Hey guys!
That time of week when we slash prices to help save you money whilst building your dream pc.
Intel Core i3 550 3.20GHz (Clarkdale) (Socket LGA1156) - Retail @ £94.79 inc VAT
The wait is over - now everyone can move up to smart performance. As the first level in Intel’s new processor family, the new 2010 Intel Core i3 processor is the perfect entry point for a fast, responsive PC experience. The new 2010 Intel Core i3 processor also features Intel Hyper-Threading Technology, which enables each core of your processor to work on two tasks at the same time, delivering the performance you need for smart multitasking. Don’t let too many open applications slow you and your PC down. Get smart performance now.
- Lithography Process: 32nm
- Cores: 2
- Threads: 4
- Frequency: 3.20GHz
- Integrated Graphics Frequency: 733MHz
- Cache: 4MB Shared L3
- Memory Controller: Dual Channel DDR3 800/1066/1333MHz
- TDP: 73w
- Socket: LGA1156
Was £104.99 Inc. VAT
Only £94.79 inc VAT.
ORDER NOW
Intel Celeron Dual Core E3400 "LGA775" 2.60GHz (800FSB) - Retail @ £33.59 inc VAT
Take basic computing to new levels with the Intel® Celeron® dual-core processor. Because many software applications for everyday tasks are now designed for dual-core processors, users can be more creative and productive in the home, office, or classroom. In addition, security and virus protection often means running more than one application at a time, and the Celeron dual core processor has the power to run them simultaneously. Based on energy-efficient micro architecture, the Celeron dual-core processor delivers superior energy-efficient dual-core performance.
- Dual Core Technology
- 2.60GHz clock speed
- 1024MB L2 Cache
- Cooler running technology, less heat and less noise!
- Supplied with Intel referance heatsink & fan
Was £36.98 Inc. VAT
Only £33.59 inc VAT.
ORDER NOW
Intel Pentium Dual-Core E6500 "LGA775 Core 2" 2.93GHz (1066FSB) - Retail @ £59.99 inc VAT
Do extraordinary things with everyday computing when you multitask your favorite music, photo and office applications with a PC running the Intel Pentium dual-core processor. Expand your computing options with two processing cores. And you’ll enjoy that performance with a minimum of power and noise. Enhanced Intel SpeedStep Technology allows your system to dynamically adjust processor voltage and core frequency, enabling decreased power consumption and heat production. And since less heat means less fan noise, you’ll also experience improved acoustics. Plus, you get the protection of built-in Execute Disable Bit designed to help keep your PC safe from viruses, worms and other malicious attacks.1 And with proven Intel technology, you get a level of quality and reliability only the leader in processors for desktop computing can provide.
- Core2-based CPU
- 2.93GHz clock speed
- 2MB L2 Cache
- Intel Speedstep Technology
- EM64T 64-Bit Technology
- Execute Disable Bit
Was £64.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Intel Core i5-2300 2.80GHz (Sandybridge) Socket LGA1155 Processor - Retail @ £137.99 inc VAT
Intel's new Sandybridge based CPU's is a complete new refresh that requires new socket LGA1155 mainboards. This new platform uses less power and has vastly superior integrated graphics. The HD2000 graphics is capable of all multimedia task featuring DirectX 10.1 runtime making them ideal for gamers too. The K series edition processors are unlocked on the multiplier allowing overclocking and also feature HD3000 onboard graphics which feature twice the horsepower of the HD2000 making them ideal for gamers and have support for 3D Gaming. The new Sandybridge K series processors also feature immense overclocking as well.
- Lithography Process: 32 nm
- Cores: 4
- Threads: 4
- Frequency: 2.80 GHz (Turbo Mode 3.10GHz)
- Integrated HD 2000 (6 EUs) Graphics
- Integrated Graphics Frequency: 850MHz (1100MHz Turbo)
- Cache: 6 MB shared L3
- Memory Controller: Dual channel DDR3 800/1066/1333/1600 MHz
- TDP: 95W
- Socket: LGA1155
- Compatible with Socket 1156 heatsinks
- 3yr Warranty
***OVERCLOCKING GUIDELINES***
- Do not exceed 1.35-1.38v core voltage, doing so could limit lifespan of the CPU
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
Was £147.98 Inc. VAT
Only £137.99 inc VAT.
ORDER NOW
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor @ £167.99 inc VAT
- Unlocked Multiplier
- Cores: 4
- Threads: 4
- Frequency: 3.30 GHz (Turbo Mode 3.70GHz)
- Integrated HD 3000 (12 EUs) Graphics
- TDP: 95W
- Socket: LGA1155
- 3yr Warranty
Was £179.99 Inc. VAT
Only £167.99 inc VAT.
ORDER NOW
Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor @ £239.99 inc VAT
- Cores: 4
- Threads: 8
- Frequency: 3.40 GHz (Turbo Mode 3.80GHz)
- Integrated Graphics Frequency: 850MHz (1350MHz Turbo)
- Cache: 8 MB shared L3
- TDP: 95W
- Socket: LGA1155
- 3yr Warranty
Was £263.99 Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
AMD Phenom II X4 Quad Core 955 Black Edition "125W Edition" 3.20GHz (Socket AM3) - Retail @ £95.99 inc VAT
The AMD Phenom II processors are the most advanced processors for true multitasking offering true quad-core design. AMD Phenom II processors deliver virtually uninterrupted information flow between processor cores, main memory and graphics and video accelerators for amazingly rapid system response and phenomenal system performance. AMD Phenom II processors deliver unbeatable multi-core value with superior high definition computing, advanced multitasking performance, and innovative, energy efficient solutions.
- 3.20GHz clock speed
- 2MB L2 cache
- 6MB L3 cache
- DDR3-1333 support
- 45nm process technology (125W Edition)
- True Multi-core Processing
- Direct Connect Architecture
- Integrated Dual-Channel Memory Controller with up to DDR3-1333 support
- HyperTransport 3.0
- AMD Balanced Smart Cache
- AMD Wide Floating Point Accelerator
- AMD Memory Optimizer Technology
- AMD Digital Media Xpress 2.0
- AMD Virtualization with Rapid Virtualization Indexing
- Cool‘n’Quiet 3.0 technology
Was £99.98 Inc. VAT
Only £95.99 inc VAT.
ORDER NOW
AMD Phenom II X4 Quad Core 965 Black Edition "125W Edition" 3.40GHz (Socket AM3) - Retail @ £107.99 inc VAT
- 3.40GHz clock speed
- 2MB L2 cache
- 6MB L3 cache
- DDR3-1333 support
Was £114.98 Inc. VAT
Only £107.99 inc VAT.
ORDER NOW
Corsair Vengeance 6GB (3x2GB) DDR3 PC3-12800C8 1600MHz Triple Channel Kit (CMZ6GX3M3A1600C8) @ £89.99 inc VAT
CORSAIR high performance Vengeance memory module 6GB (3x2GB) 1600MHz 8-8-8-24, CL8, 1.5V for motherboards using Intel triple channel processors. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each three module set is tested at 1600MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 8-8-8-24 on Intel X58 DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 8-8-8-24 values at 1600MHz, 1.50V
- 6144 Megabytes of DDR3 memory
- Three matched 2GB modules
- 100% tested at 1600MHz in X58-based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
Was £94.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
GeIL 6GB (3x2GB) DDR3 PC3-12800C8 1600MHz VALUE PLUS Triple Channel (GVP36GB1600C8TC) @ £47.99 inc VAT
GeIL announces the launch of the all new DDR3 Value PLUS & Ultra PLUS Series to be added to GeILs’ high performance memory line of products. The Value PLUS & Ultra PLUS are equipped with the latest PLUS Edition memory heat-spreader designed with heat-sink surface and extended height for maximum cooling efficiency. The Ultra PLUS line of memory will be carrying over-clocking performance while the Value PLUS line has the more stability-oriented specifications. As GeILs’ quality standard, both series will be enhanced with DBT – Die-hard Burn-in Technology for the highest quality assurance.
- PC3-12800 1600MHz CAS 8-8-8-28
- 240pin, Non-ECC, Un-buffered DDR3 DIMM
- Aluminum Heat-spreader
- 6 Layers Ultra Low Noises Shielded PCB
- 1.5V-1.6V Power Supply
- Lifetime Warranty
- DBT - Die hard burn-in technology (Improved reliability)
Was £53.99 Inc. VAT
Only £47.99 inc VAT.
ORDER NOW
G.Skill RipJawsX 4GB (2x2GB) DDR3 PC3-17000C9 2133MHz Dual Channel Kit (F3-17000CL9D-4GBXL) @ £47.99 inc VAT
G.Skill has announced the development of its brand new RipjawsX series memory modules, designed specifically for Intel Sandy Bridge LGA1155 processors, and H67 and P67 motherboard platforms. The new RipjawsX series consists of a complete range of memory solution, from DDR3 1,333MHz, 1,600MHz, 1,866MHz, 2,133MHz, 2,200MHz to 2,300MHz. Combined with the Intel’s highly anticipated Sandy Bridge platform, G.Skill RipjawsX series memory kits deliver more bandwidth and performance than ever.
Building on the strong success of the first generation Ripjaws brand in performance memory kits, every single RipjawsX memory kit is hand-tested on an Intel Sandy Bridge platform in accordance with G.Skill's strict internal testing procedure, to ensure the best in class performance, compatibility and reliability across a range of popular motherboards. It is the perfect memory solution for PC gamers, performance workstations, enthusiast power users and anyone who loves the cutting-edge of technology!The following list shows the detail specifications of G.Skill RipjawsX family.
Model Name: F3-17000CL9D-4GBXL
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL P67
CAS Latency: 9-11-9-28 2N
Capacity: 4GB (2GBx2)
Speed: DDR3-2133 (PC3-17000)
Test Voltage: 1.55-1.65V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)
Master Pack Weight: 0.26 lbs
Black PCB
Warranty: Lifetime
Was £49.99 Inc. VAT
ORDER NOW
OCZ Special OPS 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (OCZ3SOE1600LV4GK) @ £35.99 inc VAT
Featuring the high densities and stability gamers demand, these DDR3 kits are ideal for users advancing to the next generation of memory platforms, offering the speeds, density, and reliability required for the latest DirectX 10 PC titles. Featuring a unique camouflage motif heatspreader design, the DDR3 Special Ops Edition Series was designed for gaming systems in need of a reliable upgrade as well as some extra style.
The PC3-12800 SOE is available in 4GB low-voltage qualified dual channel kits for the high densities demanded by graphic-intensive games, operating systems, and applications. The Special Ops Edition is the ideal solution for gamers who need high density options in addition to superior reliability and bandwidth management without the hefty price point. These modules offer the stability and speed to give gamers the performance edge with a highly reliable, future-proof system that takes advantage of all high-speed DDR3 has to offer.
100% Hand tested for quality and the unbeatable lifetime warranty will contribute to your peace of mind during even the most intensive gameplay!
Specification:-
- 1600MHz DDR3
- CL 8-8-8-24 (CAS-TRCD-TRP-TRAS) (1.55v-1.65v)
- CL 9-9-9-24 (CAS-TRCD-TRP-TRAS) (1.45v-1.55v)
- Available 4GB Dual Channel Kits
- Unbuffered
- Special Ops XTC Heatspreader
- Lifetime Warranty
- 1.55-1.65 Volts
- 240-Pin DIMM
Was £37.99 Inc. VAT
Only £35.99 inc VAT.
ORDER NOW
HIS ATI Radeon HD 6990 4096MB GDDR5 PCI-Express Graphics Card @ £479.99 inc VAT
Designed for the power gamer, AMD Radeon HD 6990 graphics cards include AMD's second-generation, Microsoft DirectX 11 capable architecture, advanced image quality features for the best looking games, and AMD PowerTune intelligent technology to enable higher clock speeds and faster gaming. The AMD Radeon HD 6990 offers the ultimate in immersive HD gaming and computing with native support for up to five displays using AMD Eyefinity multi-display technology, with six display support possible via DisplayPort 1.2 components available for purchase later this year. The AMD Radeon HD 6990 graphics cards also feature a dual-BIOS toggle switch, allowing enthusiast gamers to unlock the card and rev up the clocks and voltages for even more performance. Finally, AMD HD3D technology provides a cutting-edge stereoscopic 3D gaming and movie experience, thanks to HDMI 1.4a support.
Features:-
- Core Clock: 830MHz (880MHz OC Mode)
- Memory: 4096MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Bandwidth: 320GB/sec
- Processing Cores: 3072
- Texture Units: 192
- ROPS: 64
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual-Link DVI & 4x Mini-Display Port (Adapters supplied to HDMI/DVI)
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 450W (Typical 400W)
- 2x 8pin PCI-E power connectors required
- 700W minimum PSU required (1000-1200W recommended for Crossfire with with four 8 Pin connectors)
- Warranty: 2 Years
Was £499.99 Inc. VAT
Only £479.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 6950 2048MB GDDR5 PCI-Express Graphics Card @ £203.99 inc VAT
The Sapphire HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- ATI Reference Design (Revision: 1) - Flashable too 6970
- Core Clock: 800MHz
- Memory: 2048MB GDDR5
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- ATI Avivo HD
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required (Power Adapters Provided)
- 450W minimum PSU recommended
- Warranty: 2 Years
- Supplied with Mini-DisplayPort too HDMI Cable
- Supplied with 1.8M HDMI High Speed Extension Cable
Was £211.99 Inc. VAT
Only £203.99 inc VAT.
ORDER NOW
HIS ATI Radeon 6950 1024MB GDDR5 PCI-Express Graphics Card @ £173.99 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- Memory: 1024MB GDDR5
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- 2x 6pin PCI-E power connectors required (Power Adapters included in box for older PSU's)
- Warranty: 2 Years
Was £187.99 Inc. VAT
Only £173.99 inc VAT.
ORDER NOW
XFX ATI Radeon HD 5850 1024MB GDDR5 PCI-Express Graphics Card ***Supplied Assasins Creed Game*** @ £119.99 inc VAT
Prepare to experience a riveting high-definition gaming experience with the ATI Radeon HD 5800 Series graphics processors. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
- Core Clock: 725MHz
- Memory Clock: 4000MHz (Effective)
- Memory Bandwidth: 128.0GB/s
- Processing Cores: 1440
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 1 DisplayPort
- HDCP Capable
- OpenGL 3.2 Support
- ATI CrossFireX Ready
- ATI Avivo HD
- 2yr Warranty
Was £124.99 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
HIS ATI Radeon HD 5570 1024MB GDDR3 SILENT PCI-Express Graphics Card (H557HO1G) @ £45.59 inc VAT
The HD 5570 packs 400 Stream processors and is fully compliant with Microsoft's DirectX 11 API, enabling the highest quality effects available on the PC platform today, as well as accelerating ATI Stream compatible applications including a variety of video transcoders and media players to ensure the best possible media viewing experience. Built on an ultra low power 40nm core technology, no additional power connection is required, making the HD 5570 series ideal for system upgrades or mainstream PCs that do not have expensive, high end power supplies.
- Core Clock: 650MHz
- Memory: 1024MB GDDR3
- Memory Clock: 1000MHz (Effective)
- Memory Interface 128 bit
- Processing Cores: 400
- Display Connectors: 1 VGA, 1 Dual-Link DVI-I & 1 HDMI
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Product Code H557HO1G
EAN Code 4895139004465
Cooler Heatsink
GPU 5570
Core Clock 650 MHz
Memory Clock 1000 MHz
Memory Size 1042 MB
Memory Type DDR3
Interface PCI Express x16 (PCI Express 2.1)
Was £49.99 Inc. VAT
Only £45.59 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 590 3072MB GDDR5 PCI-Express Graphics Card with FREE Gaming Mouse @ £575.99 inc VAT
Introducing the new NVIDIA® GeForce® GTX 590 - the most powerful DirectX 11 graphics card ever built. With a sleek exterior that houses dual 512-core GTX 500 GPUs and a custom vapour chamber cooler, the GeForce GTX 590 delivers high-end performance with style. Hook up three monitors with GeForce GTX 590's three dual-link DVI ports to play your favourite games at ultra-wide resolutions like 5760x1080 in NVIDIA Surround. Plus get all the premium GTX gaming technologies such as NVIDIA® 3D Vision™, PhysX®, and Quad SLI® for the ultimate PC gaming experience.
The GIGABYTE M8000Xtreme is a super powerful weapon designed specially for gamers. Equipped with 6000dpi pro-laser engine supports high-speed movement and accurate precision. The onboard GHOSTTM Engine memory is capable of 45 button assignments with macro editing and storing customizable macros that lets you bring your unique settings wherever you go - use them on other PCs without software. The Advanced GHOSTTM Engine software allows gamers to record and edit their
desired scripts which can include complicated keyboard and mouse commands. The Introduction
design concept of the GHOSTTM Engine software is Avatar system based, just like in games. Its Ultra-user-friendlyTM drag and drop structure user interface plus powerful macros on the go will equip any gamer to be competitive in the heat of battle.
- Graphics Engine: GeForce® GTX590
- Bus Standard: PCI Express® 2.0
- Video Memory: 3072MB GDDR5
- Engine Clock: 607 MHz
- CUDA Cores: 1024
- Memory Clock: 3414MHz (855MHz GDDR5)
- Memory Interface: 384 bit x 2
- DVI Max Resolution: 2560 * 1600
- DSub Max Resolution: 2048 * 1536
- D-sub Output: 1 x via DVI-to-D-Sub adapter
- DVI Output: 3 x Dual Link DVI-I Native
- HDMI Output: 1x HDMI via DVI-to-HDMI adapter
- Display Port Output: 1x Mini DisplayPort Native
- HDCP compliant: YES
- Dimensions: 11” x 4.5”
- 3yr Warranty
IMPORTANT: The supplied Geforce Drivers 267.52 for Geforce GTX 590 will not stop the card from overheating when overclocking. Please use newer versions from the Nvidia website and stay away from 267.52.
Was £599.99 Inc. VAT
Only £575.99 inc VAT.
ORDER NOW
OcUK Value GeForce GTX 460 1024MB GDDR5 PCI-Express Graphics Card @ £119.99 inc VAT
Built from the ground up for DirectX 11, GeForce GTX 460 delivers the ultimate next generation gaming experience. With up to 4x the DirectX 11 tessellation performance of the competition, GTX 460 packs highly detailed visuals into your games - without sacrificing high frame rates. And with NVIDIA 3D Vision, PhysX, and CUDA technologies, GeForce GTX 460 powers all the incredibly realistic effects that your games can throw its way.
- Core Clock: 675MHz
- Memory Clock: 3600MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 336
- Shader Clock: 1350MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 1x VGA, 2x Dual-Link DVI-I & 1x HDMI 1.3a
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 2 Years
ORDER NOW
Intel 320 Series 40GB 2.5" SATA-II 25nm Solid State Hard Drive - Retail @ £71.99 inc VAT
Intel Solid-State Drives represent a revolutionary breakthrough that delivers a giant leap in storage performance. Intel Solid-State Drives are designed to satisfy the most demanding gamers, media creators, and technology enthusiasts. These new drives bring a high level of performance and reliability to notebook and desktop PC storage, at a fraction of the cost of the previous generation of Intel SSD products. Drawing from decades of memory engineering experience, and new, industry-leading compute-quality 25nm NAND flash memory manufacturing processes, Intel Mainstream SATA SSDs are designed to deliver outstanding performance, featuring the latest-generation native SATA interface with an advanced architecture employing 10 parallel NAND flash channels equipped with multi-level cell NAND flash memory. With powerful Native Command Queuing to enable up to 32 concurrent operations, Intel Mainstream SATA SSDs deliver higher input/output per second and throughput performance than other SSDs on the market today - and drastically out-perform traditional hard disk drives. These drives also feature low write amplification and a unique wear-leveling design for higher reliability, meaning Intel drives not only perform better - they last longer.
- Capacity: 40GB
- Controller: Intel
- Read: Up to 200MB/sec
- Write: Up to 45MB/sec
- NAND Flash: 25nm Multi-Level Cell (MLC)
- Interface: SATA-II
- Low Power Consumption
- Lightweight (80g)
- Shock Resistant
Was £76.79 Inc. VAT
Only £71.99 inc VAT.
ORDER NOW
Intel 320 Series 80GB 2.5" SATA-II 25nm Solid State Hard Drive - OEM @ £119.99 inc VAT
- Capacity: 80GB
- Controller: Intel
- Read: Up to 270MB/sec
- Write: Up to 90MB/sec
- Lightweight (80g)
- Shock Resistant
Was £131.99 Inc. VAT
ORDER NOW
Intel 320 Series 80GB 2.5" SATA-II 25nm Solid State Hard Drive - Retail @ £131.99 inc VAT
- Capacity: 80GB
- Controller: Intel
- Lightweight (80g)
- Shock Resistant
Was £141.59 Inc. VAT
Only £131.99 inc VAT.
ORDER NOW
OCZ Agility Series 60GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-1AGT60G) @ £65.99 inc VAT
Offering your system the incredible performance of flash-based storage, the OCZ Agility Series delivers the performance and reliability of SSDs at less price per gigabyte than other high speed offerings currently on the market. The OCZ Agility Series is the result of all the latest breakthroughs in SSD technology, including new architecture and controller design, blazing read/write speeds, and 64MB of onboard cache. Designed for ultimate reliability, Agility Series SSDs have an excellent 1.5 million hour mean time before failure (MTBF) ensuring peace of mind over the long term. All Agility Series SSD drives come backed a two year warranty and OCZ’s legendary service and support.
- Capacity: 60GB
- Cache: 64MB
- Read: Up to 230MB/sec
- Write: Up to 135MB/sec
- NAND Flash: Multi-Level Cell (MLC)
- Lightweight (77g)
- Shock Resistant
- RAID Support
- TRIM Support
- OCZ Garbage Collection
- Warranty: 2 Years
Was £69.98 Inc. VAT
Only £65.99 inc VAT.
ORDER NOW
OCZ Vertex 60GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-1VTX60G) @ £74.39 inc VAT
Offering your system the incredible performance of flash-based technology, the OCZ Vertex Series delivers the performance and reliability of SSDs at less price per gigabyte than other high speed offerings currently on the market. The OCZ Vertex Series is the result of all the latest breakthroughs in SSD technology, including new architecture and controller design, blazing 230MB/sec read and 135MB/sec write speeds and featuring 64MB onboard cache. The OCZ Vertex drives feature a durable yet lightweight alloy housing, and because OCZ SSDs have no moving parts, the drives are more rugged than traditional hard drives. Designed for ultimate reliability, Vertex Series SSDs have an excellent 1.5 million hour mean time before failure (MTBF) ensuring peace of mind over the long term.
- Capacity: 60GB
- Cache: 64MB
- Controller: Indilinx Barefoot
- Lightweight (77g)
- Shock Resistant
- TRIM Support
- RAID Support
- Warranty: 3 Years
Was £79.99 Inc. VAT
Only £74.39 inc VAT.
ORDER NOW
OCZ Vertex 2E 60GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTXE60G) @ £98.39 inc VAT
Based on a cutting-edge new architecture, Vertex 2 Solid State Drives raise the bar once again and deliver unprecedented performance for the complete gamut of gaming and professional multimedia applications. OCZ designed the Vertex 2 to surpass the competition where it counts most, pushing the limits in both sequential and random read/write rates. With spectacular performance in 4k file writes up to 50,000 IOPS, these latest drives take productivity to the next level with over ten times the performance of the previous generation. Using the latest controller technology, Vertex 2 not only provides a faster, more responsive PC experience, but promotes cooler, quieter, and more energy efficient conditions compared to traditional mechanical hard drives. OCZ Vertex 2 SSDs come backed by a 3-year warranty and 2 million hour MTBF for ultimate peace of mind.
- Capacity: 60GB
- Controller: SandForce SF-1200
- Maximum Read: 285MB/sec
- Maximum Write: 275MB/sec
- Sustained Write: 250MB/sec
- Max I/O Per Second (IOPS): 50000 IOPS (4KB File)
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Was £101.99 Inc. VAT
Only £98.39 inc VAT.
