I have posted this on Fiestast forums and they think it is a oil seal what will need looking at as soon as possible.
Thought i would ask here aswell out of curiosity, maybe someone else has had a similar problem and can shed some light on it?
Copy and pasted:
I will go out and check the car after Formula 1 as finished to see if it has leaked anymore.
Just hoping what i thought was a minta off a really nice honest loaded family, isn't actually a great big lemon!
Copy and pasted:
After jacking the ST up i found this on the floor:
It is like red lubey stuff? Doesn't smell like oil...
This is where it was leaking down:
Do you think it is engine coolant? Just checked the engine coolant reservoir and its pretty much empty so i will top that up in not long. If it is this, what will be the problem? where will it be coming from?
anything else it could be?
Thanks
