Expertool Advice
4 Apr 2011
Hello,
i got my Gainward GTX570 Phantom today and its a very good looking card and idle temps are around 30 to 31 degrees and soooo quiet but havent played anything yet, been v busy.
Anyway should i use Expertool or EVGA Precision which i currently have installed and just used for fan control ? i cant decide and know nothing about overclocking either . What would you guys suggest ?
Thanks. ;)
Don't use ExperTool, it's a pile of Junk. I use to use it and then realized it's about as much use as a trapdoor on a canoe.
EVGA Precision is a good choice or MSI Afterburner. Both are pretty good and AFAIK support your card very well. - OH; and read an overclocking guide for GPU's ;]
While it's not the same as your card, Afterburner principles are covered here.
Thanks for the links but i think i'll leave the card as it is and just increase fan speed if needed. For the sake of a few extra fps i dunno if it worth messing with my phantom just in case ! I dont even like to OC my X9650 and thats made for it !! LOL ;)