ORDER NOW
OCZ Agility Series 120GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-1AGT120G) @ £122.39 inc VAT
- Capacity: 120GB
- Cache: 64MB
- Lightweight (77g)
- Shock Resistant
- RAID Support
- TRIM Support
- Warranty: 2 Years
Only £122.39 inc VAT.
ORDER NOW
OCZ Agility Series 250GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-1AGT250G) @ £239.99 inc VAT
Offering your system the incredible performance of flash-based storage, the OCZ Agility Series delivers the performance and reliability of SSDs at a lower price per gigabyte than other high speed offerings currently on the market. The OCZ Agility Series is the result of all the latest breakthroughs in SSD technology, including new architecture and controller design, blazing read/write speeds, and 64MB of onboard cache.
Perfect for notebooks and desktops alike, the Agility Series is ideal for energy-efficient mobile computing to extend battery life, increase the speed of access time, and provide a durable alternative to conventional hard disc drives with superior shock resistance. High capacities and low power consuming NAND flash technology provide the necessary performance and battery life boosts generated by the proliferation of mobile gaming and new ultra-thin laptops.
The OCZ Agility drives feature a durable yet lightweight alloy housing, and because OCZ SSDs have no moving parts, the drives are more rugged than traditional hard drives. Designed for ultimate reliability, Agility Series SSDs have an excellent 1.5 million hour mean time before failure (MTBF) ensuring peace of mind over the long term. All Agility Series SSD drives come backed a three year warranty and OCZ's legendary service and support.
Features:-
- Read: Up to 230 MB/s
- Write: Up to 135 MB/s
- 64MB Onboard Cache
- TRIM Support
- Seek Time: < .1ms
- Slim 2.5" Design
- 99.8 x 69.63 x 9.3mm
- Lightweight: 77g
- Operating Temp: 0°C ~70°C
- Storage Temp: -45°C ~ +85°C
- Low Power Consumption: 2W in operation, 0.5W in stand by
- Shock Resistant up to 1500G
- RAID Support
- MTBF: 1.5 million hours
- Compatible with Mac OS X
Was £249.98 Inc. VAT
ORDER NOW
OCZ Vertex Series 120GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-1VTX120G) @ £122.39 inc VAT
Offering your system the incredible performance of flash-based technology, the OCZ Vertex Series delivers the performance and reliability of SSDs at less price per gigabyte than other high speed offerings currently on the market. The OCZ Vertex Series is the result of all the latest breakthroughs in SSD technology, including new architecture and controller design, blazing 250MB/sec read and 180MB/sec write speeds and featuring 64MB onboard cache. The OCZ Vertex drives feature a durable yet lightweight alloy housing, and because OCZ SSDs have no moving parts, the drives are more rugged than traditional hard drives. Designed for ultimate reliability, Vertex Series SSDs have an excellent 1.5 million hour mean time before failure (MTBF) ensuring peace of mind over the long term.
- Capacity: 120GB
- Cache: 64MB
- Read: Up to 250MB/sec
- Write: Up to 180MB/sec
- Lightweight (77g)
- Shock Resistant
- RAID Support
- TRIM Support
- Warranty: 3 Years
Was £129.98 Inc. VAT
ORDER NOW
OCZ Vertex 2E Bigfoot 120GB 3.5" SATA-II Solid State Hard Drive @ £165.59 inc VAT
OCZ Vertex 2 SATA II 3.5” Solid State Drives deliver the same industry-leading performance as the 2.5” edition in a larger, lower cost per gigabyte form factor to easily integrate into desktop applications without the need to install additional hardware.
Designed to excel in both sequential and random read/write speeds up to 50,000 4KB random write IOPS, the 3.5” Vertex 2 maximizes productivity when used as a primary storage or boot drive, minimizing program load times and completing tasks with blazing speed. Using the latest controller technology, the 3.5” Vertex 2 provides a faster, more responsive PC experience complete with TRIM support to keep your drive operating at peak performance in Windows 7 systems. Built with SATA 3Gb/s, Vertex 2 3.5” drives easily integrate into today’s desktop platforms as the ultimate storage upgrade.
Features:-
- Max Read: up to 285MB/s
- Max Write: up to 275MB/s
- Sustained Write: up to 250MB/s
- Random Write 4KB (Aligned): 50,000 IOPS
- Available in 90GB to 480GB capacities
- Native TRIM support
- Max IOPS Firmware
- Seek Time: .1ms
- 3.5" Anodized Casing
- 146 (L) x 101.6 (W) x 25.40mm (H)
- Operating Temp: 0°C ~ 70°C
- Low Power Consumption: 2W in operation,.5W in standby
- RAID Support
- Compatible with Windows XP, Vista, 7, Mac OS X and Linux
- MTBF: 2 million hours
- Ideal for desktop systems (no need for converter brackets)
- 3-Year Warranty
Was £169.99 Inc. VAT
Only £165.59 inc VAT.
ORDER NOW
Corsair A50 High-Performance CPU Cooler (Socket AM2/AM3/LGA775/LGA1155/LGA1156/LGA1366) @ £24.98 inc VAT
nonl2brExcessive heat is the deadly enemy of high-performance silicon, and the Air Series A50 CPU cooler can extend the lifetime of your CPU by quietly and efficiently drawing that heat away. You’ll get faster performance, too. Intel Core™ i5 and Core™ i7 processors can be easily configured to automatically overclock when conditions are right. Lowering your CPU’s operating temperature one of the best ways to do this – your CPU will detect that it’s running cooler, and instantly boost its speed when you need it. Of course, if you’re not using a Core i5 or Core i7 or if you prefer to adjust your overclocking settings manually, the Air Series A50 will give you the temperature headroom you need.<br>
The superior engineering of the Air Series A50 makes it dramatically outperform your CPU’s stock heatsink: three 8mm copper heatpipes directly contact your CPU and instantly pull heat up into the aluminum cooling fins. A 120mm fan, mounted on rubber studs to reduce noise and vibration, quietly draws cool air through the fins.<br>
Spend 15 minutes replacing your CPU’s stock heatsink and enjoy years of better performance.<br><br>
- Compatible with Intel and AMD systems<br>
- Three 8mm copper direct-contact heatpipes<br>
- Aluminum fins<br>
- Low-noise, low-vibration 120mm fan mounted on rubber studs<br>
- Selectable 1,600 or 2,000RPM fan allows you to select the cooling performance you want<br>
- Air flow: 50 - 61 CFM<br>
- Noise level: 26 - 31.5 dBA<br>
- Two-year warranty<br>
Was £27.98 Inc. VAT
Only £24.98 inc VAT.
ORDER NOW
Corsair Hydro H50-1 High-Performance CPU Watercooler (Socket LGA775/1155/1156/1366/AM2/AM3) @ £51.98 inc VAT
nonl2brThe Corsair Hydro Series™ H50 CPU Cooler gives you the power of liquid cooling in a compact, easy to install package. You get superior cooling for higher overclocking performance without the complexity of traditional liquid-cooling systems.
The Hydro Series H50 goes head-to-head with top of the line heatsinks, but maintains the near silence of liquid cooling for annoyance-free cooling performance. Due to its compact form factor, the H50 is the ideal solution for any case with a 120mm fan mount, even small form factor cases that prevent the installation of traditional heatpipe based air coolers. So whether you want world-class cooling, lower noise levels than your current CPU cooler, or something that fits in your small form factor case, the closed-loop Hydro Series H50 takes your CPU’s temperature to new lows and takes up less room doing it.<br><br>
- Pre-filled, closed-loop system is easy to install<br>
- Copper CPU cooling plate for maximum cooling performance<br>
- Integrated pump and reservoir is sealed for zero maintenance and improved leakage protection<br>
- Large 120mm radiator for fast heat dispersion<br>
- High-efficiency, low-noise 120mm fan for drawing cool air across the radiator<br>
<br><br>
<CENTER><IMG SRC="http://www.legitreviews.com/images/reviews/1154/2k9_bestof_award.jpg" width="150" height="150"/><IMG SRC="http://www.hardwareheaven.com/reviewimages/awards/newvaluesmall.jpg" width="150" height="150"/><IMG SRC="http://img.*****.net/v2/award_logo/Extreme_Recommended.png" width="150" height="150"/><IMG SRC="http://www.hardwareheaven.com/reviewimages/awards/newperformancesmall.jpg" width="150" height="150"/></CENTER>
<br>
<CENTER></param><embed src="http://www.youtube.com/v/PUxoFiFuS_g&hl=en_GB&fs=1" allowfullscreen="true" type="application/x-shockwave-flash" width="425" height="344">
</embed></object> </CENTER>
Was £54.98 Inc. VAT
Only £51.98 inc VAT.
ORDER NOW
Gelid Tranquillo CPU Cooler (Socket 754/939/940/AM2/AM2+/AM3/LGA775/LGA1155/LGA1156/LGA1366) @ £23.99 inc VAT
The tower CPU Cooler “Tranquillo” uses 4 power heat pipes and a special heat pipe constellation to achieve best heat transfer from CPU core to the aluminium fins in its class. After precise software simulation and calculation during the development stage a unique heat sink shape was created to lower air flow resistance as much as possible.
A silent 120mm fan with the intelligent GELID PWM (Pulse Width Module) control has been chosen to make this heat sink more valuable. The fan blades were optimised to guarantee high airflow while running silently. The intelligent GELID PWM curve keeps the fan silent when no necessary cooling is needed and accelerates the fan speed whenever additional cooling is needed. The multi-award winning high performance GC-2 thermal compound is already included in the package.
Additionally mounting clips for AMD 754/ 939/ 940/ AM2/ AM2+ and for Intel 775, 1366 and latest 1156 sockets as same as back plates for Intel LGA 775, Core i5 and Core i7 boards are all included.
- Socket Compatibility: 754 / 939 / 940 / AM2 / AM2+ / AM3 / LGA775 / LGA1155 / LGA1156 / LGA1366
- Dimensions: 74 x 125 x 153mm (L x W x H)
- Fan Speed: 750 - 1500 RPM
- Air Flow: 58 CFM
- Noise Level: 12-25.5 dBA
- Weight 645g
- 5 Year Warranty
Was £26.53 Inc. VAT
Only £23.99 inc VAT.
ORDER NOW
Thermalright Venomous X Silent CPU Cooler (Socket 775/1156/1155/1366/AM2) @ £52.98 inc VAT
Patented multiple support pressure vault bracket system, allow users adding pressure to the bracket system (40~70 lbs. pressure system for Intel CPU user only), and have a more efficient and secure mounting. Include AMD Socket AM2/AM3 Bracket system. Mirrored copper base increasingly upgrade the quality and the performance of the heatsink. Special bent winglet design, allows hot air to pass the heatsink more rapidly. Heatsink are all nickel plated to ensure the best quality and performance and could last for years. Soldered heatpipes, copper base and fins, to ensure the best thermal conducting efficiency. Six sintered heatpipe design, all heatpipes are nickel plated.To slow the oxidation deterioration to the heatpipe, to ensure longer usage and performance of the heatsink for the cpu. Including FDB 600RPM ultra low noise Fan Cover set x2 and Chill factor III thermal paste. Convex copper base design, to ensure the Highest thermal conducting thermal efficiency between the cpu and the heatsink.
Heatsink Dimension
- Size: Length 127mm x Width 63mm x Height 160mm
- Weight: 755 g (excluding fan and bracket system)
- Heatpipe: 6mm sintered heatpipe *6 units
- Copper base: C1100 pure nickel plated copper base, with ultra-shine mirrored surface.
Fan Spec
- Dimension : 120 x 120 x 25mm
- Bearing Type : FDB (Fluid Dynamic Bearing)
- Rated Voltage : 12.0 VDC
- Operating Voltage Range: 10.8~13.2 VDC
- Rated Current: 0.130 Amp +10% MAX /0.11AMP
- Rated Power: 1.56 watt
- Rated Speed: 600 RPM ± 10%
- Airflow: 30.5 CFM
- Noise Level: 13.1 dB/A
- Life Expectancy: 60000 HOURS AT 40°c / 65%
- Net weight: 156 GRAMS
- Connector: 3 pin
Was £56.99 Inc. VAT
Only £52.98 inc VAT.
ORDER NOW
Antec Tri-Cool 3-Speed 120mm Fan - Black @ £1.98 inc VAT
No matter what type of fan you're looking for, the Antec TriCool line offers reliable, stable performance. Available in 80, 92, and 120mm, TriCool fans offer the perfect balance of silence and efficiency. TriCool fans feature a 3-speed switch so you can find the ideal equilibrium of quiet and cooling.
- 3-speed switch lets you balance quiet performance with maximum cooling
- 3-pin and 4-pin power connectors provide convenient connections to your motherboard or power supply
- Fan-speed monitoring capability included (requires compatible motherboard)
Was £2.99 Inc. VAT
Only £1.98 inc VAT.
ORDER NOW
Fractal Design 120mm Silent Cooling Fan @ £7.98 inc VAT
Fractal Design "Silent Series" is a full range of silent case fans. The fans has been specifically developed to deliver sufficient airflow and still keep a low noise level. Available in sizes from 40mm up to 140mm.
Each fan is supplied with rubber fan mounts and four fan screws.
- Fan Speed: 1000 RPM
- Noise Level: 15 dBA
- Air Flow: 38.3 CFM
- 3 pin connector
- 2 Year Warranty
Was £9.98 Inc. VAT
Only £7.98 inc VAT.
ORDER NOW
Thermalright TY-140mm Silent Fan (Fits 120mm fittings) @ £8.99 inc VAT
PWM fan, provides simple and easy adjustment of fan speed with the latest ETC IC. Seven Silent Torpedo Blades - “submerges”, gives most quiet and efficient airflow. Enhanced Hyper-Flow Bearing (EHFB) - to ensure consistent and stable rpm, prolonged lifetime of usage. Aerodynamic body–Less friction around the edges and give more centered and concentrated airflow. 12 cm mounting hole–allows installation on the 12 cm dimension, so will be compatible with most coolers without having the need to buy extra kit for 14cm fan.
- Fan Dimensions : L160mm x H140mm x W26.5mm
- Fan Weight : 140g
- Fan Speed : 900~1300RPM (PWM)
- Sound Level : 17~21dBA
- Airflow : 28.3~74CFM
Was £10.99 Inc. VAT
Only £8.99 inc VAT.
ORDER NOW
Antec 300 Three Hundred Ultimate Gaming Case - Black @ £47.99 inc VAT
Impressively spacious and unbeatably reliable, the Antec Three Hundred is an unbeatable enclosure. Despite its eminently portable frame, the Three Hundred has enough room for all the latest flag-ship graphics cards, as well as six hard drives and a standard ATX motherboard. A cable management compartment keeps your system organized and the airflow unobstructed. A 120mm rear fan and 140mm top fan ensure that the case runs cool even when playing the most demanding games, while the sleek black finish gives it an extra stylish edge.
- External 3 x 5.25"
- Internal 6 x 3.5" for HDD
- 1 rear 120 x 25 mm TriCool™ Fan with 3-speed switch control.
- 1 top special 140 x 25 mm TriCool™ Fan with 3-speed switch control
- 2 front (optional) 120 mm fans to cool the hard drives
- 1 side (Optional) 120 x 25 mm Fan to cool graphic cards
- Washable air filters reduces dust build up in your system, which helps keep your system cooler
- Perforated front bezel for maximum air intake
- 7 expansion slots
- Top mounted I/O ports for easy access
- 2 x USB 2.0
- Dimensions: 458mm (H) x 465mm (D) x 205mm (W)
- HDA & AC’97 Audio In and Out
Was £49.99 Inc. VAT
ORDER NOW
Coolermaster CM-690 II Advanced Dominator Case - Black @ £72.98 inc VAT
The CM 690 II Advanced raises the bar again with practical improvements over the top-selling CM 690. The spacious mid-tower will keep enthusiasts happy with room for up to 3 vga cards, high-end CPU coolers, top or bottom mount water cooling radiator and 1.8"/2.5" drive adapter. It also features much improved airflow with oversized mesh and enough space for up to 10 fans. Maintenance will be a breeze with the tool-free drive bays, new cable management and CPU cooler retention hole.
- Dimensions: 214 x 511 x 528mm
- Motherboard Compatiblity: ATX, Micro-ATX, Mini-ITX
- Room for 120 x 240mm Radiator inside the top and bottom
- External SATA HDD dock
- Includes SSD Adapter
- Cable management and CPU retaining holes for easy maintainence
- Support Tri-GFXs
- 4 x 5.25" Drive Bays
- 7 x 3.5" Drive Bays
- I/O Panel: USB2.0, 1 x eSATA, 2 x Audio
- Front Cooling: 1 x 140mm Blue LED Fan
- Rear Cooling: 1 x 120mm Fan
- Top Cooling: 1 x 140mm Fan
- Bottom Cooling: 2 x 120mm Fans (optional)
- Right Side Cooling: 2 x 120 or 140mm Fans (optional)
- Left Side Cooling: 1 x 80mm Fan
- HDD Cage Cooling: 1 x 120mm Fan (optional)
- VGA Holder: 1 x 80mm Fan (optional)
Was £76.99 Inc. VAT
Only £72.98 inc VAT.
ORDER NOW
Lian Li PC-B25FB Aluminium Midi Tower Case - Black @ £110.99 inc VAT
The new PC-B25F is a mid-tower case, which is ideal for the latest graphics cards in combination with the best thermal dynamics. Easily adjustable to optimize your hardware setup. Especially in the advent of adding in new graphics cards, equipped with 8 PCI slots, can hold three or more graphics cards, supports CrossfireX™ and 3-way SLI™.
- Case Type: Mid Tower
- Dimensions: 210mm x 495mm x 490mm ( W, H, D)
- Front bezel Material: Aluminum
- Side Panel: Aluminum
- Body Material: Aluminum
- 5.25" drive bay: 3
- 3.5" drive bay: 6
- Motherboard: ATX / M-ATX
- System Fan: 12cm Fan x 2 (1200RPM)
- System Fan: 14cm Fan x 2 (1000RPM)
- System Fan: 12cm Fan x 1 (1500RPM)
- I/O Ports: E-SATA / USB2.0 x 2 / HD+AC97 Audio
Was £115.99 Inc. VAT
Only £110.99 inc VAT.
ORDER NOW
Samsung B2230H 21.5" Widescreen LCD Monitor - Glossy Black @ £119.99 inc VAT
Samsung 30 Series monitors are designed to be eco-friendly as well as user-friendly. With efficient power saving and innovative features, they allow you to enjoy using your monitor with the confidence of a clear conscience. The phenomenal 70000:1 Dynamic Contrast Ratio welcomes you to a world of intense, natural colour and incredible, lifelike detail. Combine that with a high brightness of 300cd/m² and you have a monitor that is made for multimedia.
- Screen Size: 21.5" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 70000:1
- Brightness: 300cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Dimensions: 523.4mm x 400.0mm x 197.0mm
- Weight: 4.35kg
- Warranty: 3 Years On-Site
ORDER NOW
Asus VG236HE 23" TRUE 120Hz 3D Widescreen LCD Monitor - Black @ £275.99 inc VAT
Enter an immersive three dimensional Full HD 1080p world of games and movies with the VG236HE. Through the use of market-leading 3D technology and active shutter glasses, it instantly takes you into another dimension - transforming your gaming experience to 3D. There are hundreds of popular PC game titles currently compatible with the NVIDIA 3D Vision kit (not included).
- Tilt and Swivel also Height Adjustable.
- Screen Size: 23" Widescreen
- Contrast Ratio: 100000:1
- Response Time: 2ms
- Viewing Angles: (H/V): 170*/160*
- Inputs : 1 x DVI-D & 1 x HDMI
- Weight: 7kg
- 3 Years Warranty
Was £285.95 Inc. VAT
Only £275.99 inc VAT.
ORDER NOW
"Primo Drone" AMD Athlon II X2 Dual Core 250 3.00GHz DDR3 System @ £189.98 inc VAT
The "Primo Drone" offers the performance needed for home and business use at a low price. The AMD Athlon II X2 Dual Core 250 3.00GHz combined with 4GB of 1333MHz DDR3 RAM, offers a quick and easy multitasking experience.
Why You Should Buy This System?
- AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3) offers multitasking performance.
- 500GB Seagate Barracuda hard drive gives a solid and reliable storage capacity.
- 4GB of 1333MHz DDR3 RAM allows for snappy and precise processes to be made.
System Specification
- Case: OcUK EZCool NA-705 microATX case - Black
- Power Supply: OcUK Value 500W PSU
- CPU: AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3)
- Motherboard: AMD nForce 630a (Socket AM2+/AM3) DDR3 Motherboard
- RAM: OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel
- Hard Drive: Western Digital Caviar Blue 500GB SATA 6GB/s
- Graphics Card: Onboard integrated NVIDIA GeForce 7025 GPU
- Sound: ALC662 6-channel High Definition Audio CODEC
- Optical Drive: LG GH22NS50 22x DVD±RW SATA ReWriter
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
Compact, reliable and smart. The "Primo Drone" give you everything you need in a entry level home/business system.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Was £199.98 Inc. VAT
Only £189.98 inc VAT.
ORDER NOW
Samsung P2370 23" Widescreen LCD Monitor - Glossy Black @ £131.99 inc VAT
Ultra-slim and ultra-elegant, the Touch of Colour design is inspired by the artistic integrity of hand blown glass. The translucent charcoal gray gradation of the bezel and cobalt blue hues of the clear crystal neck subtly shift in color depending upon external light conditions, creating an exquisite interplay between the monitor and the environment that it is placed in. The ultra-slim 30mm depth not only creates more style in less space but also ensures exceptional all round efficiency. Up to 50% slimmer than traditional monitors, the modern, organic contours gently accentuate the elegance of your lifestyle and home.
- Contrast Ratio: 50000:1
- Brightness: 250cd/m²
- Inputs: 1x DVI-D (HDCP Compliant)
- Dimensions: 571.0mm x 423.0mm x 190.0mm
- Weight: 4.1kg
Was £139.99 Inc. VAT
ORDER NOW
Benq XL2410T 24" TRUE 120Hz 3D Widescreen LED Monitor - Black @ £269.99 inc VAT
BenQ, proudly announced the release of their 23.6” (16:9 Aspect Ratio) LED Gaming Monitor XL2410T. BenQ understands that to lead and become a true and professional gaming monitor provider, they have to understand the mindset and needs of gamers. In order to achieve this goal, BenQ co-worked with ZOWIE, a professional Gaming gear manufacturer. BenQ have ZOWIE’s gamer teams join in during the product development and testing stages. With their assistance, XL2410T can truly be a professional LED gaming monitor – with a set of Gaming Display Modes which includes the FPS mode (First Person Shooting), co-developed by two legendary Counter-Strike players – Emil “HeatoN” Christensen and Abdisamad “SpawN” Mohamed.
Every serious gamer know that lag will cause you to lose a game; XL2410T is made to have a quick response to action, hardware lag will no longer be the cause for your headshots. XL2410T has a fast refresh rate of 120Hz for higher precision; a low input lag so the shots made is more in sync with the visual on-screen; a quick 2ms GTG (OverDrive) meaning users can see the edge of the enemies clearly and without motion blur, and Dynamic Contrast Ratio of 10,000,000:1 for detailed images and clarity in both darkened and brightened situations, this complemented with BenQ’s gaming tuning technology becomes a huge advantage for gamers.
XL2410T has a smart design, for one purpose – to win. The monitor has two hotkeys available; the first changes the display mode: Full; Aspect; Overscan; 1:1; 17”; 19”; 19” Widescreen and 22” Widescreen. Whereas the second hotkey is Smart Scaling, which lets the users adjust picture size in original input to the screen’s limit. Together with Display Mode function, users can play in the resolution size they are used to with their previous monitor, or adjust their screen size to what their teammates are using for easier communication and reference. From BenQ’s Gaming Display Modes options, users can choose from FPS Mode, made possible by co-working with the gaming heroes -HeatoN and Spawn as the best setting for personal shooting games, or from the two User Game modes for more dedicated and personalized settings.
