Hi there
Many people have been waiting for more affordable 24" panels with wider viewing angles and now iiyama have delivered, except its not just wide viewing angles, you also get LED backlighting too:-
IIyama Prolite X2472HD 24" Premium VA Panel Widescreen LED Monitor - Black @ £199.99 inc VAT
ProLite X2472HD - a 24” LED backlit LCD Screen featuring VA Panel technology offers superb colour performance and amazing viewing angles. Offering 24 bit ‘True Colour’ and great performance for displaying Black and White with the 3000:1 Native Contrast Ratio, means that the Prolite X2472HD will provide excellent performance for Photographic, Design and Web-design. Featuring a fast response full HD 1920 x 1080 Display with VGA, DVI and HDMI connectivity this screen ensures compatibility with a wide range of systems and applications. With the added support of a Low Power LED Panel, the iiyama Prolite X2472HD is an excellent choice for Universities, Corporate, Financial and Design Markets.
Features:-
- Diagonal: 24"
- Panel: VA, LED-Backlit
- Display area: h x w 298.9 x 531.4 mm; 11.8" x 20.9"
- Response time: 8 ms
- Contrast: 3000 : 1 typical
- Contrast: 5 000 000 : 1 ACR
- Brightness: 250 cd/m² typical
- Viewing zone: horizontal/vertical: 178°/ 178°; right/left: 89°/ 89°; up/down: 89°/ 89°
- Display colour: 24-bit, 16.7 million
- Pixel pitch: h x v 0.277 x 0.277 mm
- Native resolution: Full HD 1080p, 1920 x 1080 ( 2.1 megapixel)
- Horizontal sync: 30 - 75 KHz
- Vertical sync: 55 - 70 Hz
- Synchronization: Separate sync
- Aspect ratio: 16 : 9
- Analog input connector: D-Sub
- Digital input connector: DVI-D, HDMI
- HDCP: yes
- Output connector: Audio out (only with HDMI input)
- 3yr Warranty
Only £199.99 inc VAT.
ORDER NOW
Features:-
- Diagonal: 24"
- HDCP: yes
- 3yr Warranty
ORDER NOW
