- 31 Mar 2009
- Stoke-on-trent
Do overclockers sell these? Not able to find any in there online shop.
Gutted, not gong to buy a full case in order to get 6 stand offs![]()
What happened to the ones that came with the case you have?
The reason I need some is in an old case there wasn't any, the case had raised areas that the mother board mounted too. Im in wolstanton, not sure what size I need though, not the really long ones though.
they are a standard size aren't they?
It's up to you but if you send me your address via Trust I can drop you some off in an hour or so.
We'd need to be able to get access to the case to see which ones fit.
I'm not at home tonight, would you be able to drop some off tomorrow? Or I could call and collect some. It's very good of you to offer me some to btw.![]()
They come in different sizes so we'd need to try them with your case to see which are the right length.
I could drop some off tomorrow evening, between 8 and 10, if that's OK.
Which case is it you have? I might be able to find some information on what size it needs.
That would be great mate, not sure what case it is, cheap one from overclockers.