For extreme entertainment, XL2410T is the LED monitor to go for. 3D-ready (NVIDIA 3D Vision certified); Picture by Picture (PBP); connectivity values (D-sub; DVI-D-DL, HDMI) and height adjustment feature are offered for users’ enjoyment and comfort. Picture by picture (PBP) is a feature that enables users to show two programs side-by-side on the screen. Feel like camping once in a while for fun? Watch a movie while you do it!
- LED Backlit
- Screen Size: 23.6" Widescreen
- Contrast Ratio: 10000000:1
- VESA Compliant
- Dimensions: 570.0mm x 412.6mm x 183.9mm
- Weight: 6.0kg
- Height adjustable stand / Swivel 45/45 left/right
- Warranty: 2 Years On-Site
Was £281.99 Inc. VAT
Only £269.99 inc VAT.
ORDER NOW
Pioneer BDR-205 12x BluRay RW / 16x DVD±RW Drive - Black (OEM) @ £95.99 inc VAT
Pioneer introduces the world's first 12x BD-R/BD-R DL optical drive. The BDR-205 Internal Blu-Ray Disc/DVD/CD Writer is the lastest generation in technology. This revolutionary product will write up to 12x on BD-R (25Gbytes) and BD-R DL (50Gbytes) media giving you more time to play.
Write Speed
12x BD-RE and BD-RE DL/BD-R
16x DVD-R / +R
6x DVD-RW
8x DVD+RW
8x DVD-R DL / +R DL /BD-R/BD-R DL
40x CD-R
24x CD-RW
Read Speed
8x BD-ROM/BD-ROM DL / R / RE
16x DVD-ROM and DVD-R / +R/DVD-R
12x DVD-ROM DL , DVD -RW / +RW and DVD-R DL / +R DL
40x CD-ROM
40x CD-R
24x CD-RW
Was £99.98 Inc. VAT
ORDER NOW
Samsung SH-B123L/BSBP 12x BluRay ROM DVDRW DL & RAM Lightscribe SATAII Optical Drive - Retail Black @ £50.39 inc VAT
True 1080p Full HD technology is more than just entertainment, it's an experience. And it's the pinnacle of picture quality, engulfing and entertaining you with spectacular detail-rich, eye-popping colours and super-sharp, ultra-realistic images that enhance anything and everything on your screen. With our Blu-ray drives, you'll feel like you're seeing your favourite movie for the very first time.
Blu-ray lets you get the most out of your movie watching, so shouldn't you get the most out of Blu-ray? That's where BD Advisor comes in. It lets you unlock the power of interactive high-definition movie viewing with PowerDVD and Blu-ray Discs. BD Advisor helps you test your system and understand Blu-ray basics as well as suggest upgrades. Now you can always enjoy the best Blu-ray has to offer.
Breathe new life into your movie collection with Samsung's up-scale technology. It gives your standard definition DVDs a dramatically different high resolution look. And it gives your movie-viewing experience a cinematic boost. By up-scaling, your favourite DVDs will feature the same brilliant details and rich, robust colours you've come to enjoy from the high definition content on your HDTV.
- SATA Interface
- Includes Cyberlink PowerDVD
Write Speeds
- DVD-R: 16x
- DVD-R DL: 8x
- DVD-RW: 6x
- DVD-RAM: 12x
- DVD+R: 16x
- DVD+R DL: 8x
- DVD+RW: 8x
- CD-R: 48x
- CD-RW: 24x
Read Speeds
- BD-ROM: 12x
- BD-R: 8x
- BD-RE: 8x
- BD-RE DL: 6x
- DVD: 16x
- CD: 48x
Was £59.99 Inc. VAT
Only £50.39 inc VAT.
ORDER NOW
"Primo Pterosaur" Intel Core i5 2300 2.80GHz DDR3 Sandybridge System @ £409.99 inc VAT
Introducing the "Primo Pterosaur" delivering breath taking performance and providing excellent onboard graphics from the integrated Intel HD2000 GPU. Capable of DX10.1 Stereoscopic 3D via HDMI 1.4a and having enough power for discreet gaming. The "Primo Pterosaur" offers everything that is required to make a perfect home computer.
- Choose from a selection of graphics cards to meet your performance needs
- Precision built and cabled by Overclockers UK expert technicians
- USB3, SATA 6GB/s, Intel Ethernet and EUFI graphical BIOS for next gen computing
- Case: Xigmatek Asgard - Black
- Power Supply: OCZ StealthXStream II 600W
- CPU: Intel Core i5 2300 2.80GHz Sandybridge CPU
- Motherboard: Intel H67 (Socket 1155) MicroATX DDR3 Motherboard ** B3 REVISION **
- Cooler: Intel Stock Cooler
- RAM: Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
- Graphics Card: Onboard Intel HD2000 graphics with GFX upgrade options
- Sound: Realtek 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
Service Package
With powerful graphics, rapid processing and features by the truck load, the "Primo Pterosaur" offers more than any other computer at this price.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods. T
Was £419.99 Inc. VAT
Only £409.99 inc VAT.
ORDER NOW
Pioneer 24x Internal S19LBK DVD Rewriter including Labelflash SATA Retail @ £17.99 inc VAT
Pioneer 24x Internal SATA DVDRW Drive with Black Bezel, Retail Kit with Nero Writing Software.
Optical Storage - DVD±RW (±R DL) / DVD-RAM - 5.25" x 1/2H
- Read Speed - 40x (CD) / 16x (DVD)
- Enclosure Type - Internal
- CD / DVD Rewrite Speed - 32x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 12x (DVD-RAM)
- Enclosure Colour - Black
- Interface - Serial ATA
Was £21.98 Inc. VAT
Only £17.99 inc VAT.
ORDER NOW
MSI GT680R-056UK 15.6" WLED TFT Intel HRV I7-2630QM 2.0GHz, 8GB DDR3, 1TB HDD, NVIDIA GTX460M 1.5GB GDDR5 Graphics, Win7 Home Premium 64-Bit - Black/Red @ £1,318.80 inc VAT
Based on PCMark Vantage test the GT680 scored 18,162, which is the highest test score in history. Compared to all the high end-end gaming notebooks on the market, the GT680's performance is 75% faster than others. With MSI Turbo Drive Engine (TDE) Technology, which is world's No.1 turbo technology, you can experience faster response time and efficient real-time data processing. Only one finger!! Exclusive Cooler Boost technology provides powerful cooling capabilities and receives real-time notification of the GT680's core temperature variations and fan speed. Provides you with the most economical means to upgrade memory capacity (16GB max), so you never again have memory issues affecting your gaming experience. Dual SATA hard drives(maximum capacity of 1TB)let you play more games, view more DVDs and download more music, allowing you to enjoy all kinds of entertainment when you’re out and about. NNVIDIA® GeForce® GTX 460M notebook GPUs give your games an adrenaline shot with the premium performance and great detail images quality thanks to latest DirectX11 effects. GeForce GTX 460M arms you with the latest industry-leading technologies including eye-popping NVIDIA 3D Vision, dynamic PhysX effects, high performance NVIDIA Verde drivers, and more. DirectX 11 GPU with Shader Model 5.0 is designed for ultra high performance and real-to-life image details in the new API’s key graphics feature, GPU-accelerated tessellation.
This exclusive, dazzling LED performance illumination technology increases the sensation of instant immersion when listening to music, watching video, or while wrapped up in the gaming world, thanks to changes in the GT680's cool LED lights. When listening to music, watching a video or when knee-deep in the exciting world of gaming, simply press the MSI LED light performance control hotkey and the GT680 enters Audio Synchronize Mode. Then, the GT680's LED lights on both sides of the notebook and at the front of the keyboard will light up all at once. The light performance will follow different changes in sound, allowing you to unconsciously follow the rhythm of the dynamic lighting and envelop yourself in an atmosphere of sound and light that will leave you breathless! The exclusive LED performance illumination mode can also intelligently simulate sound. When the left-side speaker emits sound, the LEDs on the left side will independently illuminate, and the same on the right side. For example, when an image of a bullet passes from left to right, the noise of the bullet will also pass from left to right through the speakers, and the LED lights then light up in conjunction with the direction of the sound moving from left to right, giving images and sound a three dimensional effect and making you feel as if you are in the midst of authentic and dynamic reverberations!
Cinema Pro Technology offers consumers the finest movie viewing experience. Just need to push the Cinema Pro button, the Windows Media Player will automatically open. The quality on screen will be more detailed, the richness in sound as well as THX TruStudio Pro surround sound effect will be activated, providing the finest sensory of the theaters. USB 3.0 can reach transfer rates of 4.8GB per second, 10 times the bandwidth of the current USB 2.0. A 27GB HD file (about as large as a 4 hour HD video) can be transferred within 70 seconds, so HD video and 3D game playback speeds are even faster. USB 3.0 is also capable of executing read/write data operations, while USB 2.0 can only execute unidirectional document transfers in the same amount of time. Genuine 720p high-definition (HD) video quality to 30fps (30 continuous images per second Allowing smooth, natural progression without jerkiness; ordinary webcams only offer 8fps). This guarantees truly clear and smooth video and picture quality and exceptional audio effects. In addition, the 16:9 HD wide-screen video display can be used with all kinds of social networking media, allowing optimum high-quality video communication and production of HD videos for the enjoyment of friends and family.
The GT680 ‘s HDMI output not only delivers super-fast 5GB per second data rates, but it also reduces cable clutter, while ensuring the best possible video quality. By taking advantage of HDMI, the GT680 can render game scenes with spectacular clarity and realism, making it a great choice for the next generation of both PC and online games. The GT680 features a numerical keypad that provides a desktop-quality typing experience. For uers often needing to key in numbers, the GT680’s keyboard is a huge boon. With its 802.11b/g/n(draft) wireless LAN and Bluetooth networking interfaces, the GT680 provides a versatile way to connect to, browse, and retrieve data on both your own devices and the online universe.
Features:-
- 15.6" WLED True HD Screen with 1920x1080 resolution
- Intel HRV I7-2630QM 2.0GHz Processor
- 8GB DDR3 Memory
- 1TB 7200rpm HDD (2x 500GB in RAID 0)
- NVIDIA Fermi GTX 460M 1.5GB Graphics
- Intel HM67 SandyBridge Chipset
- Super-Multi DVD
- Bluetooth
- HDMI
- HD Webcam
- 9 Cell battery (3hr battery life)
- Windows 7 Home Premium
- The latest 2nd generation Intel® Core™ i7 Processor
- Genuine Windows® 7 Home Premium
- Exclusive TDE Technology
- Exclusive DDR3 SO-DIMM x 4 slot Design
- Sound by Dynaudio
- THX TruStudio Pro Provides Excellent Surround Sound Effect
- High-end NVIDIA® GeForce GTX 460M discrete graphics card
- Latest & fastest Data Transfer Technology USB 3.0
Was £1,499.99 Inc. VAT
Only £1,318.80 inc VAT.
ORDER NOW
"Primo Ignition" Intel Core i3 550 3.20GHz DDR3 System @ £299.98 inc VAT
The "Primo Ignition" features a Intel Core i3 550 3.20GHz processor seamless multi-tasking capabilities which is perfect for home/office use. Awesome power contained within a small chassis the "Primo Ignition" has the option to upgrade to one of many of the latest Low Power, energy efficient Nvidia series graphics cards for extra graphical punch. Utilising Hyper threading technology the "Primo Ignition" makes short work of video encoding and multitasking.
- Intel Core i3 540 3.06GHz (Clarkdale) Processer with Hyperthreading technology for 4 Virtual cores
- 500GB Hard drive gives massive storage capacity including DVD Re-Writer Make this system perfect for data backup
- Case: OcUK EZCool NA-705 microATX Case
- Power Supply: OcUK 500W PSU
- CPU: Intel Core i3 550 3.20GHz (Clarkdale)
- Motherboard: Intel H55 (Socket 1156) DDR3 microATX Motherboard
- Cooler: Intel Approved Cooler
- Graphics Card: Onboard Intel GMA graphics or a choice of energy efficient graphics cards
- Sound: High Definition 7.1 Onboard Sound Card
- Optical Drive: LG GH22NS50 22x DVD+RW SATA ReWriter
Service Package
With multiple video outputs, compact size and advanced hyperthreading technology the "Primo Ignition" is perfect for the user looking for a highperformance system for a low price.
Was £309.98 Inc. VAT
Only £299.98 inc VAT.
ORDER NOW
Coolermaster Elite Power 500W Power Supply @ £32.99 inc VAT
The reliable, efficient and affordable line of Elite power supplies is ideal for mainstream and basic computing systems. Built with quality components and dual +12V outputs, the Elite series is fit to handle demands of high power requirements. The eco-friendly design allows the Elite series to reach more than 70% efficiency at typical loading and meet Energy Star and Blue Angel requirements.
- Compliance with the newest Intel standard ATX 12V V2.3
- More than 70% efficiency at typical load operation
- High performance components design for better reliability
- Green power design to meet Energy Star and Blue Angel requirements
- Multiple protection design(OVP/OCP/OPP/SCP)
- Support dual +12V1 and +12V2 outputs for higher power usage
- One 4+4 pin +12V CPU connector for high-end CPU
- EMI and Noise filter built in design
- 2 Year warranty
Was £34.99 Inc. VAT
Only £32.99 inc VAT.
ORDER NOW
MSI GT680-035UK 15.6" WLED TFT Intel HRV I7-2630QM 2.0GHz, 8GB DDR3, 120GB SSD + 500GB HDD, NVIDIA GTX460M 1.5GB GDDR5 Graphics, Win7 Home Premium 64-Bit - Black/Red @ £1,558.80 inc VAT
Features:-
- 8GB DDR3 Memory
- 120GB Intel SSD Boot Drive PLUS 500GB 7200rpm Storage HDD
- Blu-Ray ROM
- Bluetooth
- HDMI
- HD Webcam
- Sound by Dynaudio
Was £1,699.00 Inc. VAT
Only £1,558.80 inc VAT.
ORDER NOW
"Titan Spinosaur" Intel Core i5 2500K 3.30GHz @ 4.60GHz DDR3 Sandybridge System @ £706.00 inc VAT
Stalking through the jungle, the "Titan Spinosaur" is master of all. Featuring the Intel Core i5 2500K overclocked to a ridiculous 4.60Ghz, you can enjoy ultra smooth framerates and an immersive computing experience. With a choice of the latest DX11 graphics cards, equip yourself ready for the hunt ahead with the best offering from both Nvidia and ATI.
- A guaranteed 4.60GHz performance for the price of 3.30GHz
- Case: Antec 300 Case with LED case fan options
- Power Supply: OCZ StealthXStream 700W
- CPU: Intel Core i5 2500K 3.30GHz @ 4.60GHz Sandybridge CPU
- Motherboard: Gigabyte P67A-UD4 Intel P67 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
- Cooler: Corsair H50 CPU Cooler
- RAM: Corsair Vengeance 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit
- Graphics Card: Choice of DX11 Compatible Graphics Cards
Service Package
Heighten your gaming experience with the "Titan Spinosaur", stalk your prey down and demolish the competition. Equipped with either ATI or Nvidia, become a champion.
Was £755.99 Inc. VAT
Only £706.00 inc VAT.
ORDER NOW
Roccat Alumic Gaming Pad @ £33.59 inc VAT
With two very different surface structures, the ROCCAT™ Alumic meets the highest demands of both low and high-sense gamers. Each side also features a different design. Made from high-quality aluminum, the ROCCAT™ Alumic offers maximum stability and durability. Extra-large mousepad feet ensure the mousepad stays rooted to the spot while offering the ultimate in mouse control when gaming. It also includes a gel-filled wrist rest for maximum comfort.
- Double sided mousepad
- Anodized aluminium core
- Including gel wrist rest
- Non-slip rubber feet
- High quality materials
- Easy-to-clean surface
- Optimised for speed & control
Was £34.98 Inc. VAT
Only £33.59 inc VAT.
ORDER NOW
Speedlink Vellu Gel Mousepad - Black @ £5.39 inc VAT
The mouse pad is perfect for maintaining the wrists in a relaxed position whilst working thereby preventing excessive straining. The gel filling allows the mouse pad to mould to optimally fit any wrist thereby improving use.
- Reduces posture-related injuries
- Adapts perfectly for any wrist
- Extremely soft covering
- Mousepad with gel filling
- Enables relaxed arm posture
Was £6.98 Inc. VAT
Only £5.39 inc VAT.
ORDER NOW
Gigabyte M8600 6500DPI Wireless Gaming Mouse @ £79.98 inc VAT
Aivia M8600 Wireless Macro Gaming Mouse has long lasting battery that guarantee 100-hour nonstop gaming experience. QSBS™ (quick swap battery changing system) technology is GIGABYTE's unique design. This patent pending technology allows for Instant battery changing under 2 seconds, as fast as gun clip loading and unloading.
Aivia M8600 Wireless Macro Gaming Mouse comes with an instant charging dock, served as mouse and Li-ion batter charger as well as wireless receiver unit. This device helps you enjoy gaming with wireless transmission speed at 1000Hz polling rate. The powerful wireless reception ensures no signal is lost that every single move made by the mouse is read during game playing.
Aivia M8600 Wireless Macro Gaming Mouse features twin-eye gaming-grade laser engine. Based on advanced laser technology, the twin-eye gaming sensor features high precision, low power, and ultra-fast performance.
When Aivia M8600 Wireless Macro Gaming Mouse is connected to its complimentary wire, it is able to edit GIGABYTE's GHOST™ Macro Engine. GHOST™ Macro Engine is an incredible macro editing software for the memorized macros to be carried around even if the mouse is connected to a different computer. 32KB onboard memory enables up to 5 programmable profile settings. The engine features critically acclaimed easy-to-use drag-and-drop operating system, DPI switching, tilt-wheel speed adjustment, and customizable color hues as profile indicators.
- GamePlay™ Wireless Technology- over 50hrs battery life in game play
- Quick-swap battery system- instant battery changing under 2secs, as fast as gun clip loading
- 32KB onboard memory enables up to 5 programmable profile settings
- Dual mode wired/ wireless functionality-switch between the wireless freedom and the frenzy of wired play
- Advanced GHOST™ Macro Engine
Was £89.99 Inc. VAT
Only £79.98 inc VAT.
ORDER NOW
Gigabyte 'Ghost' Mouse Pad @ £6.12 inc VAT
The GigaByte GP-MP8000 mouse pad is a perfect partner for there gaming mouse the GM-M8000 Ghost. If you are not using the GM-M8000 mouse, be assured you will not be disappointed while using any one of your favorite mice on it. The large size of this mouse pad gives us freedom to move the mouse around with out having to worry about the mouse falling off the edge while cutting and pasting images, to seriously gaming.
- High density polyester cloth optimize your superior performance in games.
- Anti clip natural rubber secures high-speed movement.
- ide and smooth surface provides total-comfort grip.
- Designed for power users whose demand precision tracking.
- Perfect gaming size: 400x 300x 5mm.
Was £6.50 Inc. VAT
Only £6.12 inc VAT.
ORDER NOW
Seagate Momentus XT 500GB Hybrid SATA-II 2.5" 7200RPM 32MB @ £87.98 inc VAT
nonl2br
Powerful, intelligent, affordable - solid-state hybrid drives deliver SSD-like performance without sacrificing storage capacity and affordability. <br><br>
- Adaptive Memory™ technology <br><br>
- 80% faster than traditional 7,200-RPM drives <br><br>
- Boot within seconds of a laptop with SSD <br><br>
- Work in any standard laptop with any OS <br><br>
- Seagate 5-year limited warranty <br><br>
The Seagate Momentus® XT solid state hybrid drive combines SSD-like performance with affordable high-capacity hard drive storage for laptops, external backup and small form factor desktop PCs. This drive is designed for all standard laptop PCs and is OS-, driver- and software-independent, making it easy to integrate and easy to use. <br><br>
The Momentus XT drive offers hybrid storage with Adaptive Memory technology, enabling the drive to deliver higher capacities up to 500GB and SSD-like performance. <br><br>
Adaptive Memory Technology <br><br>
Designed with high-performance core components on an innovative platform, the Momentus XTdrive consists of a 7200-RPM hard drive with 32MB of cache, 4GB of solid state SLC NAND flash storage, and Adaptive Memory self-learning technology. Adaptive Memory technology intelligently monitors frequently used applications and data fi les, then places them into the solid
state portion of the drive so they can be quickly recalled. Adaptive Memory technology enables the drive to tailor its performance to the user.Whether you are gaming, editing digital media or
crunching numbers, the performance is optimized and ready for your next move. <br><br>
Key Specifications <br><br>
- 500GB, 320GB and 250GB hard drive capacity options <br><br>
- 4GB SLC NAND solid-state memory <br><br>
- 7,200-RPM spindle speed <br><br>
- 32MB of drive-level cache <br><br>
- SATA 3-Gb/s interface with Native Command Queuing <br><br>
Best for <br><br>
- High-end laptops and workstations <br><br>
- High-performance gamer laptops <br><br>
- Fast external enclosures: USB 3.0, eSATA <br><br>
- Small form factor PCs <br><br>
- High performance Desktop Storage <br><br>
<br><br>
<<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/Kss98VdhSj0?fs=1&hl=en_GB"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Kss98VdhSj0?fs=1&hl=en_GB" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
Was £94.99 Inc. VAT
Only £87.98 inc VAT.
ORDER NOW
Qpad Grin CT Large Mouse Pad @ £18.98 inc VAT
nonl2br
For all users with high demands on precision, feel and functionality this is the mouse pad that delivers. CT™ series smooth Hybratek™ coating ensures that the mouse registers every detail of the smallest mouse movement. It offers a smooth and a controlled glide with an optimum level of friction. Whether you are a hardcore gamer or work with other demanding tasks such as graphic design or large spreadsheets, you’ll thrill to the task.<br><br>
- Size: Large: 40.5x28.5cm<br>
- Thickness: 4 mm<br>
- Grin design<br>
- Surface: Hybratek Coated soft top<br><br>
<font color="red"> <font size="3"> SRP <s>£28.58</s> <b>SAVE: 6.60 </font>
Was £21.98 Inc. VAT
Only £18.98 inc VAT.
ORDER NOW
Corsair Gaming Audio Series HS1A Analogue Gaming Headset @ £39.98 inc VAT
The Gaming Audio Series HS1 Gaming Headset is designed for gamers who are serious about audio. Massive 50mm driversdeliver serious punch, without sacrificing the sparkling sound quality you need for music and movies. Extra-large, extra-deep memory foam earpads provide a reliable, custom fit that’s so comfortable, you might forget you’re wearing them.
- Massive 50mm drivers for high-quality audio reproduction
- Detailed audio reproduction with clean, accurate bass and sparkling clarity in mids and highs
- Circumaural, closed-back earcups for superior noise isolation
- Memory foam earpads provide a custom fit that won’t weigh you down
- Includes two sets of earpads to customize your comfort – your choice of microfiber or synthetic leather
- Connectivity: 3.5mm jacks for ear piece and mic
- 2 Years Warranty
Was £43.98 Inc. VAT
Only £39.98 inc VAT.
ORDER NOW
Seagate Barracuda Green 2TB SATA 6Gb/s Hard Drive - OEM (ST2000DL003) @ £62.99 inc VAT
Barracuda® Green drives from Seagate save you time. Available now with SATA 6Gb/s interface and 64MB cache and combined with the industry's only 5900-RPM spin speed, you can be sure you're getting the best performance in the green-power drive category.
Seagate SmartAlign™ technology simplifies your transition to the Advanced Format (AF), 4K standard. There is no need for time-consuming integration utilities required by similar AF drives.
