Did anyone see themselves ahead within the same level? The first time I was on this level I saw Chell running through the exit.
I liked it, the turret orchestra was brilliant as well.
I'd like to say its not... but there is no evidence to support anything or disprove anything atm. Events of Half Life 2 are certainly ahead of Portal given the Borealis is still at Aperture Science but that doesn't mean to say time travel won't happen somehow ><
The turret orchestra nearly made me **** bricks as I thought that was GLaDOs's final act of betrayal.
I'm glad we got to the surface at the end - a huge relief.![]()
Borealis isn't at aperture science - it's just a dry dock. The ship itself is missing from it (hence the achievement).
How does that mean its not the surface?![]()
I don't think GLaDOS would let Chell just go like that. It's most likely a simulation.
I love all the loose ends in Valve games, gives so much room for speculation and hidden story![]()
Hit another bit thats causing me a bit of trouble. Its basically after you finish with the old test chambers and GLaDOS talks about getting angry and going out with dignity. Theres a long shaft with a two tiered level higher up, and a splodge of blue gel you can manouver onto a slanted tile to make a ramp. I can propel myself onto the ramp and then get 2nd highest level, but cant figure out how to get onto the highest level, which has the ramp leading to the exit.
