is designed for car designers who fail to consider the implications of their design choices for n00b wannabe mechanics trying to save a few $$$
Background:
Cadillac (2002 Deville) started to develop a little misfire, slightly rough idle and would throw up a P0300 general misfire error code intermittently. Figured it was probably the spark plugs as they are listed to last 100k and it's done 90k now. Read up a bit on CaddilacForums (which is ridiculously helpful) and got the parts ordered, $50 for 8 spark plugs - nice.
Now the 'cool' thing about the Caddy is it's a transverse-mounted engine, so you have a front bank of 4 plugs - a doddle, and a rear back of 4 plugs hich are right up against the back of the engine bay - not so doddle.
Pic:
Now - the designer hell part - so it's a slight PITA to do the rear bank but I'm ok with that, it's a big engine jammed in to a not huge engine bay and transverse mounted - cool. However the kicker is (presumably an afterthought due to emmissions) they just stuck a second air injection pump right on top of the rear bank - and the bolts to undo it are about 8 inches down the back of the engine bay, where of course it's all really dark, and no room
That said, after about 4 hours of 30% skill, 10% luck, 20% knuckle skin and 40% expletives I managed to get it all done - \o/ Local mechanic quoted it as 3-4 hours plus $100 in parts so around $500 so a nice little saving there - though I'm sure changing spark plugs shouldn't be quite so hard
So, to make this more than just a self-congratulatory/frustration-releasing thread - what are your experiences with cars where you just scratch your head and wonder whether the designers actually thought things through when putting consumable parts in ridiculous locations
Background:
Pic:
