New Rig! Advice?!
17 Apr 2011
Building my first PC and was hoping to get a few pointers/corrections or suggestions, you all seem to know your stuff! Link to my basket below.
http://i.imgur.com/MTsZa.jpg
Heres the links to each of the components, any criticisms of the rig would be greatly appreciated, im hoping to get the best fitting system for the cash I've got! Thanks a bunch all!
Graphics Card : http://www.overclockers.co.uk/showproduct.php?prodid=GX-259-SP
Processor : http://www.overclockers.co.uk/showproduct.php?prodid=CP-253-AM
RAM : http://www.overclockers.co.uk/showproduct.php?prodid=MY-062-GS
Power Supply : http://www.overclockers.co.uk/showproduct.php?prodid=CA-035-CS
Blue Ray : http://www.overclockers.co.uk/showproduct.php?prodid=CD-138-SA
Motherboard : http://www.overclockers.co.uk/showproduct.php?prodid=MB-034-AK
Case : http://www.overclockers.co.uk/showproduct.php?prodid=CA-037-ZA
Hard Drive : http://www.overclockers.co.uk/showproduct.php?prodid=HD-067-HI
Thanks again!!!! :D
You could save some money and go with 955 and overclock to 965 speeds.
Hard drive I use the the Samsung 1tb F3 which is pretty good drive, not sure how the Hitachi compares with the Samsung.
I have the 965 stable at 3.8.Air cooling no voltage increase.
OFC this is cpu dependent but its a great overclocker. I recon I could hit 4 with slight volt increase and better cooler.
Thank for the reply, ill definitely take a look at the 955 so, and the f3! Cheers!
