I dont need to respect religion nor its claims that a theistic deity based God is real under the following universal definition of God:
You do not believe in such a God either, so yes you are an Atheist too regardless of however you choose to label yourself.
Impretty sure thats not how it works, it wouldn't take one hour, it would still take 4.2 years for you on the space craft, the only difference in time is to the observers.
But then there would be no time dilation.
edit]Relative velocity time dilation
When two observers are in relative uniform motion and uninfluenced by any gravitational mass, the point of view of each will be that the other's (moving) clock is ticking at a slower rate than the local clock. The faster the relative velocity, the greater the magnitude of time dilation. This case is sometimes called special relativistic time dilation. It is often interpreted as time "slowing down" for the other (moving) clock. But that is only true from the physical point of view of the local observer, and of others at relative rest (i.e. in the local observer's frame of reference). The point of view of the other observer will be that again the local clock (this time the other clock) is correct and it is the distant moving one that is slow. From a local perspective, time registered by clocks that are at rest with respect to the local frame of reference (and far from any gravitational mass) always appears to pass at the same rate.[1]
Then the same is also true of the concept of life on other planets.
Feel free to drop it at any time and stop getting so bothered over my opinions. I didnt ask you to start replying to every post I made in this or any other thread, you do that entirely because you want to troll and flamebait others.
There is to the observers and the universe around you.
Explained in the edit for you mr. smartass, and no as I said time and time and time again in many many many replies to you in several threads on this forum, I do not believe in the ILLOGICAL possibility of a DEITY based GOD as defined by ANY of the worlds RELIGIONS.
Now can you use that organ in between your ears called a brain and understand that for once? No, I suppose you cant due to how illogical and irrational you are.
No as YOU are traveling at the speed of light, so the dilation effect is on YOU not others, they are not traveling at that speed.
Well I am not an Atheist, I am ignostic and for reasons that I have quite clearly set out on numerous occasions, including that I feel that people assume too much when dismissing God and that the concept is often hijacked by the term.
So no, I am most certainly not an atheist as I do not disbelieve in the concept of God, I simply have yet to find a coherent universally accepted definition of God and find the entire acceptance or dismissal meaningless.
http://en.wikipedia.org/wiki/Theological_noncognitivism
As an Atheist you disbelieve in God, which means you give credence to the concept of God to begin with, I do not hold that view.
Although considering that you find the whole of philosophy hogwash, I am surprised that you define yourself with a philosophical position at all.
Anyway whether you respect religion or not is not what I was referring to, I was referring to mutual respect for the posters and their points of view.
Atheism, in a broad sense, is the rejection of belief in the existence of deities.[1] In a narrower sense, atheism is specifically the position that there are no deities
God is the English name given to a singular being in theistic and deistic religions (and other belief systems) who is either the sole deity in monotheism, or a single deity in polytheism
Hrmm well firstly this is the first time i have had a discussion with you in this thread about God so not sure where you get the idea that you have many many times replied to me on this matter?
Secondly, trying to make sense of your statement:
"i do not believe in the illogical possibility of a deity based God as defined by any of the worlds religions"
I got lots of problems trying to understand what you are saying here but i'll give it a bash.. Are you saying that you dont believe in God inasmuch as how God is defined by any world religion?
Just for reference note that statement is not actually the same as:
a) belief in God
b) believing in the logical possibility of God
Is it organised religion's conception(s) of God you dont believe in?
Last line, your clock always goes at a normal speed.
<snip>.
Conceptions of God vary widely. Theologians and philosophers have studied countless conceptions of God since the dawn of civilization. The Abrahamic conceptions of God include the monotheistic definition of God in Judaism, the trinitarian view of Christians, and the Islamic concept of God. The dharmic religions differ in their view of the divine: views of God in Hinduism vary by region, sect, and caste, ranging from monotheistic to polytheistic to atheistic. Divinity were recognized by the historical Buddha, particularly Śakra and Brahma. However, other sentient beings, including gods, can at best only play a supportive role in one's personal path to salvation. Conceptions of God in the latter developments of the Mahayana tradition give a more prominent place to notions of the divine.
In modern times, some more abstract concepts have been developed, such as process theology and open theism. Conceptions of God held by individual believers vary so widely that there is no clear consensus on the nature of God. The contemporaneous French philosopher Michel Henry has however proposed a phenomenological approach and definition of God as phenomenological essence of Life.
Sorry that is not a universally accepted definition of the concept God, If you bothered to actually read the wiki page:
So now can we drop it and continue on with the debate at hand.
It is a universally accepted definition of God as it is the definition that the vast majority go by.
Yes. But, the man on the ship still experience 4.2 years so does not aid spec travel at all. It's relative.
