Do you do internet banking on your phone?
1 Sep 2007
Santa Monica, California
I don't think this belongs I Mobile section...
Just a general question, I mean with SSL enabled it wont go through the network proxy so in theory other than shoulder surfing it should be safe right?
I get the texts off my bank to tell me my statement every week.
It also sends me a text if I go under a certain limit etc, which never happens because i'm loaded.
I don't login using my mobile network though.
I do when I need to access it on the move, not because of security concerns its just a pig to use.
I do check that no one is over my shoulder but from a technical point of view I have no reason to distrust the SSL implementation
One of my banks has an iphone app that I use. It's useful in a situation where all you need is a quick mini-statement.
No, it may be secure, but I just don't trust it over a 3G connection.
Besides I have never really had cause to use it outside of a PC, telephone banking is just as effective if you really must access information from a mobile and without the (perceived) risk.
No, only because HSBC don't seem to support it. There's no app, for Android anyway, and the website would be far too clunky on a small display.
