Freenas raid for 5 hard drives
13 Oct 2005
Hi, Ive currently built a freenas server with 5 x 2 TB hard drives. I was wondering what the best way to set these up would be. I am thinking a raid-5 configuration would be best. What are peoples thoughts on this? Also what would be the advantages of this in a raid-z format? And is there also a way to grow my raid setup and add more space to the pool. I can imagine my storage running out fast in a year to come.
You might like to consider RAID-6. It offers n-2 drives capacity BUT can cope with any two drives failed.
Means to say that if one drive fails and you swap it out, if another drive should fail during recovery you're fine :)
That sounds good. Is there a way to then add to more hard drives later down the line to the raid array and grow the pool of storage? This is a pretty big concern of mine to be honest.
Basically - yes .
But you haven't really given enough info to advise on anything.
The problem is - if you ar asking if its even possible, you have a bit of a way to go before being able to actually do it, as it's not really a simple matter, and you need to know what you are doing.
Firstly - why do you need RAID? Do you even need raid? Why not just use seperate drives, much easier to increase total storage capacity that way.
That is true I could use individual drives. I am setting this freenas box up so that I can rip my blu-rays to it and then share them around the house. I wanted to go the RAID route so that if one or two drives failed I would still have the data intact and I could replace the damaged drive depending on the raid level I was to use.
If I used separate drives, I would lose some of my data if one was to fail. I would also like to be able to use my drives as one pool rather than a few. My knowledge of raid arrays is very limited at best so please bare with me :)
I also found this post on another forum, would this work?
What you are asking is not possible with traditional RAID5. For a very similar solution where growth IS possible, take a gander at ZFS (raidz1). What you do is the following:
1. Add disks and "format" them as zfs storage pool devices.
2. Create a virtual device (vdev) that combines your disks in single parity raidz1 (just like raid 5).
3. Add this vdev to a zpool which you can mount and use.
The vdev is your "array," and the zpool is a volume group of arrays/devices. In the future if you need to grow, you can add additional virtual devices to the zpool. You can also replace the disks of a vdev one at a time with larger disks. Both ways provide opportunities for expansion.
Things to keep in mind: ZFS is stable but still in development in Freenas 0.7. It runs better in a 64-bit environment, and can cause significant cpu overhead (similar to software raid5) as you add more devices to a vdev. ZFS vdevs can be files, slices of disks, whole disks, raid 5 groups, raid 6 groups, or mirrors, although the latter three are the only recommended setups for vdevs. Also, ZFS distributes data across the vdev members of a zpool, so if you had one vdev with raidz and another vdev with no parity/redundancy at all, data on your entire pool is vulnerable to failure of the second vdev. So it's important to maintain configurations with parity for any future vdevs that you add.
Some reading material for you: http://blogs.sun.com/bonwick/entry/raid_z
powerofpi
No
What you want is backup solution then not a raid array. Then if a drive goes down just restore from backup.
What about the scenario if you are rebuilding your array and another drives pops or you accidentally format thewrong drive when upgrading ?
5x2 tb in raid 5 gives 8tb
Instead get something like 4x2tb and 2x 3tb or even depending how much data you need to store at first get 2 x2tb and 1 3tb for backup. Then easily expand as needed.
I like that idea, I will probably get some 3tb hard drives in the near future and place them in my main computer, away from the freenas box. This way I can back the files up on the main computer and still have a backup that is separate from the server.
Good plan. Get usb drive though, rather than internal drives. Also you can take your usb drive a to a friends house should you want to, much easier than a whole raid array + computer etc
Ive got a usb dock for hard drives that I could use, I could then back up my data once a week and leave the hard drives at my girlfriends in a rugged secure case. At least then my data will be off site and hopefully secure. Thanks very much for the help!
