£600-£650 Spec Check please
25 Mar 2003
Scotland
Just checking if the above is OK. I am open to ideas on better components for the money. Already have a keyboard, mouse, monitor, DVD drive and case.
Also using the hard drive listed above as a storage drive and installing Windows on a 80GB hard drive.
It's for my brother and he will use it for gaming (CS Source and COD 4) and general PC use.
Cheers
Great spec.
Dont install windows on a slow/old 80Gb drive, give it the best it can get, put it on the 1TB
I would personal get the 965 Phenom II its a nice overclocker. Got mine to 3.8 stable on air without voltage increase (ofc cpu dependent). The one you selected should overclock to the 965 default speed easy enough tho.
I would personal get the 965 Phenom II its a nice overclocker. Got mine to 3.8 stable on air without voltage increase (ofc cu dependent)
Why? the 955be is cheaper, and can reach just the same speeds.
they are all C3 steppings.
Have you not thought about doing a software bundle?
Can get windows 7 and a WD Caviar Blue 1TB for a combined price of £119.39 as opposed to the £167.97 you're paying for a HDD and Windows 7. Not to mention that mobo you're buying is 6GB/s compatible as well. So that'd save you £48.58 for something else.
HIS ATI Radeon 6950 1024MB GDDR5 PCI-Express Graphics Card with FREE Games Pack......................£173.99
AMD Phenom II X4 Quad Core 955 Black Edition "125W Edition" 3.20GHz (Socket AM3) - Retail..............£98.39
Gigabyte GA-870A-UD3 AMD 870 (Socket AM3) DDR3 Motherboard...................................................£81.98
Microsoft Windows 7 Bundle - Home Premium 64 Bit.......................................................................£68.40
Options applied to the above product:
Western Digital Caviar Blue 1TB SATA 6Gb/s 32MB Cache WD10EALX - OEM.......................................£50.99
XFX Pro 550W Core Edition Power Supply....................................................................................£50.99
OCZ Special OPS 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (OCZ3SOE1600LV4GK).......£35.99
Titan Fenrir Evo CPU Cooler (Socket LGA775/LGA1156//LGA1366/AMD K8/AM2/AM2+/AM3)...................£32.99
Sub Total : £494.76
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
Shipping : £10.50
VAT is being charged at 20.00%
VAT : £101.05
Total : £606.31
works out at simular cost and gives more value
that graphics card is the 1GB version, so it cant be 'flashed' into a 6970
the processor cooler you chose doesnt come with an AM3 bracket ;)
by going for the HDD + windows bundle, and going for a cheaper (but still really good) PSU, you can get a major graphics card improvement, and a better CPU cooler (i think its better).
YOUR BASKET
1 x Sapphire ATI Radeon HD 6950 2048MB GDDR5 PCI-Express Graphics Card £203.99
1 x AMD Phenom II X4 Quad Core 955 Black Edition "125W Edition" 3.20GHz (Socket AM3) - Retail £98.39
1 x Gigabyte GA-880GA-UD3H AMD 880G (Socket AM3) DDR3 Motherboard £88.99
1 x Microsoft Windows 7 Bundle - Home Premium 64 Bit £68.40
1 x Western Digital Caviar Blue 500GB SATA 6Gb/s 16MB Cache - OEM (WD5000AAKX) £29.99
1 x Corsair Hydro H50-1 High-Performance CPU Watercooler (Socket LGA775/1155/1156/1366/AM2/AM3) £51.98
1 x BeQuiet Pure Power L7 530W Power Supply £42.98
1 x OCZ Special OPS 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (OCZ3SOE1600LV4GK) £35.99
Total : £634.21 (includes shipping : £11.25).
graphic memoury only comes into effect when running multiple monitors at hight res, witch i think to manny people forget
defo usefull
+1 on Reaper 392 build list as well :) have to give credit where due
