It looks like a decent monitor - but not much better than the 223BW. Its the same TN panel type, same size, similar responsiveness and same 1680x1050 resolution.
If you are buying something new you may want to consider a larger 1920x1080 resolution monitor, try out 120Hz or go for an IPS.
May I ask what your budget is?
