Is your GTX 580 or GTX 570 to hot and loud?
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Your fast but annoying loud and hot rubbish GTX 580 and GTX 570 can now be made not rubbish and loud with this amazing GPU cooler. No fiddlying with the VRAM sinks as you get a plate to screw them all on. Making this the easiest aftermarket cooler ever.
Zalman VF3000-F Graphics Card Cooler (GTX570 and GTX580) @ £44.99 inc VAT
The dual 92mm fans cool not only the heatsink and VGA RAM, but all other peripheral components surrounding the VGA chipset.
- Powerful Cooling Performance
- Ultra Quiet Design
- Ultra Quiet Green LED Fans
- Adjustable fan controller
- High Performance ZM-STG2 thermal grease
- Includes VRAM Sinks
PLEASE NOTE REMOVING THE STOCK COOLER MAY INVALIDATE YOUR GRAPHICS CARD WARRANTY
Only £44.99 inc VAT.
ORDER NOW
Nice cooler but why are they more expensive when released compared to the 480 and 5870 coolers,they are exactly the same.
Can you not get hold of the 480 versions of these any more? I posted in the product suggestion section a couple of months ago and heard nothing back :(
The reason the price is higher is because I am having some air frieghted in from the Far East - otherwise they will take about 8 weeks to get here on a boat.