- Direct Attached Storage devices–USB/FireWire/eSATA
- Network Attached Storage devices and Windows storage servers
- Eco friendly PCs
- High-capacity desktop storage
Features
- A unique 5900-RPM speed delivers the fastest-performance eco friendly drive available.
- Seagate SmartAlign technology allows you to get all the benefits of the new Advanced Format 4K sector standard without any hassle–no utilities, no extra steps.
- The SATA 6Gb/s interface and 64MB cache maximize performance.
- Low power consumption combined with leadership in the use of environmental compliance materials means you don't have to sacrifice environmental stewardship for performance.
- Cool, quiet operation
- Capacity: 2TB
- Interface: SATA 6Gb/s
- Spindle speed: 5900RPM
- Cache size: 64MB
- Warranty: 3 Years
Was £66.98 Inc. VAT
Only £62.99 inc VAT.
ORDER NOW
Plantronics GameCom 377 Gaming Headset (79731-05) @ £22.78 inc VAT
Because your hardware should be as powerful as your gaming skills, the GameCom 377 gaming hedset delivers rugged construction and vigorous sound. A lightweight frame and specially designed ear pods redistribute pressure for maximum comfort, while the open-ear design lets you catch all the in-game sound effects without losing touch with your surroundings. When you’re ready to fire off orders, unveil the hidden, noise-cancelling microphone boom to strategise clearly with team members. Responses coming in? Adjust audio levels using in-line volume and mic-mute controls. When you’re done, rotate and tuck the microphone boom inside the headset - then let your score do the talking.
- Open-ear design keeps you connected to the game and your surroundings.
- Concealed mic boom stays hidden until you’re ready to use it.
- Specially designed ear pods redistribute pressure for maximum comfort.
- In-line volume and mic-mute controls allow for easy audio adjustment.
- Noise-cancelling microphone lets you communicate clearly.
- Rugged, military-like design and extra-strength cables make your hardware hardcore.
Was £24.98 Inc. VAT
Only £22.78 inc VAT.
ORDER NOW
Roccat Kone+ 6000DPI Max Customization Gaming Mouse @ £59.99 inc VAT
With a 6000dpi Pro-Aim Laser Sensor and its integrated Tracking & Distance Control Unit (TDCU), the further development of the prize-winning ROCCAT™ Kone Gaming Mouse has unbelievably more power under the hood. Its maximum precision and ultimate tracking are beyond comparison.
The massive upgrade made to the driver and the introduction of the EasyShift[+] button has also turned the Kone[+] into a real customizable marvel at the same time. No other mouse offers as many configuration options as the ROCCAT Kone[+].
MAXIMUM PERFORMANCE
The revolutionary 6000dpi Pro-Aim Laser Sensor, in conjunction with its 10.5 megapixel resolution and 1000Hz polling rate, offers maximum precision, even transmitting lightning fast mouse movements with up to 30Gs of acceleration and with speeds of up to 200ips (5.08m/s) without loss or lag. Thanks to the Tracking & Distance Control Unit, which is now integrated in the laser sensor, the ROCCAT™ Kone[+] can also calculate the lift-off distance as well as fine-tune the sensor to suit the mousepad. The result: optimal tracking.
ERGONOMIC HYBRID SHELL
The highly praised hybrid shell for right-handers, including the Soft-Touch Surface, have been retained, but really useful core improvements have been made that further increase the comfort of Kone’s successor. The mouse wheel is completely new: distinctive notch positions are perfect for gaming, and the wider design makes it easier to control. The button above the mouse wheel has been made larger and you’ll now find a nicely-sized toggle switch below the mouse wheel. The result: maximum gaming comfort.
22 MOUSE FUNCTIONS
Thanks to the EasyShift[+] button, all the buttons – including the mouse wheel – can be assigned two functions such as macros or other functions. As a result, you now have 22 functions available at any one time instead of the usual 12.
Find out more about EasyShift[+] and just how easy it is to use here: mehr...
4 LED MULTICOLOR LIGHT SYSTEM
Like before, the light system remains unbeaten. Four multicolor LEDs, together with the enhanced lightpipes and configurable effects, can light up, alternate or pulsate in more than four different colors at the same time. It’s a real eye-catcher on any desktop.
5 GAME PROFILES
You can configure your button assignments, including macros, DPI settings, the sensor sensitivity level and your lighting settings too, and save them to any one of 5 profiles on the 576kB of onboard memory. This allows you to customize your mouse to suit individual games. You can associate each profile with a particular application so the right button assignments, DPI and color settings, etc., are automatically loaded when you start the game. When a profile is set as the Windows Profile, the ROCCAT™ Kone[+] will always switch to this profile when you return to Windows after leaving a game or app. Additional profiles can be saved on your hard drive whenever you want, and then loaded to any one of the 5 profile slots using the driver menu.
MACRO MANAGER
Creating and editing your own command sequences is made easy thanks to the highly praised Macro Manager. Predefined macro presets for the top 20 PC games as well as several office apps make it even easier to customize the mouse – plus the new Loop Function now makes it possible to loop macros indefinitely.
SOUND FEEDBACK
The famous ROCCAT voice gives immediate feedback when you change DPI settings, profiles, the volume level or sensitivity setting. As you don’t need to look at an additional display on the screen or on the mouse itself, nothing will distract from the gameplay. It really is as easy at that.
CUSTOMIZE THE WEIGHT
A weight system comprising 4 x 5g weights is included, allowing you to customize the weight in four stages to suit your preferences.
Was £68.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Steelseries Siberia v2 - Red @ £65.99 inc VAT
Based on the award-winning SteelSeries Siberia Full-size Headset, the v2 features major enhancements in sound quality, comfort and its microphone. Every element of the v2 has been optimized for pro gaming, making the headset a preferred piece of equipment for the worlds' best competitive PC gamers - the most demanding headset users in the world.
Sporting 25% larger 50mm driver units, the SteelSeries Siberia Full-size Headset dramatically boosts overall acoustic performance. Experience a rich and detailed soundscape from immersive atmospheric background music to precise 3D positional sounds of footsteps, gunfire and more.
The close type ear cups feature thick leather padded cushions built from sound dampening foam, designed to offer passive noise reduction from loud surroundings and improve comfort over prolonged use. A virtually invisible uni-directional microphone can be retracted from the left ear cup, optimized for essential voice communications.
The v2 remains lightweight and its trademark headband suspension construction makes it extremely comfortable for use over long periods of time.
- Closed type headphones.
- Pull-out microphone.
- Crystal clear high, low and mid-tones.
- 50mm driver units.
- Lightweight suspension construction.
- Sleek RED colour
- 2 years warranty
Was £72.97 Inc. VAT
ORDER NOW
"Titan Krypt" AMD Athlon II X4 640 3.00GHz Quad Core DDR3 System @ £456.77 inc VAT
The "Titan Krypt" features a AMD Athlon II X4 Quad Core 640 3.00GHz Processor, combined with a selection of high performance, handpicked components designed to meet your desire for the perfect gaming system.
Why Should You Buy This System?
- Includes the superb AMD Athlon II X4 640 3.00GHz Quad Core Processor
- 4GB of high performance gaming memory guarantees the smoothest possible experience when multitasking and ensures you never have a break in the action
- Case: Antec 300 Gaming Case
- Power Supply: OCZ 600w StealthXStream II
- CPU: AMD Athlon II X4 Quad Core 640 3.00GHz Processor
- Motherboard: Asus M4A78LT-M 760G (AM3) Motherboard
- RAM: Corsair Dominator 4GB (2x2GB) DDR3 PC3-12800C9
- Hard Drives: Seagate Barracuda 1TB 6GB/s SATA-II 16MB Cache
- Graphics Card: Choice of the latest DirectX 10 and 11 graphic cards
- Sound: 7.1 Channel Sound (On-Board)
- Optical Drive: OcUK 22x DVD±RW SATA ReWriter (Black)
Service Package
If your after the latest in AMD technology then this system is for you. Quad core technology and DDR3 perforamnce at an excellent price point.
Was £475.97 Inc. VAT
Only £456.77 inc VAT.
ORDER NOW
TT Esports Gamers Headset Shock - White @ £32.39 inc VAT
nonl2br
The TT Esports Gamers Headset Shock brings gaming to a new level. Immerse deeply into your games with 40mm speaker drivers and stereo surround sound. Take advantage of your soundcard with 3.5mm speaker jacks bringing maximum sound performance. The ultra comfortable padded earcups make sure that comfort is key, especially for intense professional gaming. <br><br>
- Stereo surround sound<br>
- Quality 40mm speaker driver with enhanced bass performance<br>
- Noise cancelling microphone for communciation in gaming activities<br>
- Control Box with In-line control box for instant gaming sound control<br>
- 10 Levels adjustment for a perfect fit<br>
- Foldable design<br>
- Gold plated 3.5mm connctor<br>
<br>
<br>
<iframe title="YouTube video player" width="640" height="390" src="http://www.youtube.com/embed/2gampqTGEf8" frameborder="0" allowfullscreen></iframe>
Was £34.98 Inc. VAT
Only £32.39 inc VAT.
ORDER NOW
Hitachi Deskstar 7K3000 3TB SATA 6Gb/s 64MB Cache 7200RPM - OEM @ £129.98 inc VAT
The Deskstar™ 7K3000 is Hitachi’s first hard drive to deliver an enormous three terabytes of storage capacity and 7200 RPM performance in a standard 3.5-inch form factor. The 7K3000 is also the first Hitachi hard drive with a 6Gb/s SATA interface, which along with its 64MB cache buffer delivers a big boost to performance over the previous generation product.
- Backwards compatible with SATA-II
- Part Code: HDS723030ALA640
- Capacity: 3TB
- Cache: 64MB
- Spin Speed: 7200RPM
- Bootable with Sandybridge P67/H67 Motherboards
- Warranty: 3 Years
NOTE: These drives are only bootable on 64bit versions of windows Vista and 7 as well as OSX and Linux. These will work as storage on 32bit versions.
Only £129.98 inc VAT.
ORDER NOW
TT Esports Gamers Headset Shock - Black @ £32.39 inc VAT
nonl2br
<br>
<br>
Was £37.99 Inc. VAT
ORDER NOW
Speedlink Spes Clip-On Metal Microphone (SL-8691-SBK) @ £5.99 inc VAT
The microphone is attractively designed and is extremely practical. The noise-suppression system filters out bothersome background noises and makes internet chat easy and uncomplicated. Furthermore, the clothing clip allows you to clip the mic anywhere you like.
- Lots of freedom of movement thanks to the 2.4m cable
- You'll hardly notice you're wearing the mic thanks to it's low weight
- Easy to attach to clothing thanks to the clip
- Highly sensitive microphone featuring noise suppression
- Robust design made from black metal
Was £6.50 Inc. VAT
Only £5.99 inc VAT.
ORDER NOW
Western Digital Caviar Blue 500GB SATA 6Gb/s 16MB Cache - OEM (WD5000AAKX) @ £29.99 inc VAT
nonl2br
<center>
<div id="docview"><object classid="clsid
27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,28,0" width="728" height="90"><param name="movie" value="http://wdbrand.com/collateral/bannerad/Desktop/6Gb_728x90_EN.swf" /><param name="quality" value="high" vmode=transparent /><embed src="http://wdbrand.com/collateral/bannerad/Desktop/6Gb_728x90_EN.swf
" quality="high" pluginspage="http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash" type="application/x-shockwave-flash" width="728" height="90"></object></div></center>
<br>
WD Caviar Blue hard drives are available with a multitude of available features to deliver rock solid performance and ultra-cool and quiet operation. Pick the drive that suits your needs with the confidence in knowing that all WD Caviar Blue drives are built to the highest standards of quality and reliability. These drives are the perfect solution for family and business computing.
<br>
<br>
<br>
- Capacity: 500GB
<br>
- Cache: 16MB
<br>
<br>
<br>
- Seek Time: 8.9ms
<br>
- Warranty: 3 Years
<br>
<br>
Was £32.99 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Saitek PZ52P VGA Webcam - Pink @ £3.30 inc VAT
This great value webcam which is fully compatible with laptops, netbooks and desktop PCs is perfect for video messaging applications. Keep in contact with your friends, family and loved ones.
- Easy Capture, click and send
- 640 X 480 resolutions
- Broadcast live video over the web
- Great for video chat, video mail & video conferencing
- Works with MSN, Yahoo, Windows Messenger & more
Was £3.59 Inc. VAT
Only £3.30 inc VAT.
ORDER NOW
Trust Invido VGA Smart Clamp Webcam (16430) @ £7.80 inc VAT
Stylish webcam that works with all chat programs such as MSN/Live Messenger, Skype & online video applications. With a smart intergrated clamping system, easily attach the webcam to notebook screens, flat panel display or just to sit on flat surfaces.
- USB webcam with 640 x 480 hardware resolution
- 1.3 megapixel snapshot resolution
- Snapshot button to quickly take a picture
- 2x digital zoom and automatic face tracking technology
- Ideal for Live Messenger, MSN Messenger, Skype and other messenger services
- The camera stand can also be used to attach the webcam to the screen of a notebook or desktop PC
Was £8.39 Inc. VAT
Only £7.80 inc VAT.
ORDER NOW
Rift 60 Day Timecard - Digital Email Delivery @ £16.20 inc VAT
The prepaid gamecard is a comfortable payment method to receive 60 additional days of gametime for RIFT. Follow the included descriptions and you are ready to play again in a few minutes.
After the expiration of the 60 days, the subscriptions fee has to be paid again – or you extend your gametime again with a Game Card. The full version of RIFT and an internet connection are needed to play.
Digital email delivery (no shipping cost)
Was £16.98 Inc. VAT
Only £16.20 inc VAT.
ORDER NOW
Thrustmaster T500 RS Simulator Racing Wheel for PS3 & PC (Licensed for Gran Turismo 5) @ £379.98 inc VAT
H.E.A.R.T. HALLEFFECT ACCURATE TECHNOLOGY™” is the name of the new technology developed by Thrustmaster to reproduce movements made on a product in games. It relies on magnetic – and not mechanical – 3D (HallEffect) sensors, placed in different locations according to the product in question. The precision made possible by the use of this technology is significantly higher than that provided by standard technologies. Another advantage of this system: by eliminating all friction, it guarantees zero mechanical wear, for permanent precision that won’t decrease over time. The level of precision is also enhanced by the absence of any dead zones: even the slightest movement made by the player results in a reaction. Actions in games are therefore more linear, smoother and without any untimely jolts.
- Authentic wheel: 30cm (12”) in diameter with brushed metal central spokes
- Authentic sequential gearshift levers: crafted of brushed metal, attached to the base (so they don’t move with the wheel)
- 17cm in height (for instant access along 1080°)
- Precision, Force Feedback & realistic angle of rotation
- New H.E.A.R.T Hall Effect AccuRate Technology™ on the wheel’s steering:
- Ultra-precise wheel, with 16-bit resolution (65536 values on the steering)!
- Precision that won’t decrease over time (contactless magnetic sensor)
- Force Feedback with industrial motor (Torque 150mNm, 3000rpm, 65W, Ø 52mm/2”)
- Super-powerful, quick responding Force Feedback mechanism
- Rigid motorized stopper, no matter what angle of rotation you select
- Mechanism with large dual belts (fluid and smooth action)
- Angle of rotation adjustable up to 1080° (3 full turns)!
- Realistic pedal set
- Unique design with your choice of 2 positions:
- Floor-mounted position (F1-style)
- Suspended position (GT-style)
- 100% metal, for optimal stability, weight (more than 7 kgs) and resistance
- 3 100% adjustable pedals (spacing between the pedals/height)
- Brake pedal with reinforced and adjustable resistance (included and removable “Realistic Brake” mod)
- Included metal footrest with non-slip grating texture
Was £399.98 Inc. VAT
Only £379.98 inc VAT.
ORDER NOW
Samsung SpinPoint F4 EcoGreen 2TB SATA-II 32MB Cache - OEM (HD204UI) @ £62.99 inc VAT
Samsung's F4 EcoGreen is the first drive available to feature 667GB per platter. Samsung’s F4 Series EcoGreen Drive (F4EG) is the ideal high capacity drive for green computing environments. The new eco-friendly hard drive, F4EG is designed to meet demand for high performance devices with lower power consumption. Samsung’s EcoGreen F4 makes it possible to design storage systems with the right balance of high capacity, fast performance and energy conservation. Samsung F4EG has the world’s best areal density at 5400RPM rotation speeds. High density means more bits pass under the head faster, and it improves the drive performance. Samsung employs an advanced data recording technology, which brings the next generation technology into today’s single disk platform, enabling Samsung’s new 5400RPM drives to perform at current 7200RPM drive speeds. The internal SysMark test results confirms that F4EG performs as same as 7200RPM drive speeds, and even 10% faster than other green drives.
- Capacity: 2TB
- Cache: 32MB
- Interface: SATA-II
- Spin Speed: 5400RPM
- Seek Time: 8.9ms
- 3.5" Drive
- Warranty: 3 Years
Was £65.99 Inc. VAT
ORDER NOW
OcUK Value 320GB 2.5" Mobile Hard Drive External USB2.0 @ £37.99 inc VAT
The OcUK Value 320GB USB external hard disk is small in size for exceptional portability. USB powered with no bulky power adapter required coupled with an 5400rpm hard drive.
Key Features
- High Speed USB 2.0
- 5400rpm Spin Speed
- 2.5" Form Factor
- No External Power Supply Required
- USB Bus Powered
- Maximum Reading Transfer Rate - 33 MB/s
- Maximum Writing Transfer Rate - 35.5 MB/s
- 8MB Cache
- Supported Operating Systems: Microsoft Windows 98/SE/ME/2000/XP/Vista/7, Mac OS X 10.x, Linux 2.4x
Was £39.98 Inc. VAT
Only £37.99 inc VAT.
ORDER NOW
OcUK Value 500GB 2.5" Mobile Hard Drive External USB2.0 @ £44.99 inc VAT
The OcUK Value 500GB USB external hard disk is small in size for exceptional portability. USB powered with no bulky power adapter required coupled with an 5400rpm hard drive.
Key Features
- 2.5" Form Factor
- USB Bus Powered
- 8MB Cache
Was £46.99 Inc. VAT
Only £44.99 inc VAT.
ORDER NOW
OcUK Value 1TB 2.5" Mobile Hard Drive External USB2.0 @ £72.98 inc VAT
- 1TB USB external hard disk with small size for exceptional portability
- USB powered; no bulky power adapter required
- 5400 rpm spin rate; 8 MB cache; and transfer rate of up to up to 480 Mbits per second
Key Features
- 2.5" Form Factor
- USB Bus Powered
- 8MB Cache
Was £74.99 Inc. VAT
ORDER NOW
Philips SPA2602 5.1 Surround Sound Speaker System @ £34.99 inc VAT
Perfect for MP3, PC, TV and more.
Connect your speakers to all your gear. A great way to listen to your MP3 player, PC, TV, CD, DVD and all your multimedia stuff.
Sound
- Bass enhancement: Analogue Bass Boost, Bass reflex
- Frequency response: 35 - 20 K Hz
- Loudspeaker Enhancement: Magnetic Shielded LSB
- Music Power: 90 W
- Volume Control: Analogue Volume Control
- Wires: Fixed Wires
- Output power (RMS): 45 W
Loudspeakers
- Satellite speaker drivers: 3"
- Subwoofer driver: 4.25"
Connectivity
- Audio input for data: Stereo Audio (3.5 mm jack) 1 x
- Cable length: 1.5 m
- Connector: 3.5 mm stereo
Was £39.98 Inc. VAT
Only £34.99 inc VAT.
ORDER NOW
Xenon AMD Phenom II X6 1055T 2.80GHz Bundle - Six Core @ £219.98 inc VAT
Designed by experts the "Xenon AMD Phenom II X6 1055T Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "Xenon AMD Phenom II X6 1055T Bundle" offers you speed and silence in perfect combination.
Why You Should Buy This Bundle?
- Prebuilt and configured. Just "plug and play"
- 4GB of Dual Channel DDR3 memory delivers fast load times
Bundle Specification
- CPU: AMD Phenom II X6 Hex Core 1055T 2.80GHz
- Motherboard: Gigabyte GA-M68MT-S2 (Socket AM3) DDR3 Motherboard
- RAM: GEIL Value (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel
- Cooler: AMD Stock Cooler
Service Package
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Was £239.98 Inc. VAT
Only £219.98 inc VAT.
ORDER NOW
"Radon Allosaur" Intel Core i5 2500K 3.30GHz @ 4.40GHz Overclocked Bundle - Asus @ £449.98 inc VAT
Designed by experts the "Radon Allosaur Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.40GHz overclock has the processing power and speed unseen at this price point ever before. The "Radon Allosaur Bundle" will accelerate your computer experience into the next level.
- A solid, optimised 4.40GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 4GB of Dual Channel DDR3 memory delivers unsurpassed bandwidth
- CPU: Intel Core i5 2500K 3.30GHz @ 4.40GHz Sandybridge CPU
- Motherboard: Asus P8P67 PRO Intel P67 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
- Cooler: Corsair A50 CPU Cooler
- Artic Silver 5 Thermal Compound
Service Package
Was £489.98 Inc. VAT
Only £449.98 inc VAT.
ORDER NOW
"Krypton Ankylosaur" Intel Core i7 2600K 3.40GHz @ 4.60GHz Overclocked Bundle - Asus @ £549.98 inc VAT
Designed by experts the "Krypton Ankylosaur Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.60GHz overclock has the processing power and speed unseen at this price point ever before. The "Krypton Ankylosaur Bundle" will accelerate your computer experience into the next level.
- A solid, optimised 4.60GHz overclock profile provides outstanding processing performance
- USB3, SATA 6GB/s, Intel Ethernet and UEFI graphical BIOS for next gen computing
- CPU: Intel Core i7 2600K 3.40GHz @ 4.60GHz Sandybridge CPU
- Motherboard: Asus P8P67 DELUXE Intel P67 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
Service Package
Was £579.00 Inc. VAT
Only £549.98 inc VAT.
ORDER NOW
Asus Xonar DG 5.1 PCI Sound Card with built in Headphone Amp @ £24.98 inc VAT
The Xonar DG sound card combines Dolby Headphone 5.1 high definition surround with Asus’ own GX 2.5 gaming audio engine and an on-board headset amplifier. These result in accurate and deep audio that brings every nuance and sound across fully, making the new Xonar DG an ideal sound card for gamers who want to remain totally aware of their play environments.
- Built-in Headphone AMP
- Powers up every sound detail in gaming
- 3 gain modes for different usage scenarios
- Dolby Headphone for an immersive 5.1 surround imaging
- GX2.5 for realistic 3D audio effects
Was £26.99 Inc. VAT
Only £24.98 inc VAT.
ORDER NOW
ASRock M3A770DE AMD 770 (Socket AM3) DDR3 Motherboard @ £49.99 inc VAT
Devoting efforts to bring customers the innovative and reliable motherboards with the design concept of 3C, "Creative, Considerate, Cost-effective", ASRock has successfully established a well-known leading brand of the best price-performance motherboard in the industry. ASRock products' high recognition stems from company’s devotion to bring the most cost-performance products to users.
- Support for Socket AM3 processors: AMD Phenom II X6 / X4 / X3 / X2 (except 920 / 940) / Athlon II X4 / X3 / X2 / Sempron processors
- Northbridge: AMD 770
- Southbridge: AMD SB710
- 4 x DDR3 1600(OC)/1333/1066/800MHz DIMM slots
- 7.1 CH HD Audio
- Realtek RTL8111DL Gigabit LAN
- 2 x PCI Express 2.0 x16 slots (green @ x16 mode, orange @ x4 mode)
- Supports ATI™ CrossFireX
- 1 x PCI Express 2.0 x1 slot
- 3 x PCI slots
- 4 x SATA-II 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, and JBOD)
- 1 x ATA133 IDE connector (supports 2 x IDE devices)
- 1 x Floppy connector
- 10 x USB 2.0
- 1 x PS/2 Mouse Port
- 1 x PS/2 Keyboard Port
- 1 x Coaxial SPDIF Out Port
- 1 x Optical SPDIF Out Port
- 2 x Powered eSATAII/USB Connectors
Was £53.99 Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
That time of week when we slash prices to help save you money whilst building your dream pc.
