Help finding a part
27 Nov 2004
North Beds
Hey guys,
My google skills are weak this morning.
Basically, I'm looking for somewhere I can buy clamps that are used when making telescopic poles, ie lightstands etc, to clamp a smaller tube into position as it slides out of a larger tube.
essentiall it's 2 attached circular pieces of nylon with screws that tighten the circle so that it cllamps around the tube, that reduces in size on the 2nd one so that it clamps the smaller one.
usually the larger side has a normal bolt done up to be permanently clamped, and the smaller side has a thumb screw that you do up when the pole is at the right position:
That's what they look like
Any ideas? I need a variety of sizes to make my own telescopic pole, ie 28-26, 26-24, 24-22, 22-20 reducers.
Cheers
Tom
PS if anyone has an insight into how the twist lock poles work i'd be even more interested, but I can't actually modify the poles as i dont have the tooling so if it requires intervention from that end then im stuck.
Cheers
Tom.
ive seen that but they aren't metric :( Also it looks like it screws into the pole instead of just tightening the sheath, which is no good as i dont want to damage the pole (carbon fibre)
it's for a camera rig, 4x1m carbon fibre poles with a 4kg camera at the end so the clamps need to be fairly substantial! Cheers for your help though.
Cheers
Tom.
They work by threading the end of the poles and cutting slots parallel with the length of the pole. The ring on the end is tapered so that as it is tightened, the diameter of the thread reduces, pinching the flaps created when the slots were cut.
As you don't want to modify the poles, this is probably out of the question.
Any reason apart from weight it needs to be carbon fibre?
Just you can buy an aluminimum extending pole from the website I linked all made for £27.45.
Ahh, I just cheated and used a fishing pole... the sales assistant did look at me strangely when I bought it though as I only wanted the large diameter end sections, lol.
http://www.windowcleaningsupplies.net/prod_show.asp?prodid=640
best I can find
Edit:
More towards the bottom of this page:
http://www.johnhewitt.com/brushes.htm
second link looks spot on!
Out of interest with the fishing pole, is it possible to get them in carbon fibre ~5m lengths with the smallest OD being ~20mm? Almost all the sites i can find dont really list the diameters of the poles.
at 4-5m long with a 4-5kg weight on the end, aluminium bows a lot, carbon fibre far less so.
To be honest rG-tom, I had to go to a fishing store and look (Stapley water gardens was the one I went to). I know zilch about fishing!
The one I ordered, was out of their spares catalogue, as I didn't want the full length of it (they come in huge lengths!), but unfortunately went "missing" after a shoot!
The second link looks like a supplier to all of those "window cleaning pole" places, so should be spot on.
Deadline? I could recycle some off some busted stands and post them, but might take a week or so to arrive. I work in a studio so have plenty to hand, all Manfrotto.
