Upgrade time!
22 Jul 2010
So I had my eyes on this:
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor with FREE Operation Flashpoint Red River Game £167.99
(£139.99) £167.99
(£139.99)
Asus P8P67 Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) ** B3 REVISION ** £129.60
(£108.00) £129.60
(£108.00)
G.Skill RipJawsX 4GB (2x2GB) DDR3 PC3-17000C9 2133MHz Dual Channel Kit (F3-17000CL9D-4GBXL) £47.99
(£39.99) £47.99
(£39.99
It will be replacing a E6600, P5NE SLI and 4gb geil value ram.
Would you guys change anything from that spec?
Also i currently have a corsaid 520W PSu, will that be enough to power this badboy?
Cheers
James
You dont need ram with such a high speed rating, 1600mhz ram is more than enough, be around £40 too.
PSU is fine.
Patriot Viper Xtreme 4GB (2x2GB) PC3-16000C9 2000MHz Dual Channel Kit
2000MHz RAM Speed, CAS 9-10-9-27 Timings, 1.55-1.65v VDIMM, Lifetime Warranty with Patriot.
Patriot 10+ in stock £59.99
(£49.99)
Something like this stulid?
lol okay, thanks a bunch, i was pretty into my over clocking when i ddi the E6600, is the sandybridge pretty similar? Gonna be punching it up to about 4.4-45ghz.
45ghz is probably going to be too high!:D
Jokes aside, yes it will be fine with good cooling it can even go higher...
haha, well i though 4.5 would be awesome considering i had my E6600 at 3.6ghz. I'm not out to set the world on fire just wanted something nice for my encoding and gaming.
No, completely different. It's too easy now as it's just done with the multiplier and a bump or two on voltages.