Intel Core i3 550 3.20GHz (Clarkdale) (Socket LGA1156) - Retail @ £94.79 inc VAT
The wait is over - now everyone can move up to smart performance. As the first level in Intel’s new processor family, the new 2010 Intel Core i3 processor is the perfect entry point for a fast, responsive PC experience. The new 2010 Intel Core i3 processor also features Intel Hyper-Threading Technology, which enables each core of your processor to work on two tasks at the same time, delivering the performance you need for smart multitasking. Don’t let too many open applications slow you and your PC down. Get smart performance now.
- Lithography Process: 32nm
- Cores: 2
- Threads: 4
- Frequency: 3.20GHz
- Integrated Graphics Frequency: 733MHz
- Cache: 4MB Shared L3
- Memory Controller: Dual Channel DDR3 800/1066/1333MHz
- TDP: 73w
- Socket: LGA1156
Was £104.99 Inc. VAT
Only £94.79 inc VAT.
ORDER NOW
Intel Celeron Dual Core E3400 "LGA775" 2.60GHz (800FSB) - Retail @ £33.59 inc VAT
Take basic computing to new levels with the Intel® Celeron® dual-core processor. Because many software applications for everyday tasks are now designed for dual-core processors, users can be more creative and productive in the home, office, or classroom. In addition, security and virus protection often means running more than one application at a time, and the Celeron dual core processor has the power to run them simultaneously. Based on energy-efficient micro architecture, the Celeron dual-core processor delivers superior energy-efficient dual-core performance.
- Dual Core Technology
- 2.60GHz clock speed
- 1024MB L2 Cache
- Cooler running technology, less heat and less noise!
- Supplied with Intel referance heatsink & fan
Was £36.98 Inc. VAT
ORDER NOW
Intel Pentium Dual-Core E6500 "LGA775 Core 2" 2.93GHz (1066FSB) - Retail @ £59.99 inc VAT
Do extraordinary things with everyday computing when you multitask your favorite music, photo and office applications with a PC running the Intel Pentium dual-core processor. Expand your computing options with two processing cores. And you’ll enjoy that performance with a minimum of power and noise. Enhanced Intel SpeedStep Technology allows your system to dynamically adjust processor voltage and core frequency, enabling decreased power consumption and heat production. And since less heat means less fan noise, you’ll also experience improved acoustics. Plus, you get the protection of built-in Execute Disable Bit designed to help keep your PC safe from viruses, worms and other malicious attacks.1 And with proven Intel technology, you get a level of quality and reliability only the leader in processors for desktop computing can provide.
- Core2-based CPU
- 2.93GHz clock speed
- 2MB L2 Cache
- Intel Speedstep Technology
- EM64T 64-Bit Technology
- Execute Disable Bit
Was £64.99 Inc. VAT
ORDER NOW
Intel Core i5-2300 2.80GHz (Sandybridge) Socket LGA1155 Processor - Retail @ £137.99 inc VAT
Intel's new Sandybridge based CPU's is a complete new refresh that requires new socket LGA1155 mainboards. This new platform uses less power and has vastly superior integrated graphics. The HD2000 graphics is capable of all multimedia task featuring DirectX 10.1 runtime making them ideal for gamers too. The K series edition processors are unlocked on the multiplier allowing overclocking and also feature HD3000 onboard graphics which feature twice the horsepower of the HD2000 making them ideal for gamers and have support for 3D Gaming. The new Sandybridge K series processors also feature immense overclocking as well.
- Lithography Process: 32 nm
- Cores: 4
- Threads: 4
- Frequency: 2.80 GHz (Turbo Mode 3.10GHz)
- Integrated HD 2000 (6 EUs) Graphics
- Integrated Graphics Frequency: 850MHz (1100MHz Turbo)
- Cache: 6 MB shared L3
- Memory Controller: Dual channel DDR3 800/1066/1333/1600 MHz
- TDP: 95W
- Socket: LGA1155
- Compatible with Socket 1156 heatsinks
- 3yr Warranty
***OVERCLOCKING GUIDELINES***
- Do not exceed 1.35-1.38v core voltage, doing so could limit lifespan of the CPU
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
Was £147.98 Inc. VAT
Only £137.99 inc VAT.
ORDER NOW
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor @ £167.99 inc VAT
- Unlocked Multiplier
- Cores: 4
- Threads: 4
- Frequency: 3.30 GHz (Turbo Mode 3.70GHz)
- Integrated HD 3000 (12 EUs) Graphics
- TDP: 95W
- Socket: LGA1155
- 3yr Warranty
Was £179.99 Inc. VAT
Only £167.99 inc VAT.
ORDER NOW
Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor @ £239.99 inc VAT
- Cores: 4
- Threads: 8
- Frequency: 3.40 GHz (Turbo Mode 3.80GHz)
- Integrated Graphics Frequency: 850MHz (1350MHz Turbo)
- Cache: 8 MB shared L3
- TDP: 95W
- Socket: LGA1155
- 3yr Warranty
Was £263.99 Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
AMD Phenom II X4 Quad Core 955 Black Edition "125W Edition" 3.20GHz (Socket AM3) - Retail @ £95.99 inc VAT
The AMD Phenom II processors are the most advanced processors for true multitasking offering true quad-core design. AMD Phenom II processors deliver virtually uninterrupted information flow between processor cores, main memory and graphics and video accelerators for amazingly rapid system response and phenomenal system performance. AMD Phenom II processors deliver unbeatable multi-core value with superior high definition computing, advanced multitasking performance, and innovative, energy efficient solutions.
- 3.20GHz clock speed
- 2MB L2 cache
- 6MB L3 cache
- DDR3-1333 support
- 45nm process technology (125W Edition)
- True Multi-core Processing
- Direct Connect Architecture
- Integrated Dual-Channel Memory Controller with up to DDR3-1333 support
- HyperTransport 3.0
- AMD Balanced Smart Cache
- AMD Wide Floating Point Accelerator
- AMD Memory Optimizer Technology
- AMD Digital Media Xpress 2.0
- AMD Virtualization with Rapid Virtualization Indexing
- Cool‘n’Quiet 3.0 technology
Was £99.98 Inc. VAT
Only £95.99 inc VAT.
ORDER NOW
AMD Phenom II X4 Quad Core 965 Black Edition "125W Edition" 3.40GHz (Socket AM3) - Retail @ £107.99 inc VAT
- 3.40GHz clock speed
- 2MB L2 cache
- 6MB L3 cache
- DDR3-1333 support
Was £114.98 Inc. VAT
Only £107.99 inc VAT.
ORDER NOW
Corsair Vengeance 6GB (3x2GB) DDR3 PC3-12800C8 1600MHz Triple Channel Kit (CMZ6GX3M3A1600C8) @ £89.99 inc VAT
CORSAIR high performance Vengeance memory module 6GB (3x2GB) 1600MHz 8-8-8-24, CL8, 1.5V for motherboards using Intel triple channel processors. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each three module set is tested at 1600MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 8-8-8-24 on Intel X58 DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 8-8-8-24 values at 1600MHz, 1.50V
- 6144 Megabytes of DDR3 memory
- Three matched 2GB modules
- 100% tested at 1600MHz in X58-based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
Was £94.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
GeIL 6GB (3x2GB) DDR3 PC3-12800C8 1600MHz VALUE PLUS Triple Channel (GVP36GB1600C8TC) @ £47.99 inc VAT
GeIL announces the launch of the all new DDR3 Value PLUS & Ultra PLUS Series to be added to GeILs’ high performance memory line of products. The Value PLUS & Ultra PLUS are equipped with the latest PLUS Edition memory heat-spreader designed with heat-sink surface and extended height for maximum cooling efficiency. The Ultra PLUS line of memory will be carrying over-clocking performance while the Value PLUS line has the more stability-oriented specifications. As GeILs’ quality standard, both series will be enhanced with DBT – Die-hard Burn-in Technology for the highest quality assurance.
- PC3-12800 1600MHz CAS 8-8-8-28
- 240pin, Non-ECC, Un-buffered DDR3 DIMM
- Aluminum Heat-spreader
- 6 Layers Ultra Low Noises Shielded PCB
- 1.5V-1.6V Power Supply
- Lifetime Warranty
- DBT - Die hard burn-in technology (Improved reliability)
Was £53.99 Inc. VAT
Only £47.99 inc VAT.
ORDER NOW
G.Skill RipJawsX 4GB (2x2GB) DDR3 PC3-17000C9 2133MHz Dual Channel Kit (F3-17000CL9D-4GBXL) @ £47.99 inc VAT
G.Skill has announced the development of its brand new RipjawsX series memory modules, designed specifically for Intel Sandy Bridge LGA1155 processors, and H67 and P67 motherboard platforms. The new RipjawsX series consists of a complete range of memory solution, from DDR3 1,333MHz, 1,600MHz, 1,866MHz, 2,133MHz, 2,200MHz to 2,300MHz. Combined with the Intel’s highly anticipated Sandy Bridge platform, G.Skill RipjawsX series memory kits deliver more bandwidth and performance than ever.
Building on the strong success of the first generation Ripjaws brand in performance memory kits, every single RipjawsX memory kit is hand-tested on an Intel Sandy Bridge platform in accordance with G.Skill's strict internal testing procedure, to ensure the best in class performance, compatibility and reliability across a range of popular motherboards. It is the perfect memory solution for PC gamers, performance workstations, enthusiast power users and anyone who loves the cutting-edge of technology!The following list shows the detail specifications of G.Skill RipjawsX family.
Model Name: F3-17000CL9D-4GBXL
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL P67
CAS Latency: 9-11-9-28 2N
Capacity: 4GB (2GBx2)
Speed: DDR3-2133 (PC3-17000)
Test Voltage: 1.55-1.65V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)
Master Pack Weight: 0.26 lbs
Black PCB
Warranty: Lifetime
Was £49.99 Inc. VAT
ORDER NOW
OCZ Special OPS 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (OCZ3SOE1600LV4GK) @ £35.99 inc VAT
Featuring the high densities and stability gamers demand, these DDR3 kits are ideal for users advancing to the next generation of memory platforms, offering the speeds, density, and reliability required for the latest DirectX 10 PC titles. Featuring a unique camouflage motif heatspreader design, the DDR3 Special Ops Edition Series was designed for gaming systems in need of a reliable upgrade as well as some extra style.
The PC3-12800 SOE is available in 4GB low-voltage qualified dual channel kits for the high densities demanded by graphic-intensive games, operating systems, and applications. The Special Ops Edition is the ideal solution for gamers who need high density options in addition to superior reliability and bandwidth management without the hefty price point. These modules offer the stability and speed to give gamers the performance edge with a highly reliable, future-proof system that takes advantage of all high-speed DDR3 has to offer.
100% Hand tested for quality and the unbeatable lifetime warranty will contribute to your peace of mind during even the most intensive gameplay!
Specification:-
- 1600MHz DDR3
- CL 8-8-8-24 (CAS-TRCD-TRP-TRAS) (1.55v-1.65v)
- CL 9-9-9-24 (CAS-TRCD-TRP-TRAS) (1.45v-1.55v)
- Available 4GB Dual Channel Kits
- Unbuffered
- Special Ops XTC Heatspreader
- Lifetime Warranty
- 1.55-1.65 Volts
- 240-Pin DIMM
Was £37.99 Inc. VAT
Only £35.99 inc VAT.
ORDER NOW
HIS ATI Radeon HD 6990 4096MB GDDR5 PCI-Express Graphics Card @ £479.99 inc VAT
Designed for the power gamer, AMD Radeon HD 6990 graphics cards include AMD's second-generation, Microsoft DirectX 11 capable architecture, advanced image quality features for the best looking games, and AMD PowerTune intelligent technology to enable higher clock speeds and faster gaming. The AMD Radeon HD 6990 offers the ultimate in immersive HD gaming and computing with native support for up to five displays using AMD Eyefinity multi-display technology, with six display support possible via DisplayPort 1.2 components available for purchase later this year. The AMD Radeon HD 6990 graphics cards also feature a dual-BIOS toggle switch, allowing enthusiast gamers to unlock the card and rev up the clocks and voltages for even more performance. Finally, AMD HD3D technology provides a cutting-edge stereoscopic 3D gaming and movie experience, thanks to HDMI 1.4a support.
Features:-
- Core Clock: 830MHz (880MHz OC Mode)
- Memory: 4096MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Bandwidth: 320GB/sec
- Processing Cores: 3072
- Texture Units: 192
- ROPS: 64
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual-Link DVI & 4x Mini-Display Port (Adapters supplied to HDMI/DVI)
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 450W (Typical 400W)
- 2x 8pin PCI-E power connectors required
- 700W minimum PSU required (1000-1200W recommended for Crossfire with with four 8 Pin connectors)
- Warranty: 2 Years
Was £499.99 Inc. VAT
Only £479.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 6950 2048MB GDDR5 PCI-Express Graphics Card @ £203.99 inc VAT
The Sapphire HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- ATI Reference Design (Revision: 1) - Flashable too 6970
- Core Clock: 800MHz
- Memory: 2048MB GDDR5
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- ATI Avivo HD
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required (Power Adapters Provided)
- 450W minimum PSU recommended
- Warranty: 2 Years
- Supplied with Mini-DisplayPort too HDMI Cable
- Supplied with 1.8M HDMI High Speed Extension Cable
Was £211.99 Inc. VAT
Only £203.99 inc VAT.
ORDER NOW
HIS ATI Radeon 6950 1024MB GDDR5 PCI-Express Graphics Card @ £173.99 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- Memory: 1024MB GDDR5
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- 2x 6pin PCI-E power connectors required (Power Adapters included in box for older PSU's)
- Warranty: 2 Years
Was £187.99 Inc. VAT
Only £173.99 inc VAT.
ORDER NOW
XFX ATI Radeon HD 5850 1024MB GDDR5 PCI-Express Graphics Card ***Supplied Assasins Creed Game*** @ £119.99 inc VAT
Prepare to experience a riveting high-definition gaming experience with the ATI Radeon HD 5800 Series graphics processors. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
- Core Clock: 725MHz
- Memory Clock: 4000MHz (Effective)
- Memory Bandwidth: 128.0GB/s
- Processing Cores: 1440
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 1 DisplayPort
- HDCP Capable
- OpenGL 3.2 Support
- ATI CrossFireX Ready
- ATI Avivo HD
- 2yr Warranty
Was £124.99 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
HIS ATI Radeon HD 5570 1024MB GDDR3 SILENT PCI-Express Graphics Card (H557HO1G) @ £45.59 inc VAT
The HD 5570 packs 400 Stream processors and is fully compliant with Microsoft's DirectX 11 API, enabling the highest quality effects available on the PC platform today, as well as accelerating ATI Stream compatible applications including a variety of video transcoders and media players to ensure the best possible media viewing experience. Built on an ultra low power 40nm core technology, no additional power connection is required, making the HD 5570 series ideal for system upgrades or mainstream PCs that do not have expensive, high end power supplies.
- Core Clock: 650MHz
- Memory: 1024MB GDDR3
- Memory Clock: 1000MHz (Effective)
- Memory Interface 128 bit
- Processing Cores: 400
- Display Connectors: 1 VGA, 1 Dual-Link DVI-I & 1 HDMI
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Product Code H557HO1G
EAN Code 4895139004465
Cooler Heatsink
GPU 5570
Core Clock 650 MHz
Memory Clock 1000 MHz
Memory Size 1042 MB
Memory Type DDR3
Interface PCI Express x16 (PCI Express 2.1)
Was £49.99 Inc. VAT
Only £45.59 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 590 3072MB GDDR5 PCI-Express Graphics Card with FREE Gaming Mouse @ £575.99 inc VAT
Introducing the new NVIDIA® GeForce® GTX 590 - the most powerful DirectX 11 graphics card ever built. With a sleek exterior that houses dual 512-core GTX 500 GPUs and a custom vapour chamber cooler, the GeForce GTX 590 delivers high-end performance with style. Hook up three monitors with GeForce GTX 590's three dual-link DVI ports to play your favourite games at ultra-wide resolutions like 5760x1080 in NVIDIA Surround. Plus get all the premium GTX gaming technologies such as NVIDIA® 3D Vision™, PhysX®, and Quad SLI® for the ultimate PC gaming experience.
The GIGABYTE M8000Xtreme is a super powerful weapon designed specially for gamers. Equipped with 6000dpi pro-laser engine supports high-speed movement and accurate precision. The onboard GHOSTTM Engine memory is capable of 45 button assignments with macro editing and storing customizable macros that lets you bring your unique settings wherever you go - use them on other PCs without software. The Advanced GHOSTTM Engine software allows gamers to record and edit their
desired scripts which can include complicated keyboard and mouse commands. The Introduction
design concept of the GHOSTTM Engine software is Avatar system based, just like in games. Its Ultra-user-friendlyTM drag and drop structure user interface plus powerful macros on the go will equip any gamer to be competitive in the heat of battle.
- Graphics Engine: GeForce® GTX590
- Bus Standard: PCI Express® 2.0
- Video Memory: 3072MB GDDR5
- Engine Clock: 607 MHz
- CUDA Cores: 1024
- Memory Clock: 3414MHz (855MHz GDDR5)
- Memory Interface: 384 bit x 2
- DVI Max Resolution: 2560 * 1600
- DSub Max Resolution: 2048 * 1536
- D-sub Output: 1 x via DVI-to-D-Sub adapter
- DVI Output: 3 x Dual Link DVI-I Native
- HDMI Output: 1x HDMI via DVI-to-HDMI adapter
- Display Port Output: 1x Mini DisplayPort Native
- HDCP compliant: YES
- Dimensions: 11” x 4.5”
- 3yr Warranty
IMPORTANT: The supplied Geforce Drivers 267.52 for Geforce GTX 590 will not stop the card from overheating when overclocking. Please use newer versions from the Nvidia website and stay away from 267.52.
Was £599.99 Inc. VAT
Only £575.99 inc VAT.
ORDER NOW
OcUK Value GeForce GTX 460 1024MB GDDR5 PCI-Express Graphics Card @ £119.99 inc VAT
Built from the ground up for DirectX 11, GeForce GTX 460 delivers the ultimate next generation gaming experience. With up to 4x the DirectX 11 tessellation performance of the competition, GTX 460 packs highly detailed visuals into your games - without sacrificing high frame rates. And with NVIDIA 3D Vision, PhysX, and CUDA technologies, GeForce GTX 460 powers all the incredibly realistic effects that your games can throw its way.
- Core Clock: 675MHz
- Memory Clock: 3600MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 336
- Shader Clock: 1350MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 1x VGA, 2x Dual-Link DVI-I & 1x HDMI 1.3a
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 2 Years
ORDER NOW
Intel 320 Series 40GB 2.5" SATA-II 25nm Solid State Hard Drive - Retail @ £71.99 inc VAT
Intel Solid-State Drives represent a revolutionary breakthrough that delivers a giant leap in storage performance. Intel Solid-State Drives are designed to satisfy the most demanding gamers, media creators, and technology enthusiasts. These new drives bring a high level of performance and reliability to notebook and desktop PC storage, at a fraction of the cost of the previous generation of Intel SSD products. Drawing from decades of memory engineering experience, and new, industry-leading compute-quality 25nm NAND flash memory manufacturing processes, Intel Mainstream SATA SSDs are designed to deliver outstanding performance, featuring the latest-generation native SATA interface with an advanced architecture employing 10 parallel NAND flash channels equipped with multi-level cell NAND flash memory. With powerful Native Command Queuing to enable up to 32 concurrent operations, Intel Mainstream SATA SSDs deliver higher input/output per second and throughput performance than other SSDs on the market today - and drastically out-perform traditional hard disk drives. These drives also feature low write amplification and a unique wear-leveling design for higher reliability, meaning Intel drives not only perform better - they last longer.
- Capacity: 40GB
- Controller: Intel
- Read: Up to 200MB/sec
- Write: Up to 45MB/sec
- NAND Flash: 25nm Multi-Level Cell (MLC)
- Low Power Consumption
- Lightweight (80g)
- Shock Resistant
Was £76.79 Inc. VAT
Only £71.99 inc VAT.
ORDER NOW
Intel 320 Series 80GB 2.5" SATA-II 25nm Solid State Hard Drive - OEM @ £119.99 inc VAT
- Capacity: 80GB
- Controller: Intel
- Read: Up to 270MB/sec
- Write: Up to 90MB/sec
- Lightweight (80g)
- Shock Resistant
Was £131.99 Inc. VAT
ORDER NOW
Intel 320 Series 80GB 2.5" SATA-II 25nm Solid State Hard Drive - Retail @ £131.99 inc VAT
- Capacity: 80GB
- Controller: Intel
- Lightweight (80g)
- Shock Resistant
Was £141.59 Inc. VAT
Only £131.99 inc VAT.
ORDER NOW
OCZ Agility Series 60GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-1AGT60G) @ £65.99 inc VAT
Offering your system the incredible performance of flash-based storage, the OCZ Agility Series delivers the performance and reliability of SSDs at less price per gigabyte than other high speed offerings currently on the market. The OCZ Agility Series is the result of all the latest breakthroughs in SSD technology, including new architecture and controller design, blazing read/write speeds, and 64MB of onboard cache. Designed for ultimate reliability, Agility Series SSDs have an excellent 1.5 million hour mean time before failure (MTBF) ensuring peace of mind over the long term. All Agility Series SSD drives come backed a two year warranty and OCZ’s legendary service and support.
- Capacity: 60GB
- Cache: 64MB
- Read: Up to 230MB/sec
- Write: Up to 135MB/sec
- NAND Flash: Multi-Level Cell (MLC)
- Lightweight (77g)
- Shock Resistant
- RAID Support
- TRIM Support
- OCZ Garbage Collection
- Warranty: 2 Years
Was £69.98 Inc. VAT
Only £65.99 inc VAT.
ORDER NOW
OCZ Vertex 60GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-1VTX60G) @ £74.39 inc VAT
Offering your system the incredible performance of flash-based technology, the OCZ Vertex Series delivers the performance and reliability of SSDs at less price per gigabyte than other high speed offerings currently on the market. The OCZ Vertex Series is the result of all the latest breakthroughs in SSD technology, including new architecture and controller design, blazing 230MB/sec read and 135MB/sec write speeds and featuring 64MB onboard cache. The OCZ Vertex drives feature a durable yet lightweight alloy housing, and because OCZ SSDs have no moving parts, the drives are more rugged than traditional hard drives. Designed for ultimate reliability, Vertex Series SSDs have an excellent 1.5 million hour mean time before failure (MTBF) ensuring peace of mind over the long term.
- Capacity: 60GB
- Cache: 64MB
- Controller: Indilinx Barefoot
- Lightweight (77g)
- Shock Resistant
- TRIM Support
- RAID Support
- Warranty: 3 Years
Was £79.99 Inc. VAT
Only £74.39 inc VAT.
ORDER NOW
OCZ Vertex 2E 60GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTXE60G) @ £98.39 inc VAT
Based on a cutting-edge new architecture, Vertex 2 Solid State Drives raise the bar once again and deliver unprecedented performance for the complete gamut of gaming and professional multimedia applications. OCZ designed the Vertex 2 to surpass the competition where it counts most, pushing the limits in both sequential and random read/write rates. With spectacular performance in 4k file writes up to 50,000 IOPS, these latest drives take productivity to the next level with over ten times the performance of the previous generation. Using the latest controller technology, Vertex 2 not only provides a faster, more responsive PC experience, but promotes cooler, quieter, and more energy efficient conditions compared to traditional mechanical hard drives. OCZ Vertex 2 SSDs come backed by a 3-year warranty and 2 million hour MTBF for ultimate peace of mind.
