Is your GTX 580 or GTX 570 to hot and loud?
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Your fast but annoying loud and hot rubbish GTX 580 and GTX 570 can now be made not rubbish and loud with this amazing GPU cooler. No fiddlying with the VRAM sinks as you get a plate to screw them all on. Making this the easiest aftermarket cooler ever.
Zalman VF3000-F Graphics Card Cooler (GTX570 and GTX580) @ £44.99 inc VAT
The dual 92mm fans cool not only the heatsink and VGA RAM, but all other peripheral components surrounding the VGA chipset.
- Powerful Cooling Performance
- Ultra Quiet Design
- Ultra Quiet Green LED Fans
- Adjustable fan controller
- High Performance ZM-STG2 thermal grease
- Includes VRAM Sinks
PLEASE NOTE REMOVING THE STOCK COOLER MAY INVALIDATE YOUR GRAPHICS CARD WARRANTY
Only £44.99 inc VAT.
ORDER NOW
Aren't these actually quite cool running and it's the 480s which run really hot?
If these will fit in sli then they could be pretty good though :)
id buy one just cos it looks cool, if i owned a 580... :D
n zalman.. well if my cpu coolers anything to go by these should drop temps quiet a bit :)
Do they invalidate the warranty on EVGA cards? I think i read you can change the cooler just make sure not to damage anything incase you need to put the origonal stock cooler back on if you need to RMA.
