gear ratios and work this out when I'm not on the iPhone.