- Capacity: 60GB
- Controller: SandForce SF-1200
- Maximum Read: 285MB/sec
- Maximum Write: 275MB/sec
- Sustained Write: 250MB/sec
- Max I/O Per Second (IOPS): 50000 IOPS (4KB File)
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Was £101.99 Inc. VAT
Only £98.39 inc VAT.
ORDER NOW
OCZ Agility Series 120GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-1AGT120G) @ £122.39 inc VAT
- Capacity: 120GB
- Cache: 64MB
- Lightweight (77g)
- Shock Resistant
- RAID Support
- TRIM Support
- Warranty: 2 Years
Only £122.39 inc VAT.
ORDER NOW
OCZ Agility Series 250GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-1AGT250G) @ £239.99 inc VAT
Offering your system the incredible performance of flash-based storage, the OCZ Agility Series delivers the performance and reliability of SSDs at a lower price per gigabyte than other high speed offerings currently on the market. The OCZ Agility Series is the result of all the latest breakthroughs in SSD technology, including new architecture and controller design, blazing read/write speeds, and 64MB of onboard cache.
Perfect for notebooks and desktops alike, the Agility Series is ideal for energy-efficient mobile computing to extend battery life, increase the speed of access time, and provide a durable alternative to conventional hard disc drives with superior shock resistance. High capacities and low power consuming NAND flash technology provide the necessary performance and battery life boosts generated by the proliferation of mobile gaming and new ultra-thin laptops.
The OCZ Agility drives feature a durable yet lightweight alloy housing, and because OCZ SSDs have no moving parts, the drives are more rugged than traditional hard drives. Designed for ultimate reliability, Agility Series SSDs have an excellent 1.5 million hour mean time before failure (MTBF) ensuring peace of mind over the long term. All Agility Series SSD drives come backed a three year warranty and OCZ's legendary service and support.
Features:-
- Read: Up to 230 MB/s
- Write: Up to 135 MB/s
- 64MB Onboard Cache
- TRIM Support
- Seek Time: < .1ms
- Slim 2.5" Design
- 99.8 x 69.63 x 9.3mm
- Lightweight: 77g
- Operating Temp: 0°C ~70°C
- Storage Temp: -45°C ~ +85°C
- Low Power Consumption: 2W in operation, 0.5W in stand by
- Shock Resistant up to 1500G
- RAID Support
- MTBF: 1.5 million hours
- Compatible with Mac OS X
Was £249.98 Inc. VAT
ORDER NOW
OCZ Vertex Series 120GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-1VTX120G) @ £122.39 inc VAT
Offering your system the incredible performance of flash-based technology, the OCZ Vertex Series delivers the performance and reliability of SSDs at less price per gigabyte than other high speed offerings currently on the market. The OCZ Vertex Series is the result of all the latest breakthroughs in SSD technology, including new architecture and controller design, blazing 250MB/sec read and 180MB/sec write speeds and featuring 64MB onboard cache. The OCZ Vertex drives feature a durable yet lightweight alloy housing, and because OCZ SSDs have no moving parts, the drives are more rugged than traditional hard drives. Designed for ultimate reliability, Vertex Series SSDs have an excellent 1.5 million hour mean time before failure (MTBF) ensuring peace of mind over the long term.
- Capacity: 120GB
- Cache: 64MB
- Read: Up to 250MB/sec
- Write: Up to 180MB/sec
- Lightweight (77g)
- Shock Resistant
- RAID Support
- TRIM Support
- Warranty: 3 Years
Was £129.98 Inc. VAT
ORDER NOW
OCZ Vertex 2E Bigfoot 120GB 3.5" SATA-II Solid State Hard Drive @ £165.59 inc VAT
OCZ Vertex 2 SATA II 3.5” Solid State Drives deliver the same industry-leading performance as the 2.5” edition in a larger, lower cost per gigabyte form factor to easily integrate into desktop applications without the need to install additional hardware.
Designed to excel in both sequential and random read/write speeds up to 50,000 4KB random write IOPS, the 3.5” Vertex 2 maximizes productivity when used as a primary storage or boot drive, minimizing program load times and completing tasks with blazing speed. Using the latest controller technology, the 3.5” Vertex 2 provides a faster, more responsive PC experience complete with TRIM support to keep your drive operating at peak performance in Windows 7 systems. Built with SATA 3Gb/s, Vertex 2 3.5” drives easily integrate into today’s desktop platforms as the ultimate storage upgrade.
Features:-
- Max Read: up to 285MB/s
- Max Write: up to 275MB/s
- Sustained Write: up to 250MB/s
- Random Write 4KB (Aligned): 50,000 IOPS
- Available in 90GB to 480GB capacities
- Native TRIM support
- Max IOPS Firmware
- Seek Time: .1ms
- 3.5" Anodized Casing
- 146 (L) x 101.6 (W) x 25.40mm (H)
- Operating Temp: 0°C ~ 70°C
- Low Power Consumption: 2W in operation,.5W in standby
- RAID Support
- Compatible with Windows XP, Vista, 7, Mac OS X and Linux
- MTBF: 2 million hours
- Ideal for desktop systems (no need for converter brackets)
- 3-Year Warranty
Was £169.99 Inc. VAT
Only £165.59 inc VAT.
ORDER NOW
Corsair A50 High-Performance CPU Cooler (Socket AM2/AM3/LGA775/LGA1155/LGA1156/LGA1366) @ £24.98 inc VAT
nonl2brExcessive heat is the deadly enemy of high-performance silicon, and the Air Series A50 CPU cooler can extend the lifetime of your CPU by quietly and efficiently drawing that heat away. You’ll get faster performance, too. Intel Core™ i5 and Core™ i7 processors can be easily configured to automatically overclock when conditions are right. Lowering your CPU’s operating temperature one of the best ways to do this – your CPU will detect that it’s running cooler, and instantly boost its speed when you need it. Of course, if you’re not using a Core i5 or Core i7 or if you prefer to adjust your overclocking settings manually, the Air Series A50 will give you the temperature headroom you need.<br>
The superior engineering of the Air Series A50 makes it dramatically outperform your CPU’s stock heatsink: three 8mm copper heatpipes directly contact your CPU and instantly pull heat up into the aluminum cooling fins. A 120mm fan, mounted on rubber studs to reduce noise and vibration, quietly draws cool air through the fins.<br>
Spend 15 minutes replacing your CPU’s stock heatsink and enjoy years of better performance.<br><br>
- Compatible with Intel and AMD systems<br>
- Three 8mm copper direct-contact heatpipes<br>
- Aluminum fins<br>
- Low-noise, low-vibration 120mm fan mounted on rubber studs<br>
- Selectable 1,600 or 2,000RPM fan allows you to select the cooling performance you want<br>
- Air flow: 50 - 61 CFM<br>
- Noise level: 26 - 31.5 dBA<br>
- Two-year warranty<br>
Was £27.98 Inc. VAT
ORDER NOW
Corsair Hydro H50-1 High-Performance CPU Watercooler (Socket LGA775/1155/1156/1366/AM2/AM3) @ £51.98 inc VAT
nonl2brThe Corsair Hydro Series™ H50 CPU Cooler gives you the power of liquid cooling in a compact, easy to install package. You get superior cooling for higher overclocking performance without the complexity of traditional liquid-cooling systems.
The Hydro Series H50 goes head-to-head with top of the line heatsinks, but maintains the near silence of liquid cooling for annoyance-free cooling performance. Due to its compact form factor, the H50 is the ideal solution for any case with a 120mm fan mount, even small form factor cases that prevent the installation of traditional heatpipe based air coolers. So whether you want world-class cooling, lower noise levels than your current CPU cooler, or something that fits in your small form factor case, the closed-loop Hydro Series H50 takes your CPU’s temperature to new lows and takes up less room doing it.<br><br>
- Pre-filled, closed-loop system is easy to install<br>
- Copper CPU cooling plate for maximum cooling performance<br>
- Integrated pump and reservoir is sealed for zero maintenance and improved leakage protection<br>
- Large 120mm radiator for fast heat dispersion<br>
- High-efficiency, low-noise 120mm fan for drawing cool air across the radiator<br>
<br><br>
<CENTER><IMG SRC="http://www.legitreviews.com/images/reviews/1154/2k9_bestof_award.jpg" width="150" height="150"/><IMG SRC="http://www.hardwareheaven.com/reviewimages/awards/newvaluesmall.jpg" width="150" height="150"/><IMG SRC="http://img.*****.net/v2/award_logo/Extreme_Recommended.png" width="150" height="150"/><IMG SRC="http://www.hardwareheaven.com/reviewimages/awards/newperformancesmall.jpg" width="150" height="150"/></CENTER>
<br>
<CENTER></param><embed src="http://www.youtube.com/v/PUxoFiFuS_g&hl=en_GB&fs=1" allowfullscreen="true" type="application/x-shockwave-flash" width="425" height="344">
</embed></object> </CENTER>
Was £54.98 Inc. VAT
Only £51.98 inc VAT.
ORDER NOW
Gelid Tranquillo CPU Cooler (Socket 754/939/940/AM2/AM2+/AM3/LGA775/LGA1155/LGA1156/LGA1366) @ £23.99 inc VAT
The tower CPU Cooler “Tranquillo” uses 4 power heat pipes and a special heat pipe constellation to achieve best heat transfer from CPU core to the aluminium fins in its class. After precise software simulation and calculation during the development stage a unique heat sink shape was created to lower air flow resistance as much as possible.
A silent 120mm fan with the intelligent GELID PWM (Pulse Width Module) control has been chosen to make this heat sink more valuable. The fan blades were optimised to guarantee high airflow while running silently. The intelligent GELID PWM curve keeps the fan silent when no necessary cooling is needed and accelerates the fan speed whenever additional cooling is needed. The multi-award winning high performance GC-2 thermal compound is already included in the package.
Additionally mounting clips for AMD 754/ 939/ 940/ AM2/ AM2+ and for Intel 775, 1366 and latest 1156 sockets as same as back plates for Intel LGA 775, Core i5 and Core i7 boards are all included.
- Socket Compatibility: 754 / 939 / 940 / AM2 / AM2+ / AM3 / LGA775 / LGA1155 / LGA1156 / LGA1366
- Dimensions: 74 x 125 x 153mm (L x W x H)
- Fan Speed: 750 - 1500 RPM
- Air Flow: 58 CFM
- Noise Level: 12-25.5 dBA
- Weight 645g
- 5 Year Warranty
Was £26.53 Inc. VAT
Only £23.99 inc VAT.
ORDER NOW
Thermalright Venomous X Silent CPU Cooler (Socket 775/1156/1155/1366/AM2) @ £52.98 inc VAT
Patented multiple support pressure vault bracket system, allow users adding pressure to the bracket system (40~70 lbs. pressure system for Intel CPU user only), and have a more efficient and secure mounting. Include AMD Socket AM2/AM3 Bracket system. Mirrored copper base increasingly upgrade the quality and the performance of the heatsink. Special bent winglet design, allows hot air to pass the heatsink more rapidly. Heatsink are all nickel plated to ensure the best quality and performance and could last for years. Soldered heatpipes, copper base and fins, to ensure the best thermal conducting efficiency. Six sintered heatpipe design, all heatpipes are nickel plated.To slow the oxidation deterioration to the heatpipe, to ensure longer usage and performance of the heatsink for the cpu. Including FDB 600RPM ultra low noise Fan Cover set x2 and Chill factor III thermal paste. Convex copper base design, to ensure the Highest thermal conducting thermal efficiency between the cpu and the heatsink.
Heatsink Dimension
- Size: Length 127mm x Width 63mm x Height 160mm
- Weight: 755 g (excluding fan and bracket system)
- Heatpipe: 6mm sintered heatpipe *6 units
- Copper base: C1100 pure nickel plated copper base, with ultra-shine mirrored surface.
Fan Spec
- Dimension : 120 x 120 x 25mm
- Bearing Type : FDB (Fluid Dynamic Bearing)
- Rated Voltage : 12.0 VDC
- Operating Voltage Range: 10.8~13.2 VDC
- Rated Current: 0.130 Amp +10% MAX /0.11AMP
- Rated Power: 1.56 watt
- Rated Speed: 600 RPM ± 10%
- Airflow: 30.5 CFM
- Noise Level: 13.1 dB/A
- Life Expectancy: 60000 HOURS AT 40°c / 65%
- Net weight: 156 GRAMS
- Connector: 3 pin
Was £56.99 Inc. VAT
Only £52.98 inc VAT.
ORDER NOW
Antec Tri-Cool 3-Speed 120mm Fan - Black @ £1.98 inc VAT
No matter what type of fan you're looking for, the Antec TriCool line offers reliable, stable performance. Available in 80, 92, and 120mm, TriCool fans offer the perfect balance of silence and efficiency. TriCool fans feature a 3-speed switch so you can find the ideal equilibrium of quiet and cooling.
- 3-speed switch lets you balance quiet performance with maximum cooling
- 3-pin and 4-pin power connectors provide convenient connections to your motherboard or power supply
- Fan-speed monitoring capability included (requires compatible motherboard)
Was £2.99 Inc. VAT
Only £1.98 inc VAT.
ORDER NOW
Fractal Design 120mm Silent Cooling Fan @ £7.98 inc VAT
Fractal Design "Silent Series" is a full range of silent case fans. The fans has been specifically developed to deliver sufficient airflow and still keep a low noise level. Available in sizes from 40mm up to 140mm.
Each fan is supplied with rubber fan mounts and four fan screws.
- Fan Speed: 1000 RPM
- Noise Level: 15 dBA
- Air Flow: 38.3 CFM
- 3 pin connector
- 2 Year Warranty
Was £9.98 Inc. VAT
Only £7.98 inc VAT.
ORDER NOW
Thermalright TY-140mm Silent Fan (Fits 120mm fittings) @ £8.99 inc VAT
PWM fan, provides simple and easy adjustment of fan speed with the latest ETC IC. Seven Silent Torpedo Blades - “submerges”, gives most quiet and efficient airflow. Enhanced Hyper-Flow Bearing (EHFB) - to ensure consistent and stable rpm, prolonged lifetime of usage. Aerodynamic body–Less friction around the edges and give more centered and concentrated airflow. 12 cm mounting hole–allows installation on the 12 cm dimension, so will be compatible with most coolers without having the need to buy extra kit for 14cm fan.
- Fan Dimensions : L160mm x H140mm x W26.5mm
- Fan Weight : 140g
- Fan Speed : 900~1300RPM (PWM)
- Sound Level : 17~21dBA
- Airflow : 28.3~74CFM
Was £10.99 Inc. VAT
Only £8.99 inc VAT.
ORDER NOW
Antec 300 Three Hundred Ultimate Gaming Case - Black @ £47.99 inc VAT
Impressively spacious and unbeatably reliable, the Antec Three Hundred is an unbeatable enclosure. Despite its eminently portable frame, the Three Hundred has enough room for all the latest flag-ship graphics cards, as well as six hard drives and a standard ATX motherboard. A cable management compartment keeps your system organized and the airflow unobstructed. A 120mm rear fan and 140mm top fan ensure that the case runs cool even when playing the most demanding games, while the sleek black finish gives it an extra stylish edge.
- External 3 x 5.25"
- Internal 6 x 3.5" for HDD
- 1 rear 120 x 25 mm TriCool™ Fan with 3-speed switch control.
- 1 top special 140 x 25 mm TriCool™ Fan with 3-speed switch control
- 2 front (optional) 120 mm fans to cool the hard drives
- 1 side (Optional) 120 x 25 mm Fan to cool graphic cards
- Washable air filters reduces dust build up in your system, which helps keep your system cooler
- Perforated front bezel for maximum air intake
- 7 expansion slots
- Top mounted I/O ports for easy access
- 2 x USB 2.0
- Dimensions: 458mm (H) x 465mm (D) x 205mm (W)
- HDA & AC’97 Audio In and Out
Was £49.99 Inc. VAT
ORDER NOW
Coolermaster CM-690 II Advanced Dominator Case - Black @ £72.98 inc VAT
The CM 690 II Advanced raises the bar again with practical improvements over the top-selling CM 690. The spacious mid-tower will keep enthusiasts happy with room for up to 3 vga cards, high-end CPU coolers, top or bottom mount water cooling radiator and 1.8"/2.5" drive adapter. It also features much improved airflow with oversized mesh and enough space for up to 10 fans. Maintenance will be a breeze with the tool-free drive bays, new cable management and CPU cooler retention hole.
- Dimensions: 214 x 511 x 528mm
- Motherboard Compatiblity: ATX, Micro-ATX, Mini-ITX
- Room for 120 x 240mm Radiator inside the top and bottom
- External SATA HDD dock
- Includes SSD Adapter
- Cable management and CPU retaining holes for easy maintainence
- Support Tri-GFXs
- 4 x 5.25" Drive Bays
- 7 x 3.5" Drive Bays
- I/O Panel: USB2.0, 1 x eSATA, 2 x Audio
- Front Cooling: 1 x 140mm Blue LED Fan
- Rear Cooling: 1 x 120mm Fan
- Top Cooling: 1 x 140mm Fan
- Bottom Cooling: 2 x 120mm Fans (optional)
- Right Side Cooling: 2 x 120 or 140mm Fans (optional)
- Left Side Cooling: 1 x 80mm Fan
- HDD Cage Cooling: 1 x 120mm Fan (optional)
- VGA Holder: 1 x 80mm Fan (optional)
Was £76.99 Inc. VAT
Only £72.98 inc VAT.
ORDER NOW
Lian Li PC-B25FB Aluminium Midi Tower Case - Black @ £110.99 inc VAT
The new PC-B25F is a mid-tower case, which is ideal for the latest graphics cards in combination with the best thermal dynamics. Easily adjustable to optimize your hardware setup. Especially in the advent of adding in new graphics cards, equipped with 8 PCI slots, can hold three or more graphics cards, supports CrossfireX™ and 3-way SLI™.
- Case Type: Mid Tower
- Dimensions: 210mm x 495mm x 490mm ( W, H, D)
- Front bezel Material: Aluminum
- Side Panel: Aluminum
- Body Material: Aluminum
- 5.25" drive bay: 3
- 3.5" drive bay: 6
- Motherboard: ATX / M-ATX
- System Fan: 12cm Fan x 2 (1200RPM)
- System Fan: 14cm Fan x 2 (1000RPM)
- System Fan: 12cm Fan x 1 (1500RPM)
- I/O Ports: E-SATA / USB2.0 x 2 / HD+AC97 Audio
Was £115.99 Inc. VAT
Only £110.99 inc VAT.
ORDER NOW
Samsung B2230H 21.5" Widescreen LCD Monitor - Glossy Black @ £119.99 inc VAT
Samsung 30 Series monitors are designed to be eco-friendly as well as user-friendly. With efficient power saving and innovative features, they allow you to enjoy using your monitor with the confidence of a clear conscience. The phenomenal 70000:1 Dynamic Contrast Ratio welcomes you to a world of intense, natural colour and incredible, lifelike detail. Combine that with a high brightness of 300cd/m² and you have a monitor that is made for multimedia.
- Screen Size: 21.5" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 70000:1
- Brightness: 300cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Dimensions: 523.4mm x 400.0mm x 197.0mm
- Weight: 4.35kg
- Warranty: 3 Years On-Site
ORDER NOW
Asus VG236HE 23" TRUE 120Hz 3D Widescreen LCD Monitor - Black @ £275.99 inc VAT
Enter an immersive three dimensional Full HD 1080p world of games and movies with the VG236HE. Through the use of market-leading 3D technology and active shutter glasses, it instantly takes you into another dimension - transforming your gaming experience to 3D. There are hundreds of popular PC game titles currently compatible with the NVIDIA 3D Vision kit (not included).
- Tilt and Swivel also Height Adjustable.
- Screen Size: 23" Widescreen
- Contrast Ratio: 100000:1
- Response Time: 2ms
- Viewing Angles: (H/V): 170*/160*
- Inputs : 1 x DVI-D & 1 x HDMI
- Weight: 7kg
- 3 Years Warranty
Was £285.95 Inc. VAT
Only £275.99 inc VAT.
ORDER NOW
"Primo Drone" AMD Athlon II X2 Dual Core 250 3.00GHz DDR3 System @ £189.98 inc VAT
The "Primo Drone" offers the performance needed for home and business use at a low price. The AMD Athlon II X2 Dual Core 250 3.00GHz combined with 4GB of 1333MHz DDR3 RAM, offers a quick and easy multitasking experience.
Why You Should Buy This System?
- AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3) offers multitasking performance.
- 500GB Seagate Barracuda hard drive gives a solid and reliable storage capacity.
- 4GB of 1333MHz DDR3 RAM allows for snappy and precise processes to be made.
System Specification
- Case: OcUK EZCool NA-705 microATX case - Black
- Power Supply: OcUK Value 500W PSU
- CPU: AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3)
- Motherboard: AMD nForce 630a (Socket AM2+/AM3) DDR3 Motherboard
- RAM: OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel
- Hard Drive: Western Digital Caviar Blue 500GB SATA 6GB/s
- Graphics Card: Onboard integrated NVIDIA GeForce 7025 GPU
- Sound: ALC662 6-channel High Definition Audio CODEC
- Optical Drive: LG GH22NS50 22x DVD±RW SATA ReWriter
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
Compact, reliable and smart. The "Primo Drone" give you everything you need in a entry level home/business system.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Was £199.98 Inc. VAT
Only £189.98 inc VAT.
ORDER NOW
Samsung P2370 23" Widescreen LCD Monitor - Glossy Black @ £131.99 inc VAT
Ultra-slim and ultra-elegant, the Touch of Colour design is inspired by the artistic integrity of hand blown glass. The translucent charcoal gray gradation of the bezel and cobalt blue hues of the clear crystal neck subtly shift in color depending upon external light conditions, creating an exquisite interplay between the monitor and the environment that it is placed in. The ultra-slim 30mm depth not only creates more style in less space but also ensures exceptional all round efficiency. Up to 50% slimmer than traditional monitors, the modern, organic contours gently accentuate the elegance of your lifestyle and home.
- Contrast Ratio: 50000:1
- Brightness: 250cd/m²
- Inputs: 1x DVI-D (HDCP Compliant)
- Dimensions: 571.0mm x 423.0mm x 190.0mm
- Weight: 4.1kg
Was £139.99 Inc. VAT
ORDER NOW
Benq XL2410T 24" TRUE 120Hz 3D Widescreen LED Monitor - Black @ £269.99 inc VAT
BenQ, proudly announced the release of their 23.6” (16:9 Aspect Ratio) LED Gaming Monitor XL2410T. BenQ understands that to lead and become a true and professional gaming monitor provider, they have to understand the mindset and needs of gamers. In order to achieve this goal, BenQ co-worked with ZOWIE, a professional Gaming gear manufacturer. BenQ have ZOWIE’s gamer teams join in during the product development and testing stages. With their assistance, XL2410T can truly be a professional LED gaming monitor – with a set of Gaming Display Modes which includes the FPS mode (First Person Shooting), co-developed by two legendary Counter-Strike players – Emil “HeatoN” Christensen and Abdisamad “SpawN” Mohamed.
Every serious gamer know that lag will cause you to lose a game; XL2410T is made to have a quick response to action, hardware lag will no longer be the cause for your headshots. XL2410T has a fast refresh rate of 120Hz for higher precision; a low input lag so the shots made is more in sync with the visual on-screen; a quick 2ms GTG (OverDrive) meaning users can see the edge of the enemies clearly and without motion blur, and Dynamic Contrast Ratio of 10,000,000:1 for detailed images and clarity in both darkened and brightened situations, this complemented with BenQ’s gaming tuning technology becomes a huge advantage for gamers.
