Intel Ivy Bridge and Panther Point details
The scenario seems to be similar to Core 2 series where the earlier core 2 cpus were 65nm for both duo and quad. Later the core 2 series underwent die shrink to 45nm and these were more efficient and about 10% faster than their 65nm counterparts. All these were skt 775 cpus and were compatible with different chipsets (especially later one) such as P45, X48, P35 etc.
I don't think all the Ivy Bridge cpus will be skt 1155 compatible though especially 8 cores or 10 cores if they form part of Ivy Bridge aswell. It may be the case of 4 cores Ivy Bridge but not 6,8 or 10 cores cpus.
Looks interesting, looking forward to seeing how these new chips perform against the SB and whatever AMD come out with.
I do not think you will see anything over 4 cores on 1155, that is what the high end sockets are for.
Can't wait to see how these perform compared to Sandy Bridge and also it will be interesting to see how AMD responds to this in what they release to compete with it.
Stoner81.
It will be interesting to see how they perform compared to Sandybridge-E as they are launching a few months apart.
Significantly slower, significantly cheaper, Sandy -e will be 8/6 core chips(its unclear if there will be quad core chips, but quad channel memory, full 16x slots for sli/xfire is simply a waste for a quad core), Ivy bridge is dual/quad core, supposedly 20% faster than Sandybridge, though that could be averaged out with a 50% bigger gpu part(as in 50% more cores in it) could offset that so its almost the same cpu but with cpu benchmarks as they were, and gpu benchmarks 40% faster, average will be 20% faster. Or it could just be 20% faster due to 20% higher clock speeds, no one really knows yet.
In other words, it would seem a quad core Ivy wouldn't match a theoretical 5 core Sandybridge.... as Sandybridge-e is 8 cores, Ivy isn't going to touch it.
Haswell is the next really interesting Intel platform, octo cores in the mainstream segment, though I assume it will depend on Bulldozer and potentially how many cores 2nd gen Bulldozers have as to if they will be priced around say a 2600k, or way higher, hopefully we'll be seeing octo cores(with improve architecture on top) in the 2500-2600k price bracket.
Haven't actually seen info on it but I am assuming we'll see 22nm 8 core Ivybridge based chips on the high end platform before Haswell launches(late 2012/early 2013).
Is there any particular reason that Ivybridge on 1155 couldn't have more than four cores? I appreciate that in the last gen, Intel reserved the higher core counts for the LGA1366 platform, but we're a generation ahead now.
It's nice that IB will work in my LGA1155 but I really don't expect to need a CPU upgrade within four years or so unless a) games start to really benefit from more cores and b) I can upgrade to >4 cores on my 1155.
Sandybridge can work in the Ivybridge chipset mobos but not the other way around due to the memory slots its impossible to do quad channel in a sandybridge motherboard but you can do dual channel in an ivybridge motherboard.
Ivybridge isn't quad-channel, is it? I thought that was just Sandybridge-E (ie. the socket 2011 mobos). Ivy is just a die shrink of Sandy and will assumedly come in 1155 and 2011 flavours (ie. dual and quad channel versions).
Seeing as the OP says that Ivy will work in Cougarpoint mobos, I'd assume that both Sandy and Ivy CPUs/chipsets will be cross-compatible - just so long as they use the same socket pinouts, obviously!
Oh meh, thought ivybridge was the quad channel platform could have been mistaken all these codenames confuse me sometimes.
