Connecting 3 Monitors
17 Apr 2011
Hi folks :)
Next week I'm ordering the components to build my new rig.
I've dicided in getting a pair of MSI ATI Radeon HD 6950 2048MB GDDR5 PCI-Express Graphics Card's to run in crossfire.
Reading around these forums I've seen mentioned things like Mini DisplayPort to DVI-D Active Single-Link Adapter as being required for the third monitor.
My question is - the card above comes with 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort - would I need the active adaptor or can I connect 1 monitor to each of the DVI connectors and the 3rd monitor to the HDMI connector using an HDMI to DVI adaptor (which I have a spare of)?
All 3 of my monitors only have DVI and VGA connectors.
Cheers in advance :cool:
I believe Eyefinity *has* to use a display port adapter for 1 of the monitors, you cant just use the DVI/HDMI ports, even in crossfire.
I'm not totally up with ATI setups though, went the Nvidia route myself.
im not sure, but i think u can plug in 2 monitors until each card without needing to use a displayport
usually u cant use both DVI and the HDMI on a single card thou.
I just read that you can only plug monitors into the top card, or else it will disable Crossfire & no Eyefinity...it will run as just 3 separate monitors
i guess it works differently to SLI then, i dont really have any experiance with crossfire :P
Correct.
With a Crossfire setup you can only use the outputs from 1 card.
Then leave the advice to those that do.