XL2410T has a smart design, for one purpose – to win. The monitor has two hotkeys available; the first changes the display mode: Full; Aspect; Overscan; 1:1; 17”; 19”; 19” Widescreen and 22” Widescreen. Whereas the second hotkey is Smart Scaling, which lets the users adjust picture size in original input to the screen’s limit. Together with Display Mode function, users can play in the resolution size they are used to with their previous monitor, or adjust their screen size to what their teammates are using for easier communication and reference. From BenQ’s Gaming Display Modes options, users can choose from FPS Mode, made possible by co-working with the gaming heroes -HeatoN and Spawn as the best setting for personal shooting games, or from the two User Game modes for more dedicated and personalized settings.
For extreme entertainment, XL2410T is the LED monitor to go for. 3D-ready (NVIDIA 3D Vision certified); Picture by Picture (PBP); connectivity values (D-sub; DVI-D-DL, HDMI) and height adjustment feature are offered for users’ enjoyment and comfort. Picture by picture (PBP) is a feature that enables users to show two programs side-by-side on the screen. Feel like camping once in a while for fun? Watch a movie while you do it!
- LED Backlit
- Screen Size: 23.6" Widescreen
- Contrast Ratio: 10000000:1
- VESA Compliant
- Dimensions: 570.0mm x 412.6mm x 183.9mm
- Weight: 6.0kg
- Height adjustable stand / Swivel 45/45 left/right
- Warranty: 2 Years On-Site
Was £281.99 Inc. VAT
Only £269.99 inc VAT.
ORDER NOW
Pioneer BDR-205 12x BluRay RW / 16x DVD±RW Drive - Black (OEM) @ £95.99 inc VAT
Pioneer introduces the world's first 12x BD-R/BD-R DL optical drive. The BDR-205 Internal Blu-Ray Disc/DVD/CD Writer is the lastest generation in technology. This revolutionary product will write up to 12x on BD-R (25Gbytes) and BD-R DL (50Gbytes) media giving you more time to play.
Write Speed
12x BD-RE and BD-RE DL/BD-R
16x DVD-R / +R
6x DVD-RW
8x DVD+RW
8x DVD-R DL / +R DL /BD-R/BD-R DL
40x CD-R
24x CD-RW
Read Speed
8x BD-ROM/BD-ROM DL / R / RE
16x DVD-ROM and DVD-R / +R/DVD-R
12x DVD-ROM DL , DVD -RW / +RW and DVD-R DL / +R DL
40x CD-ROM
40x CD-R
24x CD-RW
Was £99.98 Inc. VAT
ORDER NOW
Samsung SH-B123L/BSBP 12x BluRay ROM DVDRW DL & RAM Lightscribe SATAII Optical Drive - Retail Black @ £50.39 inc VAT
True 1080p Full HD technology is more than just entertainment, it's an experience. And it's the pinnacle of picture quality, engulfing and entertaining you with spectacular detail-rich, eye-popping colours and super-sharp, ultra-realistic images that enhance anything and everything on your screen. With our Blu-ray drives, you'll feel like you're seeing your favourite movie for the very first time.
Blu-ray lets you get the most out of your movie watching, so shouldn't you get the most out of Blu-ray? That's where BD Advisor comes in. It lets you unlock the power of interactive high-definition movie viewing with PowerDVD and Blu-ray Discs. BD Advisor helps you test your system and understand Blu-ray basics as well as suggest upgrades. Now you can always enjoy the best Blu-ray has to offer.
Breathe new life into your movie collection with Samsung's up-scale technology. It gives your standard definition DVDs a dramatically different high resolution look. And it gives your movie-viewing experience a cinematic boost. By up-scaling, your favourite DVDs will feature the same brilliant details and rich, robust colours you've come to enjoy from the high definition content on your HDTV.
- SATA Interface
- Includes Cyberlink PowerDVD
Write Speeds
- DVD-R: 16x
- DVD-R DL: 8x
- DVD-RW: 6x
- DVD-RAM: 12x
- DVD+R: 16x
- DVD+R DL: 8x
- DVD+RW: 8x
- CD-R: 48x
- CD-RW: 24x
Read Speeds
- BD-ROM: 12x
- BD-R: 8x
- BD-RE: 8x
- BD-RE DL: 6x
- DVD: 16x
- CD: 48x
Was £59.99 Inc. VAT
Only £50.39 inc VAT.
ORDER NOW
"Primo Pterosaur" Intel Core i5 2300 2.80GHz DDR3 Sandybridge System @ £409.99 inc VAT
Introducing the "Primo Pterosaur" delivering breath taking performance and providing excellent onboard graphics from the integrated Intel HD2000 GPU. Capable of DX10.1 Stereoscopic 3D via HDMI 1.4a and having enough power for discreet gaming. The "Primo Pterosaur" offers everything that is required to make a perfect home computer.
- Choose from a selection of graphics cards to meet your performance needs
- Precision built and cabled by Overclockers UK expert technicians
- USB3, SATA 6GB/s, Intel Ethernet and EUFI graphical BIOS for next gen computing
- Case: Xigmatek Asgard - Black
- Power Supply: OCZ StealthXStream II 600W
- CPU: Intel Core i5 2300 2.80GHz Sandybridge CPU
- Motherboard: Intel H67 (Socket 1155) MicroATX DDR3 Motherboard ** B3 REVISION **
- Cooler: Intel Stock Cooler
- RAM: Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
- Graphics Card: Onboard Intel HD2000 graphics with GFX upgrade options
- Sound: Realtek 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
Service Package
With powerful graphics, rapid processing and features by the truck load, the "Primo Pterosaur" offers more than any other computer at this price.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods. T
Was £419.99 Inc. VAT
Only £409.99 inc VAT.
ORDER NOW
Pioneer 24x Internal S19LBK DVD Rewriter including Labelflash SATA Retail @ £17.99 inc VAT
Pioneer 24x Internal SATA DVDRW Drive with Black Bezel, Retail Kit with Nero Writing Software.
Optical Storage - DVD±RW (±R DL) / DVD-RAM - 5.25" x 1/2H
- Read Speed - 40x (CD) / 16x (DVD)
- Enclosure Type - Internal
- CD / DVD Rewrite Speed - 32x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 12x (DVD-RAM)
- Enclosure Colour - Black
- Interface - Serial ATA
Was £21.98 Inc. VAT
Only £17.99 inc VAT.
ORDER NOW
MSI GT680R-056UK 15.6" WLED TFT Intel HRV I7-2630QM 2.0GHz, 8GB DDR3, 1TB HDD, NVIDIA GTX460M 1.5GB GDDR5 Graphics, Win7 Home Premium 64-Bit - Black/Red @ £1,318.80 inc VAT
Based on PCMark Vantage test the GT680 scored 18,162, which is the highest test score in history. Compared to all the high end-end gaming notebooks on the market, the GT680's performance is 75% faster than others. With MSI Turbo Drive Engine (TDE) Technology, which is world's No.1 turbo technology, you can experience faster response time and efficient real-time data processing. Only one finger!! Exclusive Cooler Boost technology provides powerful cooling capabilities and receives real-time notification of the GT680's core temperature variations and fan speed. Provides you with the most economical means to upgrade memory capacity (16GB max), so you never again have memory issues affecting your gaming experience. Dual SATA hard drives(maximum capacity of 1TB)let you play more games, view more DVDs and download more music, allowing you to enjoy all kinds of entertainment when you’re out and about. NNVIDIA® GeForce® GTX 460M notebook GPUs give your games an adrenaline shot with the premium performance and great detail images quality thanks to latest DirectX11 effects. GeForce GTX 460M arms you with the latest industry-leading technologies including eye-popping NVIDIA 3D Vision, dynamic PhysX effects, high performance NVIDIA Verde drivers, and more. DirectX 11 GPU with Shader Model 5.0 is designed for ultra high performance and real-to-life image details in the new API’s key graphics feature, GPU-accelerated tessellation.
This exclusive, dazzling LED performance illumination technology increases the sensation of instant immersion when listening to music, watching video, or while wrapped up in the gaming world, thanks to changes in the GT680's cool LED lights. When listening to music, watching a video or when knee-deep in the exciting world of gaming, simply press the MSI LED light performance control hotkey and the GT680 enters Audio Synchronize Mode. Then, the GT680's LED lights on both sides of the notebook and at the front of the keyboard will light up all at once. The light performance will follow different changes in sound, allowing you to unconsciously follow the rhythm of the dynamic lighting and envelop yourself in an atmosphere of sound and light that will leave you breathless! The exclusive LED performance illumination mode can also intelligently simulate sound. When the left-side speaker emits sound, the LEDs on the left side will independently illuminate, and the same on the right side. For example, when an image of a bullet passes from left to right, the noise of the bullet will also pass from left to right through the speakers, and the LED lights then light up in conjunction with the direction of the sound moving from left to right, giving images and sound a three dimensional effect and making you feel as if you are in the midst of authentic and dynamic reverberations!
Cinema Pro Technology offers consumers the finest movie viewing experience. Just need to push the Cinema Pro button, the Windows Media Player will automatically open. The quality on screen will be more detailed, the richness in sound as well as THX TruStudio Pro surround sound effect will be activated, providing the finest sensory of the theaters. USB 3.0 can reach transfer rates of 4.8GB per second, 10 times the bandwidth of the current USB 2.0. A 27GB HD file (about as large as a 4 hour HD video) can be transferred within 70 seconds, so HD video and 3D game playback speeds are even faster. USB 3.0 is also capable of executing read/write data operations, while USB 2.0 can only execute unidirectional document transfers in the same amount of time. Genuine 720p high-definition (HD) video quality to 30fps (30 continuous images per second Allowing smooth, natural progression without jerkiness; ordinary webcams only offer 8fps). This guarantees truly clear and smooth video and picture quality and exceptional audio effects. In addition, the 16:9 HD wide-screen video display can be used with all kinds of social networking media, allowing optimum high-quality video communication and production of HD videos for the enjoyment of friends and family.
The GT680 ‘s HDMI output not only delivers super-fast 5GB per second data rates, but it also reduces cable clutter, while ensuring the best possible video quality. By taking advantage of HDMI, the GT680 can render game scenes with spectacular clarity and realism, making it a great choice for the next generation of both PC and online games. The GT680 features a numerical keypad that provides a desktop-quality typing experience. For uers often needing to key in numbers, the GT680’s keyboard is a huge boon. With its 802.11b/g/n(draft) wireless LAN and Bluetooth networking interfaces, the GT680 provides a versatile way to connect to, browse, and retrieve data on both your own devices and the online universe.
Features:-
- 15.6" WLED True HD Screen with 1920x1080 resolution
- Intel HRV I7-2630QM 2.0GHz Processor
- 8GB DDR3 Memory
- 1TB 7200rpm HDD (2x 500GB in RAID 0)
- NVIDIA Fermi GTX 460M 1.5GB Graphics
- Intel HM67 SandyBridge Chipset
- Super-Multi DVD
- Bluetooth
- HDMI
- HD Webcam
- 9 Cell battery (3hr battery life)
- Windows 7 Home Premium
- The latest 2nd generation Intel® Core™ i7 Processor
- Genuine Windows® 7 Home Premium
- Exclusive TDE Technology
- Exclusive DDR3 SO-DIMM x 4 slot Design
- Sound by Dynaudio
- THX TruStudio Pro Provides Excellent Surround Sound Effect
- High-end NVIDIA® GeForce GTX 460M discrete graphics card
- Latest & fastest Data Transfer Technology USB 3.0
Was £1,499.99 Inc. VAT
Only £1,318.80 inc VAT.
ORDER NOW
"Primo Ignition" Intel Core i3 550 3.20GHz DDR3 System @ £299.98 inc VAT
The "Primo Ignition" features a Intel Core i3 550 3.20GHz processor seamless multi-tasking capabilities which is perfect for home/office use. Awesome power contained within a small chassis the "Primo Ignition" has the option to upgrade to one of many of the latest Low Power, energy efficient Nvidia series graphics cards for extra graphical punch. Utilising Hyper threading technology the "Primo Ignition" makes short work of video encoding and multitasking.
- Intel Core i3 540 3.06GHz (Clarkdale) Processer with Hyperthreading technology for 4 Virtual cores
- 500GB Hard drive gives massive storage capacity including DVD Re-Writer Make this system perfect for data backup
- Case: OcUK EZCool NA-705 microATX Case
- Power Supply: OcUK 500W PSU
- CPU: Intel Core i3 550 3.20GHz (Clarkdale)
- Motherboard: Intel H55 (Socket 1156) DDR3 microATX Motherboard
- Cooler: Intel Approved Cooler
- Graphics Card: Onboard Intel GMA graphics or a choice of energy efficient graphics cards
- Sound: High Definition 7.1 Onboard Sound Card
- Optical Drive: LG GH22NS50 22x DVD+RW SATA ReWriter
Service Package
With multiple video outputs, compact size and advanced hyperthreading technology the "Primo Ignition" is perfect for the user looking for a highperformance system for a low price.
Was £309.98 Inc. VAT
Only £299.98 inc VAT.
ORDER NOW
Coolermaster Elite Power 500W Power Supply @ £32.99 inc VAT
The reliable, efficient and affordable line of Elite power supplies is ideal for mainstream and basic computing systems. Built with quality components and dual +12V outputs, the Elite series is fit to handle demands of high power requirements. The eco-friendly design allows the Elite series to reach more than 70% efficiency at typical loading and meet Energy Star and Blue Angel requirements.
- Compliance with the newest Intel standard ATX 12V V2.3
- More than 70% efficiency at typical load operation
- High performance components design for better reliability
- Green power design to meet Energy Star and Blue Angel requirements
- Multiple protection design(OVP/OCP/OPP/SCP)
- Support dual +12V1 and +12V2 outputs for higher power usage
- One 4+4 pin +12V CPU connector for high-end CPU
- EMI and Noise filter built in design
- 2 Year warranty
Was £34.99 Inc. VAT
Only £32.99 inc VAT.
ORDER NOW
MSI GT680-035UK 15.6" WLED TFT Intel HRV I7-2630QM 2.0GHz, 8GB DDR3, 120GB SSD + 500GB HDD, NVIDIA GTX460M 1.5GB GDDR5 Graphics, Win7 Home Premium 64-Bit - Black/Red @ £1,558.80 inc VAT
Features:-
- 8GB DDR3 Memory
- 120GB Intel SSD Boot Drive PLUS 500GB 7200rpm Storage HDD
- Blu-Ray ROM
- Bluetooth
- HDMI
- HD Webcam
- Sound by Dynaudio
Was £1,699.00 Inc. VAT
Only £1,558.80 inc VAT.
ORDER NOW
"Titan Spinosaur" Intel Core i5 2500K 3.30GHz @ 4.60GHz DDR3 Sandybridge System @ £706.00 inc VAT
Stalking through the jungle, the "Titan Spinosaur" is master of all. Featuring the Intel Core i5 2500K overclocked to a ridiculous 4.60Ghz, you can enjoy ultra smooth framerates and an immersive computing experience. With a choice of the latest DX11 graphics cards, equip yourself ready for the hunt ahead with the best offering from both Nvidia and ATI.
- A guaranteed 4.60GHz performance for the price of 3.30GHz
- Case: Antec 300 Case with LED case fan options
- Power Supply: OCZ StealthXStream 700W
- CPU: Intel Core i5 2500K 3.30GHz @ 4.60GHz Sandybridge CPU
- Motherboard: Gigabyte P67A-UD4 Intel P67 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
- Cooler: Corsair H50 CPU Cooler
- RAM: Corsair Vengeance 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit
- Graphics Card: Choice of DX11 Compatible Graphics Cards
Service Package
Heighten your gaming experience with the "Titan Spinosaur", stalk your prey down and demolish the competition. Equipped with either ATI or Nvidia, become a champion.
Was £755.99 Inc. VAT
Only £706.00 inc VAT.
ORDER NOW
Roccat Alumic Gaming Pad @ £33.59 inc VAT
With two very different surface structures, the ROCCAT™ Alumic meets the highest demands of both low and high-sense gamers. Each side also features a different design. Made from high-quality aluminum, the ROCCAT™ Alumic offers maximum stability and durability. Extra-large mousepad feet ensure the mousepad stays rooted to the spot while offering the ultimate in mouse control when gaming. It also includes a gel-filled wrist rest for maximum comfort.
- Double sided mousepad
- Anodized aluminium core
- Including gel wrist rest
- Non-slip rubber feet
- High quality materials
- Easy-to-clean surface
- Optimised for speed & control
Was £34.98 Inc. VAT
Only £33.59 inc VAT.
ORDER NOW
Speedlink Vellu Gel Mousepad - Black @ £5.39 inc VAT
The mouse pad is perfect for maintaining the wrists in a relaxed position whilst working thereby preventing excessive straining. The gel filling allows the mouse pad to mould to optimally fit any wrist thereby improving use.
- Reduces posture-related injuries
- Adapts perfectly for any wrist
- Extremely soft covering
- Mousepad with gel filling
- Enables relaxed arm posture
Was £6.98 Inc. VAT
Only £5.39 inc VAT.
ORDER NOW
Gigabyte M8600 6500DPI Wireless Gaming Mouse @ £79.98 inc VAT
Aivia M8600 Wireless Macro Gaming Mouse has long lasting battery that guarantee 100-hour nonstop gaming experience. QSBS™ (quick swap battery changing system) technology is GIGABYTE's unique design. This patent pending technology allows for Instant battery changing under 2 seconds, as fast as gun clip loading and unloading.
Aivia M8600 Wireless Macro Gaming Mouse comes with an instant charging dock, served as mouse and Li-ion batter charger as well as wireless receiver unit. This device helps you enjoy gaming with wireless transmission speed at 1000Hz polling rate. The powerful wireless reception ensures no signal is lost that every single move made by the mouse is read during game playing.
Aivia M8600 Wireless Macro Gaming Mouse features twin-eye gaming-grade laser engine. Based on advanced laser technology, the twin-eye gaming sensor features high precision, low power, and ultra-fast performance.
When Aivia M8600 Wireless Macro Gaming Mouse is connected to its complimentary wire, it is able to edit GIGABYTE's GHOST™ Macro Engine. GHOST™ Macro Engine is an incredible macro editing software for the memorized macros to be carried around even if the mouse is connected to a different computer. 32KB onboard memory enables up to 5 programmable profile settings. The engine features critically acclaimed easy-to-use drag-and-drop operating system, DPI switching, tilt-wheel speed adjustment, and customizable color hues as profile indicators.
- GamePlay™ Wireless Technology- over 50hrs battery life in game play
- Quick-swap battery system- instant battery changing under 2secs, as fast as gun clip loading
- 32KB onboard memory enables up to 5 programmable profile settings
- Dual mode wired/ wireless functionality-switch between the wireless freedom and the frenzy of wired play
- Advanced GHOST™ Macro Engine
Was £89.99 Inc. VAT
Only £79.98 inc VAT.
ORDER NOW
Gigabyte 'Ghost' Mouse Pad @ £6.12 inc VAT
The GigaByte GP-MP8000 mouse pad is a perfect partner for there gaming mouse the GM-M8000 Ghost. If you are not using the GM-M8000 mouse, be assured you will not be disappointed while using any one of your favorite mice on it. The large size of this mouse pad gives us freedom to move the mouse around with out having to worry about the mouse falling off the edge while cutting and pasting images, to seriously gaming.
- High density polyester cloth optimize your superior performance in games.
- Anti clip natural rubber secures high-speed movement.
- ide and smooth surface provides total-comfort grip.
- Designed for power users whose demand precision tracking.
- Perfect gaming size: 400x 300x 5mm.
Was £6.50 Inc. VAT
Only £6.12 inc VAT.
ORDER NOW
Seagate Momentus XT 500GB Hybrid SATA-II 2.5" 7200RPM 32MB @ £87.98 inc VAT
nonl2br
Powerful, intelligent, affordable - solid-state hybrid drives deliver SSD-like performance without sacrificing storage capacity and affordability. <br><br>
- Adaptive Memory™ technology <br><br>
- 80% faster than traditional 7,200-RPM drives <br><br>
- Boot within seconds of a laptop with SSD <br><br>
- Work in any standard laptop with any OS <br><br>
- Seagate 5-year limited warranty <br><br>
The Seagate Momentus® XT solid state hybrid drive combines SSD-like performance with affordable high-capacity hard drive storage for laptops, external backup and small form factor desktop PCs. This drive is designed for all standard laptop PCs and is OS-, driver- and software-independent, making it easy to integrate and easy to use. <br><br>
The Momentus XT drive offers hybrid storage with Adaptive Memory technology, enabling the drive to deliver higher capacities up to 500GB and SSD-like performance. <br><br>
Adaptive Memory Technology <br><br>
Designed with high-performance core components on an innovative platform, the Momentus XTdrive consists of a 7200-RPM hard drive with 32MB of cache, 4GB of solid state SLC NAND flash storage, and Adaptive Memory self-learning technology. Adaptive Memory technology intelligently monitors frequently used applications and data fi les, then places them into the solid
state portion of the drive so they can be quickly recalled. Adaptive Memory technology enables the drive to tailor its performance to the user.Whether you are gaming, editing digital media or
crunching numbers, the performance is optimized and ready for your next move. <br><br>
Key Specifications <br><br>
- 500GB, 320GB and 250GB hard drive capacity options <br><br>
- 4GB SLC NAND solid-state memory <br><br>
- 7,200-RPM spindle speed <br><br>
- 32MB of drive-level cache <br><br>
- SATA 3-Gb/s interface with Native Command Queuing <br><br>
Best for <br><br>
- High-end laptops and workstations <br><br>
- High-performance gamer laptops <br><br>
- Fast external enclosures: USB 3.0, eSATA <br><br>
- Small form factor PCs <br><br>
- High performance Desktop Storage <br><br>
<br><br>
<<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/Kss98VdhSj0?fs=1&hl=en_GB"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Kss98VdhSj0?fs=1&hl=en_GB" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
Was £94.99 Inc. VAT
Only £87.98 inc VAT.
ORDER NOW
Qpad Grin CT Large Mouse Pad @ £18.98 inc VAT
nonl2br
For all users with high demands on precision, feel and functionality this is the mouse pad that delivers. CT™ series smooth Hybratek™ coating ensures that the mouse registers every detail of the smallest mouse movement. It offers a smooth and a controlled glide with an optimum level of friction. Whether you are a hardcore gamer or work with other demanding tasks such as graphic design or large spreadsheets, you’ll thrill to the task.<br><br>
- Size: Large: 40.5x28.5cm<br>
- Thickness: 4 mm<br>
- Grin design<br>
- Surface: Hybratek Coated soft top<br><br>
<font color="red"> <font size="3"> SRP <s>£28.58</s> <b>SAVE: 6.60 </font>
Was £21.98 Inc. VAT
Only £18.98 inc VAT.
ORDER NOW
Corsair Gaming Audio Series HS1A Analogue Gaming Headset @ £39.98 inc VAT
The Gaming Audio Series HS1 Gaming Headset is designed for gamers who are serious about audio. Massive 50mm driversdeliver serious punch, without sacrificing the sparkling sound quality you need for music and movies. Extra-large, extra-deep memory foam earpads provide a reliable, custom fit that’s so comfortable, you might forget you’re wearing them.
- Massive 50mm drivers for high-quality audio reproduction
- Detailed audio reproduction with clean, accurate bass and sparkling clarity in mids and highs
- Circumaural, closed-back earcups for superior noise isolation
- Memory foam earpads provide a custom fit that won’t weigh you down
- Includes two sets of earpads to customize your comfort – your choice of microfiber or synthetic leather
- Connectivity: 3.5mm jacks for ear piece and mic
- 2 Years Warranty
Was £43.98 Inc. VAT
Only £39.98 inc VAT.
ORDER NOW
Seagate Barracuda Green 2TB SATA 6Gb/s Hard Drive - OEM (ST2000DL003) @ £62.99 inc VAT
Barracuda® Green drives from Seagate save you time. Available now with SATA 6Gb/s interface and 64MB cache and combined with the industry's only 5900-RPM spin speed, you can be sure you're getting the best performance in the green-power drive category.
Seagate SmartAlign™ technology simplifies your transition to the Advanced Format (AF), 4K standard. There is no need for time-consuming integration utilities required by similar AF drives.
