Never had a problem with proper Xenons (projectors, etc.). Yes I've seen the odd pleb with a HID kit in their Saxo's reflector lights, but that's just them being 'tards.
Don't get why the hate is against bi-xenons though.... surely the only time the high-beam (the bi part) is on is when there's no other car's around!?
So European DRLs are competing with the sun? Oooooookkkkkkk
Just taken a look at his website, http://www.lightmare.org/
So they won't give me a suntan then?![]()
I think as someone said above the reported is an even bigger idiot than the Saxo HID mahoosive.
May only be halogens not HIDs but ****ing annoying. Mainly seems to be Grannys driving around with high-beams on all the time, whereas the HIDs in reflectors crew are normally Saxo/Corsa chavs.Oh right. You'll be pleased to know that my Saxo doesn't have HIDs or anything chavtastic in it!
Anyways what I find more of an issue than incorrectly fitted HIDs round here is people with their high-beams on and not dropping down to low-beams when there's other cars around!![]()
Well what do you do stare into oncoming lights till you are dazzled?
I think there should be a legal Lux limit on headlight brightness.
How many Lux would you like to be the limit? Also this would be rather expensive to enforce at the roadside, no?
hummmm - so this is people fitting the HID bulb to a reflector based headlight? Not people fitting HID bulbs to projector based headlights?
If so... I agree it's a f'in pain in the arse and I want to smash their face in, then they go one further an put them in fog and spot lamps![]()
I cannot read anymore of that website or the article. Infuriatingly bad 'facts'.
The guy needs to get a life tbh
Personally, I don't understand how people can't see it as in issue. Do you have them fitted yourself? It is infuriating when you're driving in the dark in a poorly-lit area when someone comes the other way and blinds you to the point you can barely see the road ahead yourself.
