- 23 May 2005
- Nottingham
So, anyone managed to get their hand on one of these yet? Anyone even been lucky enough to play with one of these and the Asus? Any idea how the build quality compares?
Asus eee tablet is better on those fronts.xoom is way over priced and seemed slower and the display was not as good![]()
hating apple its hard for me to say but the ipad2 is better value for money, xoom is way over priced and seemed slower and the display was not as good![]()
real lack of widgets and support at the min, it kinda looks empty, i hope the sammy tab2 comes good.
I have a Xoom. Bought it from CPW at a cost of £579. I am not normally one to be an early adopter, but I really fancied a tablet to make my commute into London a little more enjoyable.
I am using it for
* Web Browsing - Smooth, works basically like a desktop browser, albeit without extensions. Tabbed and syncs with your Chrome faves. Only issue is that as it identifies itself as an android browser, some sites will auto direct you to the mobile site.
* E-book - I have installed Kindle. Works fine, easy to read. You can do all the normal things such as size text, bookmark etc. It is not great in direct sunlight as a true Kindle would be and maybe a little heavy for holding for prolonged periods, but for a 45 minute train ride it is just dandy.
* Gmail - much better than the normal Android client. Really good app if you are a heavy Gmail users. Comes with a widget to see your most recent 5 emails
* Calendar - default week to a page view. Again better than the standard android. Includes widget.
* Video - using Vplayer, most video types are supported without the need for re-encoding (one of the main reasons I went for a Xoom over an Ipad). 720p needs to be optimised though as it can be a bit jerky.
* Music - yep, that works
* Twitter/Facebook etc - all good, no issues.
* Games - Not a massive thing for me, but the ones I have tried seem to work fine. My 6 year old loves Angry Birds in HD.
Other useful apps/uses
* Evernote - not yet really maximised to support the bigger screen, but it is better than using the pure phone version
* Read-it-Later - great app for catching up on articles you don't normally have time to read
Cons -
* lack of App support. Waiting for 'The Economist' android version, along with other similar Media apps.
* Still waiting for MicroSD card support.
* The comments about it being released half baked, certainly apply to the OS and the app support. The Hardware itself is solid, and I can't fault it.
Other Random thoughts
* Keyboard - is actually fine to type on screen. I wouldn't want to type an essay on it, but for an email or IM it is fine.
* Camera - no idea, haven't tried it. Still not sure what I would use it for (other than the forward one for Video calling, and the rear one for Evernote scanning)
* Battery life - about 10 hours of normal usage. Doesn't charge through USB though, you have to use the bespoke charger.
* Case - you would want a case for it, and the Motorola one is good, as it doubles as a stand.
Overall, I am pleased with it, and it will grow in supported uses and apps, so I imagine it will get more and more use over time.
In all honesty the Xoom seems a little outdone now, the transformer has it beat in everything including price imo.