- Direct Attached Storage devices–USB/FireWire/eSATA
- Network Attached Storage devices and Windows storage servers
- Eco friendly PCs
- High-capacity desktop storage
Features
- A unique 5900-RPM speed delivers the fastest-performance eco friendly drive available.
- Seagate SmartAlign technology allows you to get all the benefits of the new Advanced Format 4K sector standard without any hassle–no utilities, no extra steps.
- The SATA 6Gb/s interface and 64MB cache maximize performance.
- Low power consumption combined with leadership in the use of environmental compliance materials means you don't have to sacrifice environmental stewardship for performance.
- Cool, quiet operation
- Capacity: 2TB
- Interface: SATA 6Gb/s
- Spindle speed: 5900RPM
- Cache size: 64MB
- Warranty: 3 Years
Was £66.98 Inc. VAT
Only £62.99 inc VAT.
ORDER NOW
Plantronics GameCom 377 Gaming Headset (79731-05) @ £22.78 inc VAT
Because your hardware should be as powerful as your gaming skills, the GameCom 377 gaming hedset delivers rugged construction and vigorous sound. A lightweight frame and specially designed ear pods redistribute pressure for maximum comfort, while the open-ear design lets you catch all the in-game sound effects without losing touch with your surroundings. When you’re ready to fire off orders, unveil the hidden, noise-cancelling microphone boom to strategise clearly with team members. Responses coming in? Adjust audio levels using in-line volume and mic-mute controls. When you’re done, rotate and tuck the microphone boom inside the headset - then let your score do the talking.
- Open-ear design keeps you connected to the game and your surroundings.
- Concealed mic boom stays hidden until you’re ready to use it.
- Specially designed ear pods redistribute pressure for maximum comfort.
- In-line volume and mic-mute controls allow for easy audio adjustment.
- Noise-cancelling microphone lets you communicate clearly.
- Rugged, military-like design and extra-strength cables make your hardware hardcore.
Was £24.98 Inc. VAT
Only £22.78 inc VAT.
ORDER NOW
Roccat Kone+ 6000DPI Max Customization Gaming Mouse @ £59.99 inc VAT
With a 6000dpi Pro-Aim Laser Sensor and its integrated Tracking & Distance Control Unit (TDCU), the further development of the prize-winning ROCCAT™ Kone Gaming Mouse has unbelievably more power under the hood. Its maximum precision and ultimate tracking are beyond comparison.
The massive upgrade made to the driver and the introduction of the EasyShift[+] button has also turned the Kone[+] into a real customizable marvel at the same time. No other mouse offers as many configuration options as the ROCCAT Kone[+].
MAXIMUM PERFORMANCE
The revolutionary 6000dpi Pro-Aim Laser Sensor, in conjunction with its 10.5 megapixel resolution and 1000Hz polling rate, offers maximum precision, even transmitting lightning fast mouse movements with up to 30Gs of acceleration and with speeds of up to 200ips (5.08m/s) without loss or lag. Thanks to the Tracking & Distance Control Unit, which is now integrated in the laser sensor, the ROCCAT™ Kone[+] can also calculate the lift-off distance as well as fine-tune the sensor to suit the mousepad. The result: optimal tracking.
ERGONOMIC HYBRID SHELL
The highly praised hybrid shell for right-handers, including the Soft-Touch Surface, have been retained, but really useful core improvements have been made that further increase the comfort of Kone’s successor. The mouse wheel is completely new: distinctive notch positions are perfect for gaming, and the wider design makes it easier to control. The button above the mouse wheel has been made larger and you’ll now find a nicely-sized toggle switch below the mouse wheel. The result: maximum gaming comfort.
22 MOUSE FUNCTIONS
Thanks to the EasyShift[+] button, all the buttons – including the mouse wheel – can be assigned two functions such as macros or other functions. As a result, you now have 22 functions available at any one time instead of the usual 12.
Find out more about EasyShift[+] and just how easy it is to use here: mehr...
4 LED MULTICOLOR LIGHT SYSTEM
Like before, the light system remains unbeaten. Four multicolor LEDs, together with the enhanced lightpipes and configurable effects, can light up, alternate or pulsate in more than four different colors at the same time. It’s a real eye-catcher on any desktop.
5 GAME PROFILES
You can configure your button assignments, including macros, DPI settings, the sensor sensitivity level and your lighting settings too, and save them to any one of 5 profiles on the 576kB of onboard memory. This allows you to customize your mouse to suit individual games. You can associate each profile with a particular application so the right button assignments, DPI and color settings, etc., are automatically loaded when you start the game. When a profile is set as the Windows Profile, the ROCCAT™ Kone[+] will always switch to this profile when you return to Windows after leaving a game or app. Additional profiles can be saved on your hard drive whenever you want, and then loaded to any one of the 5 profile slots using the driver menu.
MACRO MANAGER
Creating and editing your own command sequences is made easy thanks to the highly praised Macro Manager. Predefined macro presets for the top 20 PC games as well as several office apps make it even easier to customize the mouse – plus the new Loop Function now makes it possible to loop macros indefinitely.
SOUND FEEDBACK
The famous ROCCAT voice gives immediate feedback when you change DPI settings, profiles, the volume level or sensitivity setting. As you don’t need to look at an additional display on the screen or on the mouse itself, nothing will distract from the gameplay. It really is as easy at that.
CUSTOMIZE THE WEIGHT
A weight system comprising 4 x 5g weights is included, allowing you to customize the weight in four stages to suit your preferences.
Was £68.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Steelseries Siberia v2 - Red @ £65.99 inc VAT
Based on the award-winning SteelSeries Siberia Full-size Headset, the v2 features major enhancements in sound quality, comfort and its microphone. Every element of the v2 has been optimized for pro gaming, making the headset a preferred piece of equipment for the worlds' best competitive PC gamers - the most demanding headset users in the world.
Sporting 25% larger 50mm driver units, the SteelSeries Siberia Full-size Headset dramatically boosts overall acoustic performance. Experience a rich and detailed soundscape from immersive atmospheric background music to precise 3D positional sounds of footsteps, gunfire and more.
The close type ear cups feature thick leather padded cushions built from sound dampening foam, designed to offer passive noise reduction from loud surroundings and improve comfort over prolonged use. A virtually invisible uni-directional microphone can be retracted from the left ear cup, optimized for essential voice communications.
The v2 remains lightweight and its trademark headband suspension construction makes it extremely comfortable for use over long periods of time.
- Closed type headphones.
- Pull-out microphone.
- Crystal clear high, low and mid-tones.
- 50mm driver units.
- Lightweight suspension construction.
- Sleek RED colour
- 2 years warranty
Was £72.97 Inc. VAT
ORDER NOW
"Titan Krypt" AMD Athlon II X4 640 3.00GHz Quad Core DDR3 System @ £456.77 inc VAT
The "Titan Krypt" features a AMD Athlon II X4 Quad Core 640 3.00GHz Processor, combined with a selection of high performance, handpicked components designed to meet your desire for the perfect gaming system.
Why Should You Buy This System?
- Includes the superb AMD Athlon II X4 640 3.00GHz Quad Core Processor
- 4GB of high performance gaming memory guarantees the smoothest possible experience when multitasking and ensures you never have a break in the action
- Case: Antec 300 Gaming Case
- Power Supply: OCZ 600w StealthXStream II
- CPU: AMD Athlon II X4 Quad Core 640 3.00GHz Processor
- Motherboard: Asus M4A78LT-M 760G (AM3) Motherboard
- RAM: Corsair Dominator 4GB (2x2GB) DDR3 PC3-12800C9
- Hard Drives: Seagate Barracuda 1TB 6GB/s SATA-II 16MB Cache
- Graphics Card: Choice of the latest DirectX 10 and 11 graphic cards
- Sound: 7.1 Channel Sound (On-Board)
- Optical Drive: OcUK 22x DVD±RW SATA ReWriter (Black)
Service Package
If your after the latest in AMD technology then this system is for you. Quad core technology and DDR3 perforamnce at an excellent price point.
Was £475.97 Inc. VAT
Only £456.77 inc VAT.
ORDER NOW
TT Esports Gamers Headset Shock - White @ £32.39 inc VAT
nonl2br
The TT Esports Gamers Headset Shock brings gaming to a new level. Immerse deeply into your games with 40mm speaker drivers and stereo surround sound. Take advantage of your soundcard with 3.5mm speaker jacks bringing maximum sound performance. The ultra comfortable padded earcups make sure that comfort is key, especially for intense professional gaming. <br><br>
- Stereo surround sound<br>
- Quality 40mm speaker driver with enhanced bass performance<br>
- Noise cancelling microphone for communciation in gaming activities<br>
- Control Box with In-line control box for instant gaming sound control<br>
- 10 Levels adjustment for a perfect fit<br>
- Foldable design<br>
- Gold plated 3.5mm connctor<br>
<br>
<br>
<iframe title="YouTube video player" width="640" height="390" src="http://www.youtube.com/embed/2gampqTGEf8" frameborder="0" allowfullscreen></iframe>
Was £34.98 Inc. VAT
Only £32.39 inc VAT.
ORDER NOW
Hitachi Deskstar 7K3000 3TB SATA 6Gb/s 64MB Cache 7200RPM - OEM @ £129.98 inc VAT
The Deskstar™ 7K3000 is Hitachi’s first hard drive to deliver an enormous three terabytes of storage capacity and 7200 RPM performance in a standard 3.5-inch form factor. The 7K3000 is also the first Hitachi hard drive with a 6Gb/s SATA interface, which along with its 64MB cache buffer delivers a big boost to performance over the previous generation product.
- Backwards compatible with SATA-II
- Part Code: HDS723030ALA640
- Capacity: 3TB
- Cache: 64MB
- Spin Speed: 7200RPM
- Bootable with Sandybridge P67/H67 Motherboards
- Warranty: 3 Years
NOTE: These drives are only bootable on 64bit versions of windows Vista and 7 as well as OSX and Linux. These will work as storage on 32bit versions.
Only £129.98 inc VAT.
ORDER NOW
TT Esports Gamers Headset Shock - Black @ £32.39 inc VAT
nonl2br
<br>
<br>
Was £37.99 Inc. VAT
ORDER NOW
Speedlink Spes Clip-On Metal Microphone (SL-8691-SBK) @ £5.99 inc VAT
The microphone is attractively designed and is extremely practical. The noise-suppression system filters out bothersome background noises and makes internet chat easy and uncomplicated. Furthermore, the clothing clip allows you to clip the mic anywhere you like.
- Lots of freedom of movement thanks to the 2.4m cable
- You'll hardly notice you're wearing the mic thanks to it's low weight
- Easy to attach to clothing thanks to the clip
- Highly sensitive microphone featuring noise suppression
- Robust design made from black metal
Was £6.50 Inc. VAT
Only £5.99 inc VAT.
ORDER NOW
Western Digital Caviar Blue 500GB SATA 6Gb/s 16MB Cache - OEM (WD5000AAKX) @ £29.99 inc VAT
nonl2br
<center>
<div id="docview"><object classid="clsid
" quality="high" pluginspage="http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash" type="application/x-shockwave-flash" width="728" height="90"></object></div></center>
<br>
WD Caviar Blue hard drives are available with a multitude of available features to deliver rock solid performance and ultra-cool and quiet operation. Pick the drive that suits your needs with the confidence in knowing that all WD Caviar Blue drives are built to the highest standards of quality and reliability. These drives are the perfect solution for family and business computing.
<br>
<br>
<br>
- Capacity: 500GB
<br>
- Cache: 16MB
<br>
<br>
<br>
- Seek Time: 8.9ms
<br>
- Warranty: 3 Years
<br>
<br>
Was £32.99 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Saitek PZ52P VGA Webcam - Pink @ £3.30 inc VAT
This great value webcam which is fully compatible with laptops, netbooks and desktop PCs is perfect for video messaging applications. Keep in contact with your friends, family and loved ones.
- Easy Capture, click and send
- 640 X 480 resolutions
- Broadcast live video over the web
- Great for video chat, video mail & video conferencing
- Works with MSN, Yahoo, Windows Messenger & more
Was £3.59 Inc. VAT
Only £3.30 inc VAT.
ORDER NOW
Trust Invido VGA Smart Clamp Webcam (16430) @ £7.80 inc VAT
Stylish webcam that works with all chat programs such as MSN/Live Messenger, Skype & online video applications. With a smart intergrated clamping system, easily attach the webcam to notebook screens, flat panel display or just to sit on flat surfaces.
- USB webcam with 640 x 480 hardware resolution
- 1.3 megapixel snapshot resolution
- Snapshot button to quickly take a picture
- 2x digital zoom and automatic face tracking technology
- Ideal for Live Messenger, MSN Messenger, Skype and other messenger services
- The camera stand can also be used to attach the webcam to the screen of a notebook or desktop PC
Was £8.39 Inc. VAT
Only £7.80 inc VAT.
ORDER NOW
Rift 60 Day Timecard - Digital Email Delivery @ £16.20 inc VAT
The prepaid gamecard is a comfortable payment method to receive 60 additional days of gametime for RIFT. Follow the included descriptions and you are ready to play again in a few minutes.
After the expiration of the 60 days, the subscriptions fee has to be paid again – or you extend your gametime again with a Game Card. The full version of RIFT and an internet connection are needed to play.
Digital email delivery (no shipping cost)
Was £16.98 Inc. VAT
Only £16.20 inc VAT.
ORDER NOW
Thrustmaster T500 RS Simulator Racing Wheel for PS3 & PC (Licensed for Gran Turismo 5) @ £379.98 inc VAT
H.E.A.R.T. HALLEFFECT ACCURATE TECHNOLOGY™” is the name of the new technology developed by Thrustmaster to reproduce movements made on a product in games. It relies on magnetic – and not mechanical – 3D (HallEffect) sensors, placed in different locations according to the product in question. The precision made possible by the use of this technology is significantly higher than that provided by standard technologies. Another advantage of this system: by eliminating all friction, it guarantees zero mechanical wear, for permanent precision that won’t decrease over time. The level of precision is also enhanced by the absence of any dead zones: even the slightest movement made by the player results in a reaction. Actions in games are therefore more linear, smoother and without any untimely jolts.
- Authentic wheel: 30cm (12”) in diameter with brushed metal central spokes
- Authentic sequential gearshift levers: crafted of brushed metal, attached to the base (so they don’t move with the wheel)
- 17cm in height (for instant access along 1080°)
- Precision, Force Feedback & realistic angle of rotation
- New H.E.A.R.T Hall Effect AccuRate Technology™ on the wheel’s steering:
- Ultra-precise wheel, with 16-bit resolution (65536 values on the steering)!
- Precision that won’t decrease over time (contactless magnetic sensor)
- Force Feedback with industrial motor (Torque 150mNm, 3000rpm, 65W, Ø 52mm/2”)
- Super-powerful, quick responding Force Feedback mechanism
- Rigid motorized stopper, no matter what angle of rotation you select
- Mechanism with large dual belts (fluid and smooth action)
- Angle of rotation adjustable up to 1080° (3 full turns)!
- Realistic pedal set
- Unique design with your choice of 2 positions:
- Floor-mounted position (F1-style)
- Suspended position (GT-style)
- 100% metal, for optimal stability, weight (more than 7 kgs) and resistance
- 3 100% adjustable pedals (spacing between the pedals/height)
- Brake pedal with reinforced and adjustable resistance (included and removable “Realistic Brake” mod)
- Included metal footrest with non-slip grating texture
Was £399.98 Inc. VAT
Only £379.98 inc VAT.
ORDER NOW
Samsung SpinPoint F4 EcoGreen 2TB SATA-II 32MB Cache - OEM (HD204UI) @ £62.99 inc VAT
Samsung's F4 EcoGreen is the first drive available to feature 667GB per platter. Samsung’s F4 Series EcoGreen Drive (F4EG) is the ideal high capacity drive for green computing environments. The new eco-friendly hard drive, F4EG is designed to meet demand for high performance devices with lower power consumption. Samsung’s EcoGreen F4 makes it possible to design storage systems with the right balance of high capacity, fast performance and energy conservation. Samsung F4EG has the world’s best areal density at 5400RPM rotation speeds. High density means more bits pass under the head faster, and it improves the drive performance. Samsung employs an advanced data recording technology, which brings the next generation technology into today’s single disk platform, enabling Samsung’s new 5400RPM drives to perform at current 7200RPM drive speeds. The internal SysMark test results confirms that F4EG performs as same as 7200RPM drive speeds, and even 10% faster than other green drives.
- Capacity: 2TB
- Cache: 32MB
- Interface: SATA-II
- Spin Speed: 5400RPM
- Seek Time: 8.9ms
- 3.5" Drive
- Warranty: 3 Years
Was £65.99 Inc. VAT
ORDER NOW
OcUK Value 320GB 2.5" Mobile Hard Drive External USB2.0 @ £37.99 inc VAT
The OcUK Value 320GB USB external hard disk is small in size for exceptional portability. USB powered with no bulky power adapter required coupled with an 5400rpm hard drive.
Key Features
- High Speed USB 2.0
- 5400rpm Spin Speed
- 2.5" Form Factor
- No External Power Supply Required
- USB Bus Powered
- Maximum Reading Transfer Rate - 33 MB/s
- Maximum Writing Transfer Rate - 35.5 MB/s
- 8MB Cache
- Supported Operating Systems: Microsoft Windows 98/SE/ME/2000/XP/Vista/7, Mac OS X 10.x, Linux 2.4x
Was £39.98 Inc. VAT
Only £37.99 inc VAT.
ORDER NOW
OcUK Value 500GB 2.5" Mobile Hard Drive External USB2.0 @ £44.99 inc VAT
The OcUK Value 500GB USB external hard disk is small in size for exceptional portability. USB powered with no bulky power adapter required coupled with an 5400rpm hard drive.
Key Features
- 2.5" Form Factor
- USB Bus Powered
- 8MB Cache
Was £46.99 Inc. VAT
Only £44.99 inc VAT.
ORDER NOW
OcUK Value 1TB 2.5" Mobile Hard Drive External USB2.0 @ £72.98 inc VAT
- 1TB USB external hard disk with small size for exceptional portability
- USB powered; no bulky power adapter required
- 5400 rpm spin rate; 8 MB cache; and transfer rate of up to up to 480 Mbits per second
Key Features
- 2.5" Form Factor
- USB Bus Powered
- 8MB Cache
Was £74.99 Inc. VAT
ORDER NOW
Philips SPA2602 5.1 Surround Sound Speaker System @ £34.99 inc VAT
Perfect for MP3, PC, TV and more.
Connect your speakers to all your gear. A great way to listen to your MP3 player, PC, TV, CD, DVD and all your multimedia stuff.
Sound
- Bass enhancement: Analogue Bass Boost, Bass reflex
- Frequency response: 35 - 20 K Hz
- Loudspeaker Enhancement: Magnetic Shielded LSB
- Music Power: 90 W
- Volume Control: Analogue Volume Control
- Wires: Fixed Wires
- Output power (RMS): 45 W
Loudspeakers
- Satellite speaker drivers: 3"
- Subwoofer driver: 4.25"
Connectivity
- Audio input for data: Stereo Audio (3.5 mm jack) 1 x
- Cable length: 1.5 m
- Connector: 3.5 mm stereo
Was £39.98 Inc. VAT
Only £34.99 inc VAT.
ORDER NOW
Xenon AMD Phenom II X6 1055T 2.80GHz Bundle - Six Core @ £219.98 inc VAT
Designed by experts the "Xenon AMD Phenom II X6 1055T Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "Xenon AMD Phenom II X6 1055T Bundle" offers you speed and silence in perfect combination.
Why You Should Buy This Bundle?
- Prebuilt and configured. Just "plug and play"
- 4GB of Dual Channel DDR3 memory delivers fast load times
Bundle Specification
- CPU: AMD Phenom II X6 Hex Core 1055T 2.80GHz
- Motherboard: Gigabyte GA-M68MT-S2 (Socket AM3) DDR3 Motherboard
- RAM: GEIL Value (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel
- Cooler: AMD Stock Cooler
Service Package
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Was £239.98 Inc. VAT
Only £219.98 inc VAT.
ORDER NOW
"Radon Allosaur" Intel Core i5 2500K 3.30GHz @ 4.40GHz Overclocked Bundle - Asus @ £449.98 inc VAT
Designed by experts the "Radon Allosaur Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.40GHz overclock has the processing power and speed unseen at this price point ever before. The "Radon Allosaur Bundle" will accelerate your computer experience into the next level.
- A solid, optimised 4.40GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 4GB of Dual Channel DDR3 memory delivers unsurpassed bandwidth
- CPU: Intel Core i5 2500K 3.30GHz @ 4.40GHz Sandybridge CPU
- Motherboard: Asus P8P67 PRO Intel P67 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
- Cooler: Corsair A50 CPU Cooler
- Artic Silver 5 Thermal Compound
Service Package
Was £489.98 Inc. VAT
Only £449.98 inc VAT.
ORDER NOW
"Krypton Ankylosaur" Intel Core i7 2600K 3.40GHz @ 4.60GHz Overclocked Bundle - Asus @ £549.98 inc VAT
Designed by experts the "Krypton Ankylosaur Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.60GHz overclock has the processing power and speed unseen at this price point ever before. The "Krypton Ankylosaur Bundle" will accelerate your computer experience into the next level.
- A solid, optimised 4.60GHz overclock profile provides outstanding processing performance
- USB3, SATA 6GB/s, Intel Ethernet and UEFI graphical BIOS for next gen computing
- CPU: Intel Core i7 2600K 3.40GHz @ 4.60GHz Sandybridge CPU
- Motherboard: Asus P8P67 DELUXE Intel P67 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
Service Package
Was £579.00 Inc. VAT
Only £549.98 inc VAT.
ORDER NOW
Asus Xonar DG 5.1 PCI Sound Card with built in Headphone Amp @ £24.98 inc VAT
The Xonar DG sound card combines Dolby Headphone 5.1 high definition surround with Asus’ own GX 2.5 gaming audio engine and an on-board headset amplifier. These result in accurate and deep audio that brings every nuance and sound across fully, making the new Xonar DG an ideal sound card for gamers who want to remain totally aware of their play environments.
- Built-in Headphone AMP
- Powers up every sound detail in gaming
- 3 gain modes for different usage scenarios
- Dolby Headphone for an immersive 5.1 surround imaging
- GX2.5 for realistic 3D audio effects
Was £26.99 Inc. VAT
Only £24.98 inc VAT.
ORDER NOW
ASRock M3A770DE AMD 770 (Socket AM3) DDR3 Motherboard @ £49.99 inc VAT
Devoting efforts to bring customers the innovative and reliable motherboards with the design concept of 3C, "Creative, Considerate, Cost-effective", ASRock has successfully established a well-known leading brand of the best price-performance motherboard in the industry. ASRock products' high recognition stems from company’s devotion to bring the most cost-performance products to users.
- Support for Socket AM3 processors: AMD Phenom II X6 / X4 / X3 / X2 (except 920 / 940) / Athlon II X4 / X3 / X2 / Sempron processors
- Northbridge: AMD 770
- Southbridge: AMD SB710
- 4 x DDR3 1600(OC)/1333/1066/800MHz DIMM slots
- 7.1 CH HD Audio
- Realtek RTL8111DL Gigabit LAN
- 2 x PCI Express 2.0 x16 slots (green @ x16 mode, orange @ x4 mode)
- Supports ATI™ CrossFireX
- 1 x PCI Express 2.0 x1 slot
- 3 x PCI slots
- 4 x SATA-II 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, and JBOD)
- 1 x ATA133 IDE connector (supports 2 x IDE devices)
- 1 x Floppy connector
- 10 x USB 2.0
- 1 x PS/2 Mouse Port
- 1 x PS/2 Keyboard Port
- 1 x Coaxial SPDIF Out Port
- 1 x Optical SPDIF Out Port
- 2 x Powered eSATAII/USB Connectors
Was £53.99 Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
