- 21 Feb 2011
- Darford, Kent
Hi everyone
I,m thinking of upgrading to Sandybridge in the next few months (when I have enough money lol)
I have decided I will most likely get the following items:
http://www.overclockers.co.uk/showproduct.php?prodid=CP-368-IN&groupid=701&catid=6&subcat=1275
http://www.overclockers.co.uk/showproduct.php?prodid=MB-044-AK&groupid=701&catid=5&subcat=
I need to get a new cpu cooler as my current cooler (in sig) isn't able to be fitted onto a sandybridge socket.
I have been looking at loads of coolers but really can't decide the best one.
My current choices are as follows:
http://www.overclockers.co.uk/showproduct.php?prodid=HS-005-PL&groupid=701&catid=57&subcat=1395
I do really like the Megahalems and that u can fit your fans but it does make it expensive.
http://www.overclockers.co.uk/showproduct.php?prodid=HS-093-TR&groupid=701&catid=57&subcat=1395
I also like this but looking at other review sites the silver arrow and Noctua DH14 seem to perform better.
http://www.overclockers.co.uk/showproduct.php?prodid=HS-078-TR&groupid=701&catid=57&subcat=1395
Really like the Silver arrow and does appear on the standard fans to be very quiet.
http://www.overclockers.co.uk/showproduct.php?prodid=HS-011-NC&groupid=701&catid=57&subcat=1395
This is always quoted as being one of the best air cooling cpu but is it worth the extra 15 odd quid
My case is in sig and should be able to support all of these coolers, I real question is what is the best option for maximum cooling.
Ideally I want no noise at all when cpu on idle but don't care under load, what I am really asking are the megahelms really worth the extra cash by letting u fit the best fans to them, or is it worth just getting on of the others.
And finally is their much difference between the D14 and the silver arrow and the venonmous X?
Thanks in advance
Thanks in advance
