Hey guys can i have your opinions please??
The website is out of place on my laptops resolution.
Website seems ok though, a little plain but you don't need anything fancy. Its what you're happy with.
The thumbnails should disappear when enlarged. The half hidden hover over text on the right just looks silly. There is nothing flowing on the page it just looks cobbled together.
Can you to suggest anyway to make it flow, this is my first flash project so any suggestions would be great.
I have made the thumbnails dissapear now.
Fails W3C validation and flash movies really should be in an object tag rather than an image tag.
Have you had a look at lightbox instead of flash? Means your website can then be viewed certain phones and tablets. :D
Technically, good job.
But design and usability-wise, it's a bit of a PITA. At first I thought the layout was completely broken.
