Looking for 1920 by 1080 <256KB
14 Apr 2010
Milton Keynes
Hi there,
Wondering if anyone knows a link or has an awesome (prefered sexeh) background matching the above criteria that I can use as my Windows login screen =)
Thanks!!! =D
I wish someone would invent some sort of search engine where you could... wait..
Honestly I have looked... and put in the resolution but you can't set the size(kb) of the file... and i haven't after about 2 hours of looking been able to find a decent looking picture with that file size :P
Link the pic and someone here can do it for you. The method won't produce pin sharp images of course, but PS is very good at producing compressed JPEGs that still look good.
ooo if no one minds... that would be awesome!
main.php
As for what app im using... I follow this guide
Done :D[/url]
Haha Awesome :P
Paint.net will do it and it's a free download.
Cheers will get that tonight have have a play =)
Why do you want it to be less than 256KB?
Because its the silly rule you need to follow when you are using it as the login screen, ofc if anyone knows hot to do this without need it to be smaller than 256KB that would be freakin awesome, as of yet though, i only know how to do it this way! =(
Cheers everyone!
because its not possible.....
okay it is possible on that
http://snoop1050.pwp.blueyonder.co.uk/meep.jpg 176kb ignore any virus qwarning crap some idiot must have hosted a dodgy website on my isps webspace....
